2015-09-09 by bperkins211@...
I will have to pull this back out of mothballing, but if you recall I had been working on this that can work either Stand Alone app or in Most DAW's as a VST.
KorgKontrolVST KorgKontrolVST This feature is not available right now. Please try again later.
Preview by Yahoo
that one shows Fruity Loops running a VST version of it.. has a gating effect by triggering the Volume ON/OFF and sweeps the filter open/close.
KorgWobble2 KorgWobble2 This feature is not available right now. Please try again later.
Preview by Yahoo
this one shows how you can draw complex filter modulations that can by SYNCHED TO BEAT! in a VST enviroment. IE if you speed up the BPM, the modulations will speed up too.. and of course slowing down BPM will slow down the modulations.. you can hear that in this clip at about 1:00 where it slows down the first time...
KorgKontrolVST
KorgKontrolVST testing a custom VST plugin controller for Korg Poly 800 with HAWK800 firmware mod.
Preview by Yahoo
I still need to get an AtomaHawk from you someday to tweak in the FM modulation and other parameters it provides...
The above still works very nicely and I did figure out how to get the realtime tweakable GUI ADBSSR envelopes to work.. just need some scripting help to INVERT them. But it's nice to be able to actually SEE what the Breakpoint and Slope do graphically to the standard ADSR envelope.
It also needs some more tweaking in fetching a Patch data to set all the virtual knobs up for you each time you call a new patch up. Right now the only way I could do it is by looping MIDI from the GUI.. Poly>GUI>Poly.. maybe some kind of special filtering of the MIDI data is needed.
So basically it is only about 3/4 done and it could be ported to Macs too.. and of course 32 and 64bit systems.
Mike I think you have a copy of one of my 1st versions of this already..
/Blaine
