Archive for korgpolyex.
EX800 EPROM file corrupted in Files section ?
2013-06-26 by benoitdmx
Hello guys,
I started some investigations on the EX800 firmware, and I tried to disassemble the binary file located in the Files section (EX800 firmware)
As far as I can see, the file is corrupted : the first bytes are 06 B9 for address 0x0000 (the reset vector). And there are no instructions with 0x06 prefix in the 8085.
I will try to compare the file with the EPROM content in my EX800, but if somebody already made another dump and can compare it too...
Benoit
Re: [korgpolyex] EX800 EPROM file corrupted in Files section ?
2013-06-26 by Gordon JC Pearce
On Wed, Jun 26, 2013 at 12:35:48PM -0000, benoitdmx wrote:
> Hello guys,
> Benoit
Isn't the CPU little-endian, making that address $B906 and therefore quite firmly in the ROM map?
I know the EX800 image from the files section works because that's what I use in my Poly...
Gordonjcp MM0YEQ
2013-06-26 by Michael Hawkins
It is not corrupt.
06 B9 is mvi b, 0B9h
Mike
Sent: Wednesday, June 26, 2013 8:35 AM
Subject: [korgpolyex] EX800 EPROM file corrupted in Files section ?
Hello guys,
Benoit
Re: EX800 EPROM file corrupted in Files section ?
Ok thanks Mike
It means that my 8085 disassembler is... humm... (it reports this sequence as unknown instruction... like most of the RST vectors entries). I did not check in the datasheet to be honnest, just trusted the software
I will try another disassembler then (for those being interested : the problem I saw comes from DASMx. It worked perfectly to disassemble the 6303 code from my DSS1... but clearly not the case for the 8085)
Is there a 8085 disassembler you would recommend Mike ?
Benoit
--- In korgpolyex@yahoogroups.com, Michael Hawkins <korgpolyex800@...> wrote:
> It is not corrupt.
> Mike
> From: benoitdmx <benoit@...>
> Hello guys,
> Benoit
2013-06-27 by benoitdmx
Ok, I found what was wrong with DAMSx. The problem was between the chair and the computer....
I just declared vectors in place of RST entries at beginning of the symbol file. So DAMSx interprets the data at address 0x0000 as a jump to address 0x06B9...
In fact, RST are not vectors for the 8085, they are entry-points, and the symbol must be different in the table for DASMx.
I just updated my symbol table and now, the EPROM file is disassembled correctly.
Benoit
--- In korgpolyex@yahoogroups.com, "benoitdmx" <benoit@...> wrote:
> Ok thanks Mike
> Benoit
> --- In korgpolyex@yahoogroups.com, Michael Hawkins <korgpolyex800@> wrote:
> > It is not corrupt.
> > Mike
> > From: benoitdmx <benoit@>
> > Hello guys,
> > Benoit
Re: [korgpolyex] Re: EX800 EPROM file corrupted in Files section ?
2013-06-27 by Michael Hawkins
Check out my hawk800 sourceforge project. I just uploaded the disassembler I used back in 2007 and also provided the supporting files that will give you all of the disassembly labels and comments that I worked out back then.
Read the README.txt file.
https://sourceforge.net/projects/hawk800/files/Disassembly/
Mike
Sent: Wednesday, June 26, 2013 4:11 PM
Subject: [korgpolyex] Re: EX800 EPROM file corrupted in Files section ?
Ok thanks Mike
Benoit
> It is not corrupt.
> Mike
> Hello guys,
> Benoit
