Archive for korgpolyex.
Poly 800 mk1 playing up (still very workable)
2014-04-03 by <wrezal@...>
Hi all,
Last time I came here you where all very helpful and I found I just really needed a new PSU for my Poly 800 (got one now). Problem this time around is that I took my poly on a little trip and then it wouldn't turn on pre gig practice (I admit I didn't have a proper case for it) and it was making garbage sounds like just sounded like junk and there where some issues with lights etc.
I take it home and leave it a few days and then suddenly I can power it on again but the presets have all gone and now the headphone jack isn't responding to the volume pot (but still works). Volume pot also a bit crackly.
Have performed the moog slayer and an audio input mod on it, but could my bad soldering have messed something up inside or is this just a deeper problem?
Thanks all for the help!
Cheers,
Dave
Re: Poly 800 mk1 playing up (still very workable)
2014-04-04 by Jill Saphic
well then!
that sounds terrible, doesn't it.
Poly-800s dont seem sturdy, but they are put together by KORG
with being strapped on and played in mind, banging against your
legs and being picked up and put back down lots!
the sound from the lighting is usually shielding of some kind isn't in place.
The only thing I've seen make a Poly-800 lose it's internal memory is
power outage with no battery backup/dead batteries.
Even if it's just unplugged from the wall without batteries installed
or the ones in there are dead.
Did you make sure you got the right milliamps on your new PSU.
Thats really important, and don't believe that its not, especially on
a plastic economy synthesizer. did you see this on the net:
KORG POLY-800 PSU
Part/Model number:
KAC9500
center plug is 2,1 mm.
outer ring of PSU connector is "+" positive.
center tip of PSU connector is "-" negative.
 Power: DC- 9Volts-300ma miliamps)
"or" alkaline batteries (C cells x 6)
If you went over 300, thats a bit of a problem...
I waited for a couple of months to AC--> power mine on
and just used batteries untill I found the right one
with exactly 300 ma, I can imagine it going all wonky
if it had too hot a power supply.
But hey, just a thought! maybe it helps...
Re: [korgpolyex] Re: Poly 800 mk1 playing up (still very workable)
2014-04-04 by Sami Jumppanen
PSU milliamps = max current output. The more the safer for operation - the worse for short circuits ;).
PSU don't "push" current into Poly, it's the Poly that draws the current. In other words: it takes what it needs and the rest from the supply is just "not used".
Why only the 300mA PSU worked for you, Jill, is explained by some *other* factor than the milliamp rating. That's what I can place a bet on. What it is, I can only guess.
Some PSU's give poorly regulated (humming, unsteady) voltage that may drop below the required voltage level under load. These days the transformer PSU's are luckily replaced by switching-mode PSU's. You identify them by their light weight vs. higher current output. There is no big transformer with iron core inside. I don't know if there are switching-mode PSU's that cause unwanted high frequency noise for Poly.
In the past I've also seen PSU's that give a lot more than the nominal volts. I don't know if that is a problem for a Poly, or that it could cause the depicted symptoms.
Just my 9 volts... :)
Sami "Some-E" Jumppanen
On Fri, Apr 4, 2014 at 11:36 AM, Jill Saphic <jill_saphic@...> wrote:
well then!
KORG POLY-800 PSU
Part/Model number:
KAC9500
Sami Jumppanen
http://netti.nic.fi/some-e
Re: [korgpolyex] Poly 800 mk1 playing up (still very workable)
2014-04-04 by Michael Hawkins
Definitely sounds like your mod might have come loose somehow. But, we won't know until you open her up and have a good look. Check to see if you have an internal battery back up as well as look for other possibilities. If you're not sure about your mod's just take a photo and post it here.
Mike
On Thursday, April 3, 2014 1:54 PM, "wrezal@..." <wrezal@...> wrote:
Hi all,
Cheers,
Dave
Mike
Hi all,
Cheers,
Dave
2014-04-06 by Jill Saphic
Hello Sami
Oh! I think you misunderstood me.
 I didn't write that was the ONLY one that would work 4 me.
I wrote that I refused to connect a PSU to my little Poly-800 that wasn't
the exact specifications that KORG used in the PSU they supplied with the
synthesizer when it was new in the box.
hence, the 300 milliamps, 9volt DC.
 I certainly don't have many rules when it comes to my work gear,
but one I do is use the factory specs in the owners manual or service manual
when I replace anything.
Even a silly wall wart!
thats just me I suppose...
And if I can't manage,  I sell it to someone that believes they have the knowledge,
and wants to experiment around with things.
Thats why i wrote it was just a thought, I should have said "just my thoughts..."
"Why only the 300mA PSU worked for you, Jill, is explained by some *other* factor than the milliamp rating. That's what I can place a bet on. What it is, I can only guess."
2014-04-06 by Sami Jumppanen
Umm, now I'm becoming sure I'm misunderstanding you :D
Do it like the Finns: small-talk = less is more ;)
Just kidding.
Specs are of course ok. But it doesn't matter if it's 300 or 900 mA. It does matter if it's less than 300.
sami jumppanen / android sgs2
6.4.2014 9.01 kirjoitti "Jill Saphic" <jill_saphic@...>:
Hello Sami
