Lpc2000
Index last updated: 2026-04-28 23:31 UTC
external reset of timer
2005-01-19 by itsjustimpossible
Hi
I need to use an external pulse to reset one of the timers of an
LPC2294. The latency of the FIQ from an external interrupt is too
long, so I wondered if there is any clever technique that anyone has
thought of to achieve the same thing faster.
Sadly, the capture pins aren't able to provide a nice external
hardware reset input.
If anyone has any suggestions they would be gratefully received.
many thanks
Simon
Re: external reset of timer
2005-01-19 by Karl Olsen
--- In lpc2000@yahoogroups.com, "itsjustimpossible" <simonjh@b...>
has
Use a capture pin and enable the capture interrupt.  In the capture
interrupt handler, remember the captured value as the time where you
would have reset the timer.  When you later need the timer value,
subtract the remembered value.
Karl Olsen
has
Karl Olsen
2005-01-19 by lpc2100_fan
Friendly amendment,  during the capture interrupt service routine
disable all other higher priority interrupts while handling the
setting of the timer. Read the captured value, read the current timer
value, subtract captured from current value, count the number of
cycles this took write the result of the subtraction + cycles into timer.
Cheers, Bob
> has
> Karl Olsen
OT: LPC903 ICP spec
2005-01-20 by Peter Jakacki
This is slightly off topic but since this is a Philips micro and I also
use them as a support micro for the LPC2xxx .....
<Posted to comp.arch.embedded>
I just received some samples of the LPC903 the other day and it hit me.
Where is the specification for the ICP? I know it only needs
clock,data,reset but I can't any find a document that describes the
timing and format for that section.
I know that you can use the eval board plus an adaptor to talk to these
things but it is usual for a manufacturer to release the programming
details. I have been using PIC12's in this area and there is no shortage
of info on programming these miserable little (useful) suckers.
Does anybody know anything about the ICP spec for the LPC903s?
TIA,
Peter
Checked by AVG Anti-Virus.
Version: 7.0.300 / Virus Database: 265.7.1 - Release Date: 1/19/05
RE: [lpc2000] OT: LPC903 ICP spec
2005-01-20 by David Kay
Philips Apps have just posted the ICP spec and source code for the
ISP/ICP bridge software on the LCP900 users group:-
http://groups.yahoo.com/group/lpc900_users/files/
Best Regards,
For and On Behalf of Adilam Electronics
David Kay
Field Application Engineer - New Zealand
Tel  : +64 3 341 3050
Mob: +64 21 664 351
Fax : 0800 366 247
Email : david.kay@...
local focus_global reach - That's adilam !
Sent: Thursday, 20 January 2005 1:42 p.m.
To: lpc2000@yahoogroups.com
Subject: [lpc2000] OT: LPC903 ICP spec
TIA,
Peter
Yahoo! Groups Links
Re: [lpc2000] OT: LPC903 ICP spec
Thanks again Dave, I've joined, grabbed the files, and left a message.
Maybe you could help some more? :)
- Peter
2005-01-21 by itsjustimpossible
--- In lpc2000@yahoogroups.com, "lpc2100_fan" <lpc2100_fan@y...>
timer
timer.
> Cheers, Bob
Thanks for all the suggestions, I gave it a try and it works very
nicely. One of those useful techniques that I will have to remember,
makes sense when you think about it.
thanks again
Simon
