Lpc2000
Index last updated: 2026-04-28 23:31 UTC
Bootloader initializations ?
2005-07-07 by Gromann, Klaus
Hi all,
does anyone know which parts of the LPC2294 are initialized by the
internal bootloader? I have strange differences when I start with HW
reset (includes the internal bootloader) and when I start my software
from the debugger.
Differences are :
- timer speed is different
- I have to do a vector remapping at the beginnig of the main-function
(remap at the beginning of the reset_handler doesn't work !)
I use a phytec LPC2294 eval board and Rowley CrossStudio for ARM.
Any suggestions  or hints ?
Klaus
Re: [lpc2000] Bootloader initializations ?
2005-07-08 by 42Bastian Schick
Gromann, Klaus <klaus.gromann@...> schrieb am Thu, 7 Jul 2005
17:51:30
> Differences are :
You should not rely on any setup, just spend the code to setup the chip
as you need it. This means at least VIC, MAM,PLL and vector-mapping,
PINSEL.
We have a customer using the same board, and as he sets up the relevant
parts within the resethook of our RTOS so he is sure its software works
same either from Debugger, HW reset or his own bootloader.
42Bastian Schick
Re: Bootloader initializations ?
2006-04-28 by austin.linux.lpc2294@boardsailor.com
I have been trying to get my LPC2294 eval board from Olimex working with interrupts, and I am having quite a bit of trouble.  Could I see some code that would reset the vector mapping in the main function after the bootloader has had a chance to mess it up?  I believe that that the bootloader changing the vector table is my biggest problem.  I can get the processor to produce an interrupt when UART0 recieves data, but once an interrupt occures, it appeares from how the processor manipulates the LED that is wired up that, the processor has crashed.
   Austin Schuh
>  Gromann, Klaus <klaus.gromann@klau...> schrieb am Thu, 7 Jul 2005
>17:51:30
>> Differences are :
>PINSEL.
>the
>42Bastian Schick
