Index last updated: 2026-04-28 23:40 UTC
The usual Polysix questions (non-lithium battery replacement?)
2006-03-28 by b_j_glover
Hi -
Sorry, a newbie question. I just picked up a Polysix that needs
minor repairs. Fortunately the battery is fine, at the moment.
I'd prefer to replace it with a rechargeable one similar to the
original to avoid the extra modifications that seem to be necessary
when using a lithium battery. (I know that may still leak one day,
but not anytime soon.) I thought I saw the part described once, but
now I can't find the reference. Any advice...?
I also need to replace one of the patch selection buttons, which is
functional but worryingly loose. And after reviewing past comments
I'm still not 100% sure whether the pitch bend wheel should be
sprung or not (though I'm guessing not)...
Thanks for any comments,
Ben
Re: [PolySix] The usual Polysix questions (non-lithium battery replacement?)
2006-03-28 by Niels Ott
For my Trident MK2, I removed the old battery (carefully with soldering
iron) and dragged it to an electronics store. The guy there didn't have
the exact replacement but a suitable part.
As this replacement didn't fit onto the circuit board I made a little
seperate (bread)board which I connected with a cable and some pin
connectors.
Cons: Is a lot of work
Pro: If the battery should leak again, it won't mess up the CPU board.
Furthermore it is easier to replace again now.
The original battery of the Mk2 seems to be the same as used in the
Polysix, at least according to this picture:
http://analog.no/mods/korg_polysix_battery_leakage.htm
Reichelt Elektronik (large German electronics mail order company) still
has the orginal battery for sale - but the thing is that you have to
order parts for 10\ufffd and the battery costs 1,75\ufffd there. Grrr!
But the original replacement is most easy to install.
I can't judge on that.
Best,
   Niels
