Poly800 DCO 1 does not play the right notes
2015-11-25 by bagaeta@...
Hello, I'm a new member here, general synth geek and collector. I recently took delivery of a Poly800 but when I tried it I noticed some strange behavior, with some notes out of tune. After a bit of fiddling I think this is happening only with DCO1: when in double mode with DCO1 level turned down to 0 the notes are in tune.
With DCO1 it looks like the DCO is not responding to notes (from the keyboard or MIDI) in the right fashion. So for example if I play C D E F it sounds kind of like C D Eb E (or something to that effect)
Any idea what could be causing this and how to fix it?
Thank you!
Bruno
Thank you!
Bruno
