Index last updated: 2026-03-31 18:47 UTC
Back to One
Back to One
2005-12-22 by motionsandwaves
I just recently had the battery replaced in my Polysix and had
everything cleaned inside and out, the problem is that say if I'm one
Bank C sound 2, after 15-20 minutes the sound reverts back to Bank A
Sound 1. What do I do?
Any help would be super groovey
Joe
Re: [PolySix] Back to One
2005-12-23 by The Old Crow
That sounds like the KLM-367 is resetting. Might want to adjust the
reset trimmer a little. The A-D, 1-8 LEDs (and other LEDs) should all
light up for about 1 second before setting to patch A-1.
If it sets to A1 too quickly, then the reset voltage adjustment is a bit
too 'edgy'.
Crow
>Thanks
>Joe
2005-12-27 by modulatio@aol.com
A thousand thankyous , I'll let you know how it turns out.
Cheers
joe
To: PolySix@yahoogroups.com
Sent: Fri, 23 Dec 2005 00:10:19 -0500
Subject: Re: [PolySix] Back to One
too 'edgy'.
Crow
>Thanks
>Joe
PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6
Yahoo! Groups Links
Sent: Tue, 27 Dec 2005 09:35:13 -0500
too 'edgy'.
Where is it the reset trimmer located?
Joe
Reset Trimmer
2005-12-29 by modulatio@aol.com
Sent: Tue, 27 Dec 2005 16:01:45 -0500
too 'edgy'.
Joe
2005-12-30 by The Old Crow
It is labeled VR1 RESET and is located near the upper right-hand
corner of the KLM-367 when looking at the board mounted in the Polysix.
The other six trimmers (that have nothing to do with the CPU reset) are
close to each other in the middle of the board.
Crow
>Thanks
