The Mellotron Group group photo
The Mellotron Group
Index last updated: 2026-04-28 23:38 UTC
Off topic AND off-the wall
2013-01-30 by Sean
The strangest thoughts come on the shitter....
We all love the plate reverb right?
What if one was made with a gigantic sheet of wooden ply instead? Like the top of a violin? What on earth would that sound like as a reverb?
Thought I'd share.
-Sean
Re: [newmellotrongroup] Off topic AND off-the wall
2013-01-30 by william Beith
I build plate reverbs for studios. Wood is not dense enough. I use stainless
steel under high tension which gets a long decay time and a bright sound without
huge resonant peaks.Bill
To: newmellotrongroup@yahoogroups.com
Sent: Tue, January 29, 2013 6:41:55 PM
Subject: [newmellotrongroup] Off topic AND off-the wall
Thought I'd share.
-Sean
2013-01-30 by lsf5275@aol.com
Well that kills my alternative idea of using an old shoe.
In a message dated 1/29/2013 8:36:32 P.M. Eastern Standard Time,
wbeith@sbcglobal.net writes:
stainless steel under high tension which gets a long decay time and a bright  sound
without huge resonant peaks.Bill
____________________________________
Thought I'd  share.
-Sean
2013-01-30 by fdoddy@aol.com
How 'bout making a plate reverb out of me? My wife thinks I'm incredibly dense.
fritz...oh...m400#1697 btw.
To: newmellotrongroup <newmellotrongroup@yahoogroups.com>
Sent: Tue, Jan 29, 2013 11:32 pm
Subject: Re: [newmellotrongroup] Off topic AND off-the wall
In a message dated 1/29/2013 8:36:32 P.M. Eastern Standard Time, wbeith@sbcglobal.net writes:
I build plate reverbs for studios. Wood is not dense enough. I use   stainless steel under high tension which gets a long decay time and a bright   sound without huge resonant peaks.
Bill
Thought I'd   share.
-Sean
RE: [newmellotrongroup] Off topic AND off-the wall
2013-01-30 by Tom Doncourt
Though it may seem ridiculous your idea makes some sense. I've gotten some sympathetic tone ringing out of large marimba notes that I've built. I tried miking them up and it added a warmth to the sound if not an actual reverberation. I wouldn't use a sheet of ply though- the way it is laminated prevents it from resonating. If you glued some 1/2 thick cedar lengths together on edge ( and better if they are quarter sawn), hung the "plate" from its nodal points and plcaed a speaker and a mike close by you might get an interesting tone, if not an actual reverb. I've seen Mr. Beith's lovely plate units-this is something of a wholly other order!
From: newmellotrongroup@yahoogroups.com [newmellotrongroup@yahoogroups.com] on behalf of Sean [fourtytwominds@yahoo.com]
Sent: Tuesday, January 29, 2013 7:41 PM
Thought I'd share.
-Sean
Thanks for the plate acknowledgment. One issue I did not address is the process
of exciting the plate to create the reverb then the mechanism to pick up the
reverberated sounds. Inducing vibration in metal, then picking up the results of
that induction is reasonably easy. Trying the same thing with wood seems to be
more of an acoustical mechanical process. Maybe excite the wood with a
loudspeaker (or one of those wall mount hi-fi speaker - subwoofer units) then
use a Barcus Berry pick up for the return signal.
Bill
To: "newmellotrongroup@yahoogroups.com" <newmellotrongroup@yahoogroups.com>
Sent: Wed, January 30, 2013 7:44:38 AM
Subject: RE: [newmellotrongroup] Off topic AND off-the wall
Thought I'd share.
-Sean
2013-01-31 by Jack Younger
Since most pickup systems are magnetic, a wood plate would probably be more effort than it's worth....
That's not to say you can't use the resonant qualities of wood in the process. The strings are the integral part of the equation. Wood works on an instrument because the strings resonate the surface.  We've used our piano for reverb effects on a few occasions. The idea of a dedicated "string reverb" has been on my mind for quite some time.....tried it with a few old beater acoustic guitars, but with very little return.
