Lpc2000
Index last updated: 2026-04-28 23:31 UTC
I2C
I2C
2006-03-10 by Sutton Mehaffey
I haven't totally gotten my I2C (LPC2148) to work with my RAMTRON
serial RAM yet.  All the status' look good on both writing and reading
to RAM, but still get 0xA1 after I write a 0x77.
However, I noticed that even if I have no power on my RAM and no SDA
and SCK lines connected, all the status' are exactly the same and the
data is still 0xA1.  It seems as though if the RAM weren't responding
at all, you shouldn't get valid codes.  And, I have my ACKs turned on!
 Any ideas?
Sutton
Re: I2C
2006-03-10 by rtstofer
>  Any ideas?
> Sutton
Two things:  First, I assume your I2C code is from the Philips samples
in the Files section, right?  I would certainly start with this before
branching off to bigger and better things.
Second, I haven't had much success getting I2C to work without a logic
analyzer.  I have a couple of them but even the cheap setup from
KronosRobotics will work.  See
http://www.kronosrobotics.com/Projects/KRAnalyzer.shtml
In one of my magazines I saw a circuit to detect the start condition
and use that to trigger a scope.  It also implemented some other
trigger conditions.  Unfortunately, I can't find the magazine.  I was
thinking about stuffing the circuit into a CPLD.
I don't know anything about the 2148 but I did use I2C on the 2106 and
it worked fine.  I grabbed the code from someplace - I don't even
remember where.  However, I was just talking to Microchip Port
Extenders and an LCD display.
Richard
Re: I2C
2006-03-10 by Mark Butcher
Hi Sutton
If you haven't done so yet, I think that it is time to reach for your
oscilloscope. Perhaps the RAM is never responding at all because it is
not being addressed properly (Its inbuilt address and bus
configuration address).
To be sure that you are not being deceved, look at the SDA line during
the 9th clock cycle sent from the master to see whether the slave (the
RAM) is actually pulling it low and thus responding or not.
If it's not responding you will have to cure this first - although in
this case I would also expect one of the following status in the
interrupt after sending the address:
    case (0x48):                      // the slave address was sent
but no ack was received (RX)
    case (0x20):                      // the slave address was sent
but no ack was received (TX)
Cheers
Mark Butcher
www.mjbc.ch
reading
on!
>  Any ideas?
> Sutton
Re: I2C
2006-03-10 by charlesgrenz
Hi Sutton,
  What size pull-ups do you have and have you tried slowing the clock
down?
regards,
Charles
>  Any ideas?
> Sutton
Re: I2C
2006-03-11 by Sutton Mehaffey
Charles,
Using 10K pullups.
Mark,
Yes.  I was afraid I would have to get the scope out.  I was hoping
that it would be straight forward.  Hardware rarely is, I guess.  It
is strange that I am getting back all ACKs, (0x18 and 0x28s) during
the process.  Even to my surprise with the RAM chip not connected....
You know how it is, take a deep breath, sigh, and continue on.  I'll
figure it out.  It's probably something silly I'm missing.
Richard,
I have been using exclusively the LPC2148 user manual flow chart and
state algorithms.  And, I've looked over the sample code.  I am
getting the correct status, but now that I seem to get those status
(with ACKs) with the RAM chip not even connected, it looks like scope
time.
Sutton
--- In lpc2000@yahoogroups.com, "charlesgrenz" <charles.grenz@...> wrote:
> Hi Sutton,
> down?
> regards,
> Charles
> >  Any ideas?
> > Sutton
Re: I2C
2006-03-11 by rtstofer
> Charles,
> Using 10K pullups.
10k isn't a pull-up when applied to I2C.  The absolute maximum that
might work on a good day is about 4.7k and a more realistic value is 2.2k.
You never provided a link to the RAM device (that I recall) but in
looking at the FM24CL64, they recommend a 1.1k pull-up.  The reason it
is so small is the lower VDD.  Normally, at 5V VDD the pull-up can go
as low as 2k, maybe 1.8k.  At 3.3V the resistor would be somewhat smaller.
But, again, I don't know which device you are using.
Richard
Re: I2C
Thanks Richard.
I think I discovered 99% of the problem.  Apparently, I was shipped
samples of the Serial RAM FM24C256 chip that were true 5V parts and I
asked for 3.3V.  Makes it a little difficult to get the chip to work
:)  But, I will also change my pullups when I get the correct chip in.
 They are too high.
I've been a software designer for many years and I am trying to learn
more about the hardware side and do some of the design myself.  I
found I don't learn how the hardware works as well if I have someone
else do all the hardware design.  So, sometimes I miss some things in
the datasheet that are very important (4.7K pullups instead of 10K).
It's fun to learn, though.
Sutton
> > Charles,
> > Using 10K pullups.
2.2k.
smaller.
> Richard
Re: [lpc2000] Re: I2C
2006-03-11 by Tom Walsh
Sutton Mehaffey wrote:
>Thanks Richard.
> They are too high.
That's how we all did it, you can learn all you want in schools, but
until you get into the real world ...
I've learned a lot by looking at other's designs, heh, I do not "know it
all" and it is is fun to learn new stuff!
Enjoy,
TomW
>Sutton
>>>Charles,
>>>Using 10K pullups.
>2.2k.
>smaller.
>>Richard
>Yahoo! Groups Links
Tom Walsh - WN3L - Embedded Systems Consultant
http://openhardware.net, http://cyberiansoftware.com
"Windows? No thanks, I have work to do..."
Re: I2C
I come from the other side of the problem.  All of my background is in
hardware design.  I struggle with things like Linux and the GNU
toolchain but datasheets and timing specs are a cake walk.
But, we're all having fun or we wouldn't be here!
Richard
> >Thanks Richard.
> > They are too high.
"know it
> Enjoy,
> TomW
> >Sutton
> >>>Charles,
> >>>Using 10K pullups.
> >2.2k.
> >smaller.
> >>Richard
> >Yahoo! Groups Links
