The Logic Off Topic list
Index last updated: 2026-04-28 23:27 UTC
Hard drive not found
2004-02-15 by litepipe
Hello,
          I'm having a problem with my IBM Deskstar 20gig drive. My computer
won't regognize it. I've had the hard drive for about 2 years with no
problems. Over the past couple of months every once in a while the hard
drive wouldn't get noticed at boot-up. After a cold boot it would usually be
o.k. The problem seems to get worse with time and today I can't get the hard
drive to be noticed at all. I've tried a cold boot, entering the bios,
taking the hard drive out (it's in a removable tray) and nothing is working.
I haven't noticed any weird sounds coming from my computer, but it's in a
closet so I don't really hear it much. I just derfagged it the other day and
it appeared o.k. There have been a few times where SX or Logic crashed
because it appeared te hard drive disapeared.
         Any suggestions? I didn't just lose my drive did I? Thanks!!
  --litepipe
Re: [L-OT] Hard drive not found
2004-02-16 by Murray McDowall
Litepipe - I have bad news. I suspect the caps on your mobo are not long
for this world. I had a very similar experience a year or so ago on the
machine I am typing this on - or an earlier incarnation thereof.
A couple of years back a lot of Taiwanese Mobo makers cut corners by buying
capacitors from a crowd in Taiwan which stole a process for making
electrolytic caps from a Japanese firm. They sold them at half the price of
the Jap firm and so the mobo manufacturers saved about 25c per board.
Unfortunately, the Taiwanese firm left out a step in the process and the
phony caps suffered from a slow internal buildup of gas. Eventually they
fail and cause all kinds of instability in the power rails on your board.
I had an Abit PIII board with this problem - the first manifestation was
errors in some but not all Ethernet transfers. Quite some time later it
started refusing to see my boot drive on the first boot up. It would work
on a reboot. Eventually the board (Abit BE6 II) failed.
I later discovered this was very common and some major brands had whole
lines of machines based on boards with this fault and according to some
support whistleblowers one major firm (think of HAL) had a policy of not
revealing this to consumers unless they already knew of the problem.
Imagine having some dork tell you to reinstall windows when he knows you
have one of two million of their machines built on boards with this fault.
A new board (a by then hard to find Asus TUSLC2 - superceded components are
not easy to get) fixed everything.
I could be mistaken about the problem in your case but I would bet your
drive is just fine.
Murray
2004-02-16 by litepipe
Hi Murray,
are
  Luckily my board is an ASUS TUSLC-2. Or maybe not so lucky...I would
rather the board be bad than my hard drive.
  --litepipe
At 11:21 PM 2/15/04 -0500, you wrote:
>  Hi Murray,
>are
OK  nice board ;-)
It is possible that your board was built after this problem came to light
in which case the caps could be fine. If you can remember when you bought
the board this might help - my Abit board that went bad was made about mid
2000 and it died about Aug/Sep 2002.
Here are a bunch of articles on this:
http://www.theinquirer.net/?article=6085
http://www.theinquirer.net/?article=13962
http://www.theinquirer.net/?article=5878
This one is on IBM's way of handling this.
http://www.theinquirer.net/?article=10115
One test would be to get another drive, ghost your current system onto it
and see if it does any better in the machine. Drives are very cheap now and
if there is anything wrong with the current drive you won't lose your
data/system. I like to keep a drive lying around for emergencies - I bought
a n 80 Gig Seagate 7200.7 for 100 bucks Australian a week or two ago.
Murray
2004-02-16 by mercutio
There were a series of Deskstar IBM drives that were prone to early
failure.
I had one of these - luckily was able to coax most of my files on to
another drive before it went completely.
There are class action suits and lots of documentation on the web -
Google for "IBM Deskstar failure" or something similar and I think you
will come up with a list of the affected models in short order.
My advice would be to get a new drive immediately and if you can coax
the Deskstar to life - rip what you can off it and trash it.
