The Logic Off Topic list
Index last updated: 2026-04-28 23:27 UTC
Synchro errors from D drive
2004-09-30 by HKC
All of a sudden my audio HD is starting to give me problems, everything coming from the D drive is giving "synchronization errors". It started yesterday when the disk too slow message started to pop up every now and then. Then today it developed into this very annoying state. Is this the much dreaded IBM deskstar problem (they seem to just break down) or what else could be wrong?
If I move the files to the main drive everything is ok so it�s not a matter of drivers. I�m on windows but so were half of this list 2 years ago so I thought this was a good place to ask. A new drive doesn�t cost much so that�s not really an issue but I don�t want to buy it if something else is causing the errors.
PS If I run all audio tracks from the C drive and add one audio instrument where the samples are located on the D drive then the problem occurs when I play the instrument, as soon as I stop things are back to normal.
Henrik Krogh
henrikkrogh@...
Re: Synchro errors from D drive
2004-10-01 by gswerner2002
> If I move the files to the main drive everything is ok so it´s not
a matter of drivers. I´m on windows but so were half of this list 2
doesn´t cost much so that´s not really an issue but I don´t want to
are back to normal.
> Henrik Krogh
Is this the first time you've tried to use audio files from the D
drive, or combined with the C drive? Or do you have a different audio
driver active that you dont usually use?
I get sync errors with certain audio drivers at times
