Poly 800 data knob schematics
2014-05-13 by neosay@...
Archive for korgpolyex.
2014-05-13 by bperkins211@...
2014-05-14 by Sami Jumppanen
On Tue, May 13, 2014 at 3:45 PM, bperkins211@... [korgpolyex] <korgpolyex@yahoogroups.com> wrote:
I authored that and probably should delete it. I abandoned the project when I couldn't get a good response from the P800. I believe the problem is that the MPU is not scanning fast enough, coupled with the problem of a wide enough pulsed signal from the encoder to keep the 4066 switch closed long enough. That's my best guess. And is probably why we have not seen a successful mod like this work. It's a mod that seems to require modification to the firmware to actually support a encoder for value changes to parameters to work decently. ~Blaine
Sami Jumppanen
http://netti.nic.fi/some-e
2014-05-14 by Michael Hawkins
2014-05-14 by neosay@...
2014-05-14 by Eanna Butler
On 14 May 2014 14:15, neosay@... [korgpolyex] <korgpolyex@yahoogroups.com> wrote:
I found a kit for a data knob here - but the kit itself is unavailable and the guys form circumbenders don't what to share the instructions... but obviously there is a technical solution...
Korg Poly800 mkII data entry knobKorg Poly800 mkII data entry knobData entry knob to replace the up/down keys on a Korg Poly800 mkII Pressing the knob takes the synth in and out of edit mode. There are 20 clicks per 360 deg...Preview by Yahoo
2014-05-14 by bperkins211@...
2014-05-14 by Martin Ator
2014-05-19 by neosay@...
Sorry for bending the name circuitbenders...
@Blaine: I understand that you are not convinced about the solutions you worked on for the data knob. But do you think you could correct the schematics in principal that I can start to prototype something? My understanding for electronics not good enough to do it based on your comments in your recent message ; - ) A handwriting would be also absolutely sufficient…
Thanks!
2014-05-19 by bperkins211@...
2014-05-19 by Michael Hawkins
2014-06-10 by neosay@...
2014-06-10 by bperkins211@...
