Index last updated: 2026-03-31 18:47 UTC
8048 CPU replacement?
2006-01-29 by jure zitnik
hello it's me again.
well so far it looks like it's quite possible that the main cpu is
faulty. the full label is
NEC PD8048c-345
i have a few questions:
does this microprocessor have internal PROM? if so - do we have a
binary for it? how would i go about programming it? anyone ever did
that?
any idea if it could still be available somewhere? any known substitute?
anyone got any of those spare? from a broken polysix maybe?
best regards,
jure
Re: [PolySix] 8048 CPU replacement?
2006-01-29 by The Old Crow
The 8048 is a factory mask-ROM device. You ("you" being Korg in this
case) sent a paper tape roll of the object code to mask into the device
to Nec (or Intel) and they made a run of 3,000 or more parts for you.
3,000 was the usual minimum quantity in those days. The "-345" in the
part number is probably the index number kept at the factory for which
file is masked onto the part.
That being said, there does exist the 8748 and 8749 CPUs, which are
EPROM versions. You can still get unprogrammed ones from places like
jameco.com. It has to be programmed, which means you need a device
programmer that can program 8748s/8749s. The binary code file is also
needed, which I have around here somewhere. I have made KLM-367,
KLM-366 and KLM-380 (Trident) CPUs in this manner.
Crow
>NEC PD8048c-345
>that?
>best regards,
>jure
>PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6
>Yahoo! Groups Links
Re: 8048 CPU replacement?
2006-01-29 by gil_we
Chris, how much do you sell the new KLM-367A compatible board for
nowdays?
this
device
you.
which
are
like
also
> Crow
> >NEC PD8048c-345
> >that?
substitute?
> >best regards,
> >jure
> >Yahoo! Groups Links
I do, email me.
> NEC PD8048c-345
> that?
substitute?
> best regards,
> jure
