Re: [newmellotrongroup] M400 #275....J Mascis's (Dinosaur Jr.) mellotron...Di...
2010-04-13 by lsf5275@aol.com
It's an SMS-3. Good board. Have him bring it to me. Frank In a message dated 4/13/2010 10:23:24 A.M. Eastern Daylight Time, e4103s@yahoo.com writes: [_Attachment(s)_ (mip://064332e0/default.html#TopText) from Jack Younger included below] Hello everybody! Long time. I recently had the opportunity to head out to Amherst, MA to adjust and assess J's mellotron and, being that he is a bit reclusive, figured I'd share my experience and let folks know where #275. He is not the type to become too involved in mellotronia so the info may be helpful to those with the list. Anyhow, it's an unusual unit that he said he purchased in the 90's from somebody who worked at Mellotron (Sweden), apparently when they were beginning to set up shop in Canada, although his memory is fuzzy as to names and dates. Any help from you folks as to the possibilities of any of this would be great. #275 is a hideous thing, brush painted black, with a housing built around the existing cabinet supporting what appears to be a tool tray. Bench model? He has two more racks, one with other stock sounds and one he had made back in the 90's. I believe it has an SMS of some sort. It's pretty buff. The pics should tell you, but I couldn't get into the machine to see as I was on a time constraint. I will say that it is a very stable unit....sweet sounding and despite the eventual need for pinch rollers and pads, held the adjustments and remained solidly functional. I informed him of the need for an overhaul and that it should probably be removed for this, so folks in the New England area that would be interested should respond. He isn't looking for anything aesthetic, simple replacement/He isn't looking for anything aesthetic, simple replacement/<WBR>adjustment o So let me know if you're curious. Hope you are all well! -Jack
