Lpc2000
Index last updated: 2026-04-28 23:31 UTC
difference in execution time(Keil, LPC2129)
2006-05-06 by ayman ghaly
Hi all
    I measured the execution time of the code shown below using break points in the keil simulator and it was approximately 500 micro seconds.
  But when I measured the execution time of the same code from the Philips ARM board LPC2129 it was about 3000 micro seconds.
  Do you have any idea about the cause of this difference?
  Note that I used the following adjustments before running the code:
  Target: Philips LPC2129
  Oscillator frequency: 12 MHz
  CCLK= 48MHz
  PCLK= CCLK/2
  Cc: No optimization for the code
  Code:
              unsigned int i,j;
              for (i=0;i<5;i++)
                          for (j=0;j<286;j++);
  Thanks for your help.
  Ayman
Get amazing travel prices for air and hotel in one click on Yahoo! FareChase
Re: difference in execution time(Keil, LPC2129)
2006-05-06 by derbaier
How many wait states did you have on your real physical memory and how
many wait states did you tell your simulator to simulate?
-- Dave
--- In lpc2000@yahoogroups.com, ayman ghaly <ghalyayman@...> wrote:
>   Hi all
seconds.
>   CCLK= 48MHz
>   PCLK= CCLK/2
>   Code:
>               unsigned int i,j;
>               for (i=0;i<5;i++)
>   Ayman
FareChase
Re: [lpc2000] Re: difference in execution time(Keil, LPC2129)
2006-05-07 by ayman ghaly
Thanks Dav for your concern.
  I download the program to the internal flash of the ARM board, so I don't use external memory. I didn't find anything related to the number of wait states in the manual of the LPC2129 regarding to this.
  Ayman
-- Dave
>   Hi all
seconds.
>   CCLK= 48MHz
>   PCLK= CCLK/2
>   Code:
>               unsigned int i,j;
>               for (i=0;i<5;i++)
>   Ayman
FareChase
  SPONSORED LINKS
        Microcontrollers   Microprocessor   Intel microprocessors
  YAHOO! GROUPS LINKS
    Visit your group "lpc2000" on the web.
 lpc2000-unsubscribe@yahoogroups.com
New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.
2006-05-07 by derbaier
You can look up the functions of the MAMCR(0xE01FC000) and
MAMTIM(0xE01FC004) registers in the User Manual to see how wait states
are configured, but the RESET state is to have the MAM disabled. I can
not tell from reading the register descriptions if all 6 wait states
are enabled if MAMCR is all zeros, OR if there are no wait states
enabled if MAMCR is disabled. I have always cofigured access times
according to clock speed like the manual suggests, so I can't come up
with an answer from personal experience. The safe default is to come
out of RESET with the maximum number of wait states enabled, but I can
not find that statement in the manual, so it is only a guess that
probably you are running with 6 wait states ( 7 clocks access). Since
you are successfully running the clock at 48MHz, you either have a
VERY fast part, or your are running with some wait states, since 20MHz
is the maximum for single clock access to the internal FLASH according
to the MAM usage notes.
--Dave
>   Ayman
> -- Dave
> --- In lpc2000@yahoogroups.com, ayman ghaly <ghalyayman@> wrote:
> >   Hi all
> seconds.
> >   CCLK= 48MHz
> >   PCLK= CCLK/2
> >   Code:
> >               unsigned int i,j;
> >               for (i=0;i<5;i++)
> >   Ayman
> FareChase
>   SPONSORED LINKS
>   YAHOO! GROUPS LINKS
Service.
and save big.
2006-05-07 by Robert Adsett
 From page 83 of the user manual
MAMTIM provides 7 cycles for memory fetch on reset.
And earlier in the same section when MAMCR is 0 no memory fetches use
latched data, all initiate a fetch cycle.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
http://www.aeolusdevelopment.com/
2006-05-08 by derbaier
> Robert
I have not used the 2129 varient for a while, so that probably
explains why that information is not on page 83 of the 3 May 2004
manual that I used. You probably have an actual current manual?
Regardless, your comment made me look a little deeper in my own manual
and I did find some similar info.  This statement on page 92 of my
manual explains how it is actually accomplished.
"The MAM actually uses latched data if it is available, but mimics the
timing of a Flash read operation. This saves power while
resulting in the same execution timing. The MAM can truly be turned
off by setting the fetch timing value in MAMTIM to one
clock."
So, to get the simulator times and the actual times to agree, he needs
to enable MAMCR and set MAMTIM for a 1 clock access?  And, of course,
run the ARM clock at less than 20MHZ.  :-)
Thanks for the setting me straight!
--Dave
