Lpc2000
Index last updated: 2026-04-28 23:31 UTC
Type cast to byte aligned variable in GCC
2006-02-19 by weartronics
Dear lpc2000,
I am trying to port some Keil example code (LPC2148 USBHID) to the GCC
compiler. Keil use the __packed keyword to specify byte alignment for
variables (see
http://www.keilsoftware.com/support/man/docs/ca/ca_le_packed.htm) but
this is not supported by GCC. I know GCC provides an "__attribute__
((__packed__))" which can be used in variable declarations, but how
can I type cast to a byte aligned variable type!? My problem line is
below...
*((__packed WORD *)EP0Buf) = (USB_EndPointHalt & m) ? 1 : 0;
Thanks!
Nic
Re: Type cast to byte aligned variable in GCC
2006-02-20 by Thiadmer Riemersma (ITB CompuPhase)
I built macros to handle such cases. This is more portable. I use GCC,
but I actually don't know whether the syntax that you are proposing is
supported.
Re: [lpc2000] Re: Type cast to byte aligned variable in GCC
2006-02-20 by nic@weartronics.com
Hi Thiadmer,
Thanks for your reply, I think you may be correct the type cast to byte
aligned variable is not possible using GCC.
Can you show me an example of your macros, so I can try to rewrite the
code to use the macros instead?
Kind regards,
Nic
>supported.
>Yahoo! Groups Links
