Lpc2000
Index last updated: 2026-04-28 23:31 UTC
ANNOUNCEMENT NEW ARM7 BOARD
Re: [lpc2100] ANNOUNCEMENT NEW ARM7 BOARD
2004-01-07 by J.C. Wren
Maybe it's just me, but I can't see to determine what country you are in.
	--jc
On Tuesday 06 January 2004 19:04 pm, Business webmaster wrote:
> http://arm.web7days.com
> regards,
> EZarm
> To visit your group on the web, go to:
>  http://groups.yahoo.com/group/lpc2100/
>  lpc2100-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to:
>  http://docs.yahoo.com/info/terms/
2004-01-07 by Arie de Muynck
Doesn't matter.
The board has no proper decoupling of the processor. Just look at the
pictures and compare with Leon's design. We already told him so in
sci.electronics.design etc.
Don't buy it, unless you want to solder caps directly on the processor pins,
or wait until he understands electronics, decoupling, reliability etc and
has fixed the design.
Arie de Muynck.
Re: ANNOUNCEMENT NEW ARM7 BOARD
2004-01-07 by gokbektas
Please find the attachment images. I already
posted I am designing a development
board for Philips
LPC2106.
It is simply desinged to make ARM
work.
Main features of the
board:
- One RS-232 Interface with
RX-TX
- One Full RS-232 Interface with all modem signals
etc.
- Standart 2x16 Dot matrix character LCD connector with
backlight
- On board 3.3V and 1.8V voltage regulators and two
power LEDs
- LPH7779 84x48 Graphic LCD (Nokia-3310 LCD) Board
Mount
  (uses standart IO pins, not SPI)
- 20pin
Connector for Wiggler JTAG interface
  - an 6
ch. DIP switch is used for selecting Graphic/Character LCD
an 8 ch. DIP switch isolates UART1 pins from level shifter IC if it is not
used
  - it is possible to replace 8ch DIP switch with 8pin
header connector
    if logic level uart signals needed for
embedded modems etc. same
    is provided for uart0 too with 4
pin header connector.
  - reset switch for CPU
  - SPI
connector with all SPI singals and 3.3V VDD and GND
  - Bypass
caps for every IC (check the PCB drawing and 3d pics)
  - A
little prototyping area
I
designed this board for my own use, I usually make my
own
development boards for new microcontrollers/FPGAs
etc.
Actually I am waiting my order at PCB fab.
They are busy now
and I have chance to modify and fix the board
before they start
manufacturing of
prototypes.
""Helpful Opinions, recommendations
are welcome!""
Best
Regards
2004-01-07 by Lewin A.R.W. Edwards
Ignore this idiot. He has been spamming comp.arch.embedded after asking
the most foolish questions imaginable. (He also goes by the names of
Mylinux, Myliux, EZarm, et al, if you want to search for some of the
threads). He either stole this design, or it's a scam, or he's just
reselling it - and no WAY can he provide any support for it.
  -- Lewin A.R.W. Edwards (http://www.zws.com/)
Learn how to develop high-end embedded systems on a tight budget!
http://www.amazon.com/exec/obidos/ASIN/0750676094/zws-20
Thank you, and thanks to Arie de Muynck.  I appreciate the heads up on this.
	--jc
>  > in.
>  Yahoo! Groups Links
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
