The Logic Off Topic list
Index last updated: 2026-04-28 23:27 UTC
Re: [LUG] [OT] HELP! Mac Techies: View Options
2004-01-20 by Andy Hardwake
Hi Chris,
Don't know why it happens, but it's always the same way here after
upgrading/installing/reinstalling any system software, and it (nearly)
always gets to normal after 2 or 3 days of use, provided you choose
your setting as many times a day as you get to it... Not a reasonable
explanation, I know, but this is how it works here.
Best,
Andy
On Jan 20, 2004, at 7:16 AM, Chris Moore wrote:
> I have a View Options problem:
> Every-time that I login (or sometimes even during the same session) the
> View Preferences that I have set (via the VIEW menu, or using
> Command+J) for my Applications folder always reset to something else!
> I have tried setting the view options the same for both "This window
> only" and "All windows" views... It doesn't matter, they still reset to
> something else. They do not "stick"!
> I have tried everything that I can think of. I have "repaired disk",
> run MacJanitor, "repaired disk permissions", etc.  I even deleted the
> file named "com.apple.finder.plist" and let it replace itself on
> reboot. All of this to no avail! The view preferences STILL change back
> to something else when I log back in again...!
> I just upgraded from Jaguar 10.2.8, and this problem has carried over
> to my "Archive and Install" version of Panther 10.3.
> Please help!
> Chris M.
2004-01-20 by fauxstout
reset to
a couple things may be the cause. if you use FileVault i have read
that it tends to eat user preferences randomly. another one may be
that eithe r the folder your trying to set prefs for i slocked. you
can un-lock it by Apple-I for the info screen, and somewhere in the
permissions area click the 'unlock' icon if its locked.
hope that helps
kristian
2004-01-21 by logiclists
> hope that helps
Thanks for the tips guys!!!  But, a few people contacted me off-list and I got the
answer, and it worked!!!!
First, the answer:  Delete the hidden file called "DS_Store" in any folder that is giving
your "View" troubles.... That's it!  These files can get corrupted.
You can find these files by using the Finder's search program (COMMAND+F), and
then adding a second search parameter and make it search for "invisible" files....
Then, when you find the "DS_Store" file of the folder that is giving you issues, just
select it and DELETE!!!  Problems gone, as a new DS_Store file is created
automatically.... Although I think that you have to logout/login first (that is what I did
just in case)....
LASTLY, this was a "carry-over" issue that I have been having for MONTHS, and was
not a result of the upgrade to Panther...  I just got sick of it NOW, that's all!
All is fixed, thanks to the advice!
Chris M.
{Admin} Can we add it to our FAQ pages? Was: HELP! Mac Techies: View Options
2004-01-22 by Andy Hardwake
> and I got the
> (COMMAND+F), and
> you issues, just
> created
> (that is what I did
> just in case)....
> MONTHS, and was
> that's all!
Many thanks, Chris, for posting this. I really think it's worth being
placed somewhere on FAQ pages (do we have OT FAQ BTW?).
Best,
Andy
