> Message posted by Andre Favreau <aliasjunkmail@...>:
> Does anyone know how to loop a file and avoid a clip when it loops back to
> the beginning?
> I need to make a 30sec of music that will loop for a website.
> Thanks
Yes, I've done that a lot. Simply make at least three copies of the loop
on a track in Logic (or any other DAW). Then smooth the transitions by
audio crossfade and finally cut out the a full loop in the middle (loop nr
2 if using 3 in total). Then this loop should loop with no glitches.
Export it to you preferred multi media format.
Greetings from Sweden
Per Boysen
www.ilike.com/artist/Per+Boysen
