LPC2212/4 and Altera Cyclone in same JTAG chain?
2005-10-27 by wayne_s_cranwell
Has anyone used a Ulink USB-JTAG adaptor from within Kiel's uVision3 IDE, to target a Philips LPC2214 that is in a JTAG chain with an Altera FPGA, e.g. cyclone? The manual chain configuration of the IDE uVision tool allows one to enter the Altera IDCODE and IR length etc. as well as the Philips IDCODE and IR length etc. The Settings view then shows two devices - and the Philips "radio" button is selected to indicate the device the debugger should "talk" to. However, a simple verify of internal flash fails repeatedly with "ARM cannot be reset; Check JTAG cable" or similar. My chain setup is as follows: ULINK TDI--> Altera TDI --> Altera TDO --> LPC TDI --> LPC TDO --> ULINK TDO. TMS and TCK are parallel to both. If I physically isolate the Altera from the TDI/TDO chain (isolate Altera and Short ULINK TDI to LPC TDI) such that there is only the LPC in the chain, all is well. Any experience/ comment welcomed. Thanks Wayne
