Archive for korgpolyex.
New Member: (constant Load ERR.)
2013-06-17 by daveyray913
Hello All,
I've been a Korg Poly-800 mk1 owner since circa 1988. Traded in my first synth, a Casio CZ-1000 + $150, for the upgrade and it was well worth it. (on a side note: last week I had an impulse buy moment on eBay and picked up a CZ-1000 again. It's fun, but much thinner sounding than I remembered)
BACKSTORY (if interested):
My Poly has been through hell and back. It survived me pounding on it for years, a nephew once, unknown to me, took it from my closest at was pounding on as a toy for a month or two while I was in college, and it survived a house fire in 1992 where a thoughtful firefighter threw it out a window to save it and it was promptly stomped on accidentally by another fireman breaking some keys. It still worked but since then I've just used another midi controller to play it. I'm hoping to fix the keys soon too but I have another more pressing issue:
Sorry, I have a bad habit of making a short story long. I'll ge onto..
THE PROBLEM:
My Poly's been shelved for several years and now I'm hoping to dust it off and Mod it and also would LOVE to add it to my rig in my band BUT I'm trying to make sure it's 100% operational first. I browsed your topics and I found a few that talk about ERR/load issues but my problem seemed just different enough where I couldn't find a solution. As I'm sure many of you have experienced, dealing with the tape interface to load patches can be frustrating and I had it down to a science last time I had the Poly running ~ 5 years ago. But this time, no matter what I attempt, I cannot load from a tape/wav/audio source. It has given me a LOAD-ERR message over 1000X now no matter what levels or audio device, or with using new cables, different sources for the load files I try… I even got desperate and tried running the signal thru compressors and EQ etc. but still no dice. I can see that it's `hearing' the signal since the `LoAd' lights are twinkling and I'm getting the Err message at the end.
Good News: The synth itself is functioning. I put in new C's and I can manually type in and edit patches and they keep in memory.
Is this a known problem? Is there a fix like a bad resistor to replace? Or is there a better way to load patches on a Poly 800 mk1? I tried a sysex/midi patch dump but… it's doesn't seem to work through Ableton since the poly 800 mk1's midi is so rudimentary.
OR….Will the Hawk-800 installation solve my patch loading issue?
Thank you kindly!
Daveyray of Jesse's First Time
www.JFTROCKS.COM
Re: [korgpolyex] New Member: (constant Load ERR.)
2013-06-19 by Jason Adkins
Hiya,yep that is one interesting story,I'm amazed it is working at all,remind me not to buy your Poly800 if you ever  put it on ebay.!
Anyway,this may not be any help to ypu i have an EX-800 and I downloaded the .wav file of factory presets of the web,I connected the tape in to the internal audio out on my iBook using a mono jack lead with and using freeware program Audity (a freeware sound editor) played it into the EX-800 and I got the same error I then change the gain switch on back from low to high and it worked perfectly.
The other thing it maybe is your .wav file is corrupted,I can email my one if you want.
j
On 17 Jun 2013, at 15:12, daveyray913 wrote:
Hello All,
THE PROBLEM:
Thank you kindly!
www.JFTROCKS.COM
Re: New Member: (constant Load ERR.)
2013-06-19 by daveyray913
Thanks much for the reply, I was getting worried no one wanted to converse with me, or had no ideas to assist me.
Yea, I wouldn't be so cruel as to sell this gangly ol' beast to an unsuspecting customer. I may donate it to Michael if I wind up buying one that's more functional. Have my eye on one on EBay right now....but…
Sadly, I tried pretty much what you did to no avail. ( I even also use Audacity , nice little program, I use it often to digitally slow down songs I'm trying to learn to get the nuances.)
I have several copies of the original factory load from various sources. One's a digital copy I made from the original cassette I still have which worked last time I had the 'board out 5 years ago. I even tried user made patch sets people had posted...Oh and I'm fairly certain I did not use MKII loads by accident.
I can't be the only guy that has this issue. I've read many many forums of Poly800 users having trouble getting it to load patches but usually some sage advice on volume/gain and setting the switches correctly solves it. Unfortunately, I think my problem is hardware related on the poly itself. I've tried every combination of high/low + volume + gain + different wires ( mono/balanced/stereo/unbalanced) + crying a little and even bargaining with a crossroads demon. No luck.
My Tape/Load toggle switch is getting a little funky, If I bump the Poly it sometimes will leave the `load' screen back to `11P' and I have to switch it back and forth a couple times to get it to work again. So, for giggles, I'm going to try putting in new toggle switches on the back panel just to be sure that's not it. I'm taking trip to Radio 'Snack' tonight for parts.
I'm also installing a dedicated memory battery on board, SO I can at least manually load patches and not worry about losing them when the C batteries fail.
Cheers
Daveyray
> one if you want.
> j
> > Hello All,
> > THE PROBLEM:
> > Thank you kindly!
> > www.JFTROCKS.COM
Re: [korgpolyex] Re: New Member: (constant Load ERR.)
Sorry I meant Audacity not bloody Auidty idiot that I am.
Actually I think I used a  mini 3.5mm mono lead with a 6,3mm stereo converter on the EX-800 end.
