The Mellotron Group group photo
The Mellotron Group
Index last updated: 2026-04-28 23:38 UTC
Oiling the motor
Oiling the motor
2011-10-19 by Andy Thompson
Dear all
It's a bit late to bother Martin about this again, so maybe some of you can help. My M400 is blowing 2A fuses on its SMS - Martin tells me the motor probably needs oiling. I've done so in situ and replaced the fuse, but no improvement. I'm keen not to remove the motor, as I'm a crap mechanic and don't want the hassle of getting the drive belt back to its correct tension, unless absolutely necessary.
Any ideas?
Andy T.
Re: [newmellotrongroup] Oiling the motor
2011-10-19 by lsf5275@aol.com
Too much tension on the belt can do this. Oiling the motor also causes it
to attract dust. Dust works its way into the bushings and actually increases
 friction. these things both cause increased amperage draw and can blow
the fuses. Try loosening up the belt a bit. It should only have enough tension
 to turn the flywheel such that when you grab the revolving flywheel, the
belt  begins to slip on the motor pulley after only a bit of resistance.
Hope this helps.
Frank
In a message dated 10/19/2011 2:45:26 P.M. Eastern Daylight Time,
andy.thompson@virgin.net writes:
Dear all
Any ideas?
Andy T.
  To: newmellotrongroup@yahoogroups.com
  Sent: Wednesday, October 19, 2011 10:54 PM
  Subject: Re: [newmellotrongroup] Oiling the motor
  Bigger fuse!
  Just kidding, way too dangerous!
  Heh heh  :-)   Martin jested that I 'put a nail across it'. How d'you know when a professional roadie's been at your amp? (Not actually a joke). The main fuse is wrapped in foil from a cigarette packet. Seen it done. "Quick fix, innit, mate?"
  Perhaps too much tension from the belt, but if it didn’t do it before, and nothing changed, stumped.
  Frank thinks the same, by the looks of it. Thanks for the help, chaps, will tackle it on the morrow.
  Andy T.
  Dear all
  Any ideas?
  Andy T.
2011-10-19 by Tony
Bigger fuse!
Tony PhD Computer Science, Certified Electronic Technician
Sent: Wednesday, October 19, 2011 11:45 AM
Subject: [newmellotrongroup] Oiling the motor
Dear all
Any ideas?
Andy T.
2011-10-20 by Tony
Good luck Andy!
Please post the results.
Tony
Sent: Wednesday, October 19, 2011 2:01 PM
  Bigger fuse!
  Andy T.
  Dear all
  Any ideas?
  Andy T.
