I`m thinking of upgrading the polysix to midi. (Johannes)
1)Will i be able to record sutoff/resonance etc.. changes to a
sequencer say cubase sx?
2)I`m not sure if to modify the polysix with the white noise options
and the progrmmable pitch bend et.. options, (to retain the
originality of the polysix). What do you guys think?
> Thanks,
> Kevin DaSpaceman!
I think Johannes is the best one to answer this ;)
BTW Johannes, the uA726HC is on the way, we'll see what comes up :)
Thanks.
> Responses are welcome :)
options
> > Thanks,
> > Kevin DaSpaceman!
Most likely, NO. Most MIDI kits only record note-on/note-off, but there are some other expensive ones (if you can find them) that will interface more completely.
> > options and the progrmmable pitch bend et.. options, (to retain
> > the originality of the polysix). What do you guys think?
If you are worried about the originality of the P6, why are you putting a MIDI kit into it? It's your machine, do what you want!
