Index last updated: 2026-03-31 01:44 UTC
i need new ic2
i need new ic2
2005-07-05 by fmulassano
Hi folks,
my name is francesco from italy.... i have repared my poly6, but all
led is on.... oldcrow says bad cpu...
possible solutions?
sorry for my 'maccheroni' english! :-)
Re: i need new ic2
2005-07-07 by gil_we
I guess adjusting the "Reset Adjust" trimmer could solve the problem,
but you'll have to verify. This is how I solved it on my Trident.
--- In PolySix@yahoogroups.com, "fmulassano" <urbanspaceman@t...> wrote:
> Hi folks,
> possible solutions?
Re: i need new ic2
2005-09-14 by darke_one666
wrote:
> Hi folks,
> possible solutions?
If the battery leaked then it is likely that IC30 & IC31 on KLM367
will need replacing. You may have some tracks that have corroded too
that will need repairing. These devices are connected to the D/A and
are important for the correct function of the programmer. You will
also need to check that the D/A is set up properly once you have
completed a repair like this. I believe you can find this somwhere on
www.synthzone.com
