Lpc2000
Index last updated: 2026-04-28 23:31 UTC
Another problem with flash utility v2.2.3
2006-04-19 by mahbub1833
Today I downloaded flash utility v2.2.3 from philips website for
lpc2148. after successful installation when i ran that program i
couldn't change device. All other buttons works except the device
selection.
Another interesting thing is - when I change device from my prior
installation (v2.2.0) and then run v2.2.3 again then the chaged device
is shown in that.
I tried by uninstalling all prior versions and fresh installation, but
didn't work.
Did I miss anything? Or the utility have that error? How would I slove
this problem?
Thanks.
SV: [ZS3] [lpc2000] Another problem with flash utility v2.2.3
2006-04-19 by Kell Jørgensen
> selection.
Click the "Read Device ID" button and it will show up.
> is shown in that.
The device type is stored in the registry. Ver. 2.2.3 will probably read
it there if the registry entry has not been removed.
> didn't work.
When you uninstall the registry entry probably _will_ be removed.
Kell
Re: Another problem with flash utility v2.2.3
2006-04-19 by fordp2002
--- In lpc2000@yahoogroups.com, "mahbub1833" <fireball003@...> wrote:
> Hi,
> selection.
> is shown in that.
> didn't work.
> this problem?
> Thanks.
This is not a bug but a feature.
2.2.3 automatically senses the device. I use 2.2.3 all the time and it
works pretty well.
