Lpc2000
Index last updated: 2026-04-28 23:31 UTC
injecting an external 4 MHz clk into LPC2000, and using PLL - anyone done similar ?
2004-05-08 by microbit
Hi All,
This might have come up before I think, but I can't seem to
readily find it in my LPC2000 folder.
Has anyone ever tried supplying LPC2000 with an external 4 MHz
clock signal, to be used with PLL at higher clock rates ?
Since it's a full swing Ext signal, I don't see any limitations, other
than the osc buffer ckty, which surely should handle that.
I'm thinking of multiplying up to 64 MHz cclk.. a tad too high.
And 8 X = 32 MHz is too low.
This is for LPC2119/29.
Space is critical and I need to save an SMT Xtal real estate wise.
-- Kris
Re: injecting an external 4 MHz clk into LPC2000, and using PLL - anyone done similar ?
2004-05-10 by embeddedjanitor
In some place in the datasheet, the external xtal is specified as 10
to 25MHz. There might be problems trying to get the PLL running
properly off a 4MHz clock.
If you need a 4MHz clock for some other part of your board then
perhaps you can generate this out of the LPC2119.
--- In lpc2000@yahoogroups.com, "microbit" <microbit@c...> wrote:
> Hi All,
other
> -- Kris
Re: [lpc2000] Re: injecting an external 4 MHz clk into LPC2000, and using PLL - anyone done similar ?
2004-05-10 by microbit
Hi Charles (and philips_apps ?) ,
The PLL divider can be set for eg. 16, and the prescaler still can be
set such that the CCO runs within its specified range ?
I already have an accurate 4 MHz CLK output from an RF section on the
system (has its own crystal), and I was pondering over saving a crystal/caps
on the LPC2119/29 by injecting that 4 MHz into the CLKIN of LPC.
Board space needs to be minimal, an SMT crystal is quite big.
I might end up putting a low PPM crystal in after all, unless there is some clarification
to the actual freq range allowed with an Ext input Clock signal into LPC2000.
Robert at philips Apps team ?
Can you assist ?
Anywho,
Bit of a pain to bootstrap it, but it just comes down to a pull up resistor on
a control line - although the default clock on power up out of RF device is
500 kHz, until set to 4 MHz with an SPI instruction......
( I do this on MSP430, it clocks of its internal DCO, and the 4 MHz is used
as SMCLK for peripherals that need accuracy like timers and USARTs etc)
That could very well be the biggest problem : the LPC clock will only be
500 kHz at cold start for the first few mS.
I can't see why one couldn't inject a full rail-to-rail 50% duty signal like that
into the oscillator input of LPC2000, it *should* work.
Reliability is the issue of course.
I'm sure there's a reason for the restriction on EXT clock in, but I don't readily
see it. The 10-25 MHz as an oscillator with Xtal, that's understandable, it's quite
hard to provide an on-chip Pierce or similar that can cover a highly extended freq.
range.
The only other reason I could have seen for the equal freq. range restriction
on Ext Clock of 10-25 Mhz could have been some AC coupling time constant
that is too low for signals much lower than 10 MHz.
But that seems like it doesn't make sense either.
Thanks anyway !
B rgds
Kris
2004-05-10 by Bill Knight
Kris
  One quick point.  The LPC does not like a rail-to-rail
input clock.  I believe the max level is the same as the
core voltage (1.8v) and the minimum is 200mV.  Also, the
signal should be capacitively coupled.
  It probably wouldn't hurt if you had the RTCLK signal
pinned out on your JTAG connector either and used it.
Otherwise debugging is going to be very slow.
-Bill
the ARM Patch
2004-05-10 by tphatrapornnant
As I remember, I used to try 2.0 MHz crystal oscilator but it seemed
PLL can't work at lower than 10MHz. I have just tested by changing
OSC from now 10 MHz to 2 MHz with 6 time multiplier. The 1 ms
interrupt timer changed to 1.8 ms, it should be 5 ms. So, I afraid it
doesn't work at 4 MHz.
Teera.
> Hi All,
other
> -- Kris
2004-05-11 by philips_apps
"Crystal Oscillator" section in the "System Control Block" chapter of
the LPC2114/2124/2212/2214 and LPC2119/2129/2194/2292/2294 User
Manuals covers input frequency range topics.
If on-chip PLL system or boot-loader is used, input clock frequency
is limited to exclusive range of 10 MHz to 25 Mhz.
These restrictions are imposed by the design of the PLL circuitary.
Since all Philips LPC2000 parts have the same PLL module, above
requirements exist in the case of LPC2104/5/6 parts, too.
Philips Apps Team
--- In lpc2000@yahoogroups.com, "tphatrapornnant" <tp35@l...> wrote:
> Hi,
seemed
it
> Teera.
> > Hi All,
> other
> > -- Kris
2004-05-12 by slawcus
I haven't noticed this in datasheet:
Can I drive X1 with low speed external clock without PLL, then change
X1 frequency on the fly and after that use PLL?
Example: PDIUSBD12 CLKOUT - default is 4MHz (I'm aware of voltage
limitation at X1 of LPC device).
LPC2106 X1 is driven by this 4MHz, during PDIUSBD12 setup change
CLKOUT to the higher value > 10MHz. Turn on the PLL, continoue with
normal operation. PDIUSBD12 CLKOUT change should be without glitches
and frequency is not changed with USB reset (according to datasheet).
Is this possible?
> Regards,
> Philips Apps Team
> > Hi,
> seemed
> it
> > Teera.
> > > Hi All,
> > other
> > > -- Kris
2004-05-12 by microbit
Hi Bill,
Thanks for the tip !
I was still at concept stage and that hadn't occured to me yet :-)
-- Kris
To: <lpc2000@yahoogroups.com>
Sent: Monday, May 10, 2004 9:02 PM
Subject: Re: [lpc2000] Re: injecting an external 4 MHz clk into LPC2000, and
> Kris
> -Bill
> the ARM Patch
2004-05-13 by microbit
> Regards,
> Philips Apps Team
Ok, so it's the ref. input on the phase comparator that's the limiting
factor,
or similar.
That makes sense now.
Thanks !
-- Kris
2004-05-13 by philips_apps
Hello Slawcus,
Philips has not conducted test(s) that would exactly match what you
have described in the post, however if proper PLL setup & connect
scheme are applied, we expect no problems. As long as the transition
from one clock to another is kept glitch-free on the X1, and all side
effects are taken in consideration prior to the design (i.e. impact
on all of the on-chip peripherals), you are safe.
Philips Apps Team
change
datasheet).
> Is this possible?
chapter of
frequency
circuitary.
> > Regards,
> > Philips Apps Team
wrote:
> > > Hi,
> > seemed
changing
afraid
> > it
> > > Teera.
wrote:
> > > > Hi All,
limitations,
> > > other
high.
wise.
> > > > -- Kris
