Lpc2000
Index last updated: 2026-04-28 23:31 UTC
Bootloader: Wrong answer on Prepare-Command (2) (Sector 2) CMD_SUCCESS
2004-04-01 by Andreas Schwarz
Hello,
I'm using lpc21isp to program my LPC2106. When I try to download the
test2 hex file from the Aeolus newlib example, I get the following output:
Writing Sector 0: ....(...)
Sector 0 written
Writing Sector 1: ....(...)
Sector 1 written
Writing Sector 2: ....(...)...Wrong answer on Prepare-Command (2) (Sector 2)
CMD_SUCCESS
...and the program doesn't work (no traffic on TXD). If I change "#if 1" to
"#if 0" and vice-versa (to disable the UART echo example), the program loads
ok, and I can receive the "hello world"-message over the UART.
What's wrong here?
Andreas
Re: [lpc2000] Bootloader: Wrong answer on Prepare-Command (2) (Sector 2) CMD_SUCCESS
2004-04-01 by Robert Adsett
At 06:41 PM 4/1/04 +0000, you wrote:
>Hello,
>Sector 0 written
>Sector 1 written
>CMD_SUCCESS
>What's wrong here?
Can you run the Philips ISP program? If so, does it work?
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
> >Hello,
> >Sector 0 written
> >Sector 1 written
> >CMD_SUCCESS
> >What's wrong here?
I tracked down the error message.  It's coming from this piece of code
             sprintf((char *)tmpString, "P %ld %ld\r\n", Sector, Sector);
             SendComPort(tmpString);
             ReceiveComPort(Answer, sizeof(Answer)-1, &realsize, 2,5000);
             sprintf((char *)tmpString, "P %ld %ld\r\n0\r\n", Sector, Sector);
             if(strcmp((const char *)Answer, (const char *)tmpString) != 0)
                 printf("Wrong answer on Prepare-Command (2) (Sector
%ld)\n", Sector);
                 OutputErrorMessage(GetErrorNumber(Answer));
                 exit(4);
The prepare command is documented as taking a start sector and an end
sector number and so something like
P 2 2
should be sent to the micro.  Unless echo is turned off then that should be
echoed back followed by the return code number (which should be 0 for
CMD_SUCCESS).
It's apparently not getting that but the code is converting whatever is
received to a number and then to an error message.  If you can compile the
code try inserting the following line
printf("Expected [%s] -- Received [%s]\n", tmpString, Answer);
That may help track down what is actually happening.
Robert
                         Kelvin Throop, III
