On Monday, July 12, 2004, at 11:52 AM, gregdeuerling wrote:
> I have a Maxim thermocouple converter (MAX6675) hooked up to a
> LPC2294's SPI. The MAX6675 is SPI read only device, i.e., enable
> chip select and it starts shifting out bits on each SPI clock.
> Is there no way to make the LPC's SPI receive a byte with out
> sending a byte first ? I hate to have to bit bang the LPC's I/O's
> to get the SPI functionality I need, but it looks like thats what
> I'm going to have to do.
> Am I over looking something ???
That's the way SPI works - a byte is received as it sent (as each bit
is clocked out, a bit is clocked in). You write a byte to the transmit
register, it sends/receives, then you read the transmit register to get
the byte back.
Just send a 0 (or whatever) in order to read.
Shannon
