Op Tue, 11 Apr 2006 10:17:16 +0200 schreef <j.martens@...>:
> The reason why I would like to use a GCC compiler is because the compiler
> included in the Kickstart is code limited to 32K
You can't use GCC from within the EW (unless you hack into the custom
build tool). You can, however, debug GCC-generated ELF/DWARF files. But
either will probably cost more in developer time and device production/use
than buying your way out of the code limit.
Gemaakt met Opera's revolutionaire e-mailprogramma:
http://www.opera.com/mail/
