Korg poly-800 diode info
2019-01-31 by studio_1a@...
Archive for korgpolyex.
Hi, can someone give me some alternatives for D1=HZ-5CLL-TD and D2=SR1K-2 . I noticed there are some differences between Klm-596-4 and Klm-596-8 unfortunately only general Klm-596 schematics are available.
thanks
2019-01-31 by <backshall1@...>
thanks
2019-02-01 by studio_1a@...
2019-02-01 by <backshall1@...>
Hi Don,
the 596-4 board does have a battery soldered and hotglued between IC18 & IC19 as well like previously mentioned D1 & R1 in place and soldered. The preference would be not to re-install the patches everytime, so then I should just remove D1 & R1 if the battery is present, hypothetical question could this have affected the -5 rail? I've measured the T1 transformer and will check the L1 coil next but all other rectifying diodes check out ok. On, transistors I've tried to cross reference those parts but some more obscure parts came up..I will try to source the original parts on ebay this way I won't have any doubts.
Hi Don,
Hi Don,
I believe that's why Q1,Q3,Q18 as well as various caps and other components were replaced, I just inherited this keyboard as non working(missing -5V rail?), but many things seems wrong. Questionable solder joints, ground leads to various components IC4-IC3 and some caps, really shitty work I must say done by previous owners, half desoldered CPU, new eprom...etc..I'm taking my time to review everything and clean it up, hoping to revive it soon. I managed to order the original transistors from ebay, so its just a waiting game now.
Any other suggestions appreciated and thank you very much for your help. Have a great day