But something's currently in the works....details when something actually functions.  Ha!
Sent: Wednesday, January 30, 2013 10:22 AM
Thanks for the plate acknowledgment. One issue I did not address is the process of exciting the plate to create the reverb then the mechanism to pick up the reverberated sounds. Inducing vibration in metal, then picking up the results of that induction is reasonably easy. Trying the same thing with wood seems to be more of an acoustical mechanical process. Maybe excite the wood with a loudspeaker (or one of those wall mount hi-fi speaker - subwoofer units) then use a Barcus Berry pick up for the return signal.
Bill
Thought I'd share.
-Sean
2013-01-31 by william Beith
Thinking about this at greater length, the wood plate would act more like a
filter than a reverberation device.
I try to get the plate (metal) to deliver as flat a response as possible with
maximum decay. The 3X7 foot plate gives a solid 3.5 seconds of decay, more if
you compress the output. And low frequency rumble becomes a problem in the
larger ones. A plate sitting on a concrete floor picks up the vibration of
nearby foot steps. Maybe I can make a long one as a seismic monitor!
 Bill
Sent: Thu, January 31, 2013 6:23:22 AM
functions.  Ha!
Bill
Thought I'd share.
-Sean
2013-01-31 by Tom Doncourt
One day Bill, I'm going to get one of those plate reverbs from you. I had a long standing dream of getting an EMT like we used in the 70's but ....this seems more realizable!!
On Jan 31, 2013, at 10:06 AM, william Beith wrote:
Thinking about this at greater length, the wood plate would act more like a filter than a reverberation device.
I try to get the plate (metal) to deliver as flat a response as possible with maximum decay. The 3X7 foot plate gives a solid 3.5 seconds of decay, more if you compress the output. And low frequency rumble becomes a problem in the larger ones. A plate sitting on a concrete floor picks up the vibration of nearby foot steps. Maybe I can make a long one as a seismic monitor!
Bill
Bill
Thought I'd share.
-Sean
2013-01-31 by Bruce Daily
Hi all-
   It occured to me (and maybe others) that one could glue a veneer of wood to a metal plate, re-enforcing the desired effects of both.  Admittedly, the glue may fail in time (and there could be bi-material warping effects), but the resulting reverb could be interesting.
   -Bruce D.
To: "<newmellotrongroup@yahoogroups.com>" <newmellotrongroup@yahoogroups.com>
Sent: Thursday, January 31, 2013 8:43 AM
> Bill
> From: Jack Younger <e4103s@yahoo.com>
> From: william Beith <wbeith@sbcglobal.net>
>Bill
> From: Tom Doncourt <tomdcour@amnh.org>
>The strangest thoughts come on the shitter....  We all love the plate reverb right?  What if one was made with a gigantic sheet of wooden ply instead? Like the top of a violin? What on earth would that sound like as a reverb?  Thought I'd share.  -Sean
Re: Off topic AND off-the wall
2013-01-31 by Sean
I imagine you'd have to have an incredibly soundproof room to get away with the amplification levels needed.
I also imagine the resonant peaks of the wood would give a bizarrely colored reverb sound, and probably a pretty short reverb time overall.
Tom, why quarter sawn?
-Sean
> Bill
> From: Tom Doncourt
> Â
> behalf of Sean [fourtytwominds@...]
> Â
> Thought I'd share.
> -Sean
Re: [newmellotrongroup] Re: Off topic AND off-the wall
Hi Sean, what I should say is that you want boards where ,when you look at the ends the rays run vertical, you would get this with rift sawn, to a lesser degree quartersawn, and even some boards of plainsawn. It is the type of grain you would find on soundboards in pianos , guitars etc because it resonates better. Marimba bars are mostly made with the end grain running vertically ,nice and straight all the way down the board. A plate made from wood like this would have a longer ring time than plywood,
-Sean
> Bill
> From: Tom Doncourt
> Â
> Â
> Thought I'd share.
> -Sean
