korg poly 800 problems joystick and 12 db
2015-02-12 by Vincenzo Vincenzo
hello to all of grouplet,
I wanted to ask for your help because I have a problem with my Korg Poly 800 modified Moog Slayer mod and cutting 12/24 db filter ..
the change has always worked but some days the joystick is not working properly ..
modulation DCO and VCF (above and below) is mute,
but by moving the joystick to the right I get the pitch bend + VCF and moving the joystick left I have the pitch bend + DCO.
modulations were summed with the right and left;
on the contrary above and below is mute.
with editing 12/24 db sound only 24 db, 12 db sound is muted.
according to you what I can do?
Thank you in advance for all the help.
