Re: [lpc2000] Digest Number 1137
2006-05-30 by Juval I
> > Message 9 > From: "imacke76" imacke@... > Date: Tue May 23, 2006 0:33pm(PDT) > Subject: Second Stage Bootloader > > Hello , > > I implemented a second stage bootloader in the first flash sector of > my Phillips LPC2294. The bootloader is able to update the flash by CAN > bus using IAP commands. The bootloader checks a signature and if this > is correct, it starts the program from the second flash sector. Before > starting the program in the second flash sector, interrupts are > disabled using the I-bit in the cpsr register. The bootloader then > loads the program counter with the start address from second flash sector. > In the second flash section, interrupts are re-mapped to ram. The ram > is re-organized. > Updating the second section with JTAG works fine. The Bootloader > checks the signature and is executing the code. Updating the second > section with my bootloader ist also working. But in some cases, the > code doesn´t start executing. Comparing the uploaded code with the > dependent file says O.K. > Maybe, some registers has to be reinitialized!? > > Any help would be appreciated. Thanks! > > > > > > ________________________________________________________________________ > Hi I'm doing somting alike but with a fail-safe methode contact me of list and I might be able to help you Juval [Non-text portions of this message have been removed]