I would try to use some contact cleaner on your Poly800 on the lo/high switch first before pulling it to bits,great thing about the EX-800 is it doesn't use batteries its psu only and internal battery (which is fun to replace) your Poly 800 might keep the data you have with all the batteries in it? Has your Poly 800 got an internal battery to? If i I can find one at a reasonable price I'd much rather have the Poly 800 MK11 purely because of the DDL.
Cheers
Daveyray
> one if you want.
> j
> > Hello All,
> > THE PROBLEM:
> > Thank you kindly!
> > www.JFTROCKS.COM
2013-06-19 by Sami Jumppanen
Hi Daveyray,
I only have EX and don't know about the problem, but I wanted to say you got a really good long story there! :)
If I would suspect something knowing nothing it's the tape load connector soldering that needs to be fixed. I've once soldered the MIDI in connector of Boss Dr-550 and rotary switch (umm not exactly related) of Alesis Microverb II. Well, the point is everything gets difficult when parts begin to disconnect.
If I could just find the schematics of EX... but we're talking about Poly, I recall there are schematics available right? I should take a look and see if there are weak links. I can't promise that immediately though.
Sami Jumppanen
http://samijum.pp.fi
- SGS2 -
17.6.2013 17.12 "daveyray913" <sinisterthewicked@...> kirjoitti:
Hello All,
THE PROBLEM:
Thank you kindly!
www.JFTROCKS.COM
Thanks much, I had it open and didn't SEE any solder breaks but I'll recheck with a voltmeter or try replacing the jacks all together while I'm already changing out the toggle switches.
And Yes, I 'm a bit verbose. I'll try to keep my posts shorter and more pithy.
At this point I'm seriously thinking of just snagging a functioning EX-800 or another poly800 on eBay to make my life easier.
--- In korgpolyex@yahoogroups.com, Sami Jumppanen <sami.jumppanen@...> wrote:
> Hi Daveyray,
> to disconnect.
> Sami Jumppanen
> - SGS2 -
> > Hello All,
> > THE PROBLEM:
> > Thank you kindly!
> > www.JFTROCKS.COM
2013-06-19 by Martin Ator
Try it the other way round first. Dump from the Poly-800 and see what you get. Then try and verify it. You may need to normalise it in software first. It doesn't matter that there's no patches
Sent: Wednesday, 19 June 2013, 18:02
Subject: Re: [korgpolyex] New Member: (constant Load ERR.)
Hi Daveyray,
Sami Jumppanen
- SGS2 -
Hello All,
THE PROBLEM:
Thank you kindly!
www.JFTROCKS.COM
" meant Audacity not bloody Auidty " No worries, I am the last person in the world to be judgmental over grammar/typos. I knew exactly what you meant.
Thanks for the advice, Silly me didn't think of simple
contact cleaner. I'll give it a shot and keep y'all posted.
And this is a first run Mk-1, no internal battery but it looks like an easy fix to add a cell, I have a lithium cell and holder coming from eBay I'll solder in.
Speaking of which, I'm eye-balling a MKII for circa $300 on eBay....might be a little steep for my budget since I already bought an Akai miniak, an old Casio cz-1000 and an M-audio Venom this year....wife will not be happy when a 4th 'board shows up at the door.
Cheers
> > now....but…
> > luck.
> > C batteries fail.
> > Cheers
> > Daveyray
> > --- In korgpolyex@yahoogroups.com, Jason Adkins <jason_ralf808@>
> > the
> > email my
> > > one if you want.
> > > j
> > > > Hello All,
> > well
> > on
> > closest
> > onto..
> > > > THE PROBLEM:
> > dust
> > band
> > but my
> > the
> > down
> > wav/
> > and
> > mk1?
> > > > Thank you kindly!
> > > > www.JFTROCKS.COM
That's a good plan. THX
> From: Sami Jumppanen <sami.jumppanen@...>
> Hi Daveyray,
> Sami Jumppanen
> - SGS2 -
> >Hello All,
> >THE PROBLEM:
> >Thank you kindly!
> >www.JFTROCKS.COM
2013-06-19 by Gordon JC Pearce
Didn't you say the keyboard was knackered? Why not just bung an EX800 ROM in and load them over MIDI?
Gordonjcp MM0YEQ
Ya, she's in rough shape, but I'm not quite ready to give up. After I cleaned it up this week and started fixing the broken keys... it doenst look TOO bad. The couple patches I manually programed are loud and clear and sound good...
What I really want is to MOD it, make it useful in my band as a gimmicky piece of nostalgia, but I'm nervous installing Hawk into a 'knackered' 'board as you put it. (I love your vernacular btw).
But I guess HAWK800 would fix the problem too...with it's much improved Midi Sysex? I could forget about the tape interface/lack of Mk1 sysex altogether.
Silly question: Where do I aquire an EX-800 ROM? & Wouldnt I lose Joystick control?
Decisions, decisions....
> Gordonjcp MM0YEQ
2013-06-19 by Michael Hawkins
There's a mod that you can do that puts an EX800 ROM "on top" of the original Poly ROM. And you use a switch to flip from one or the other ROM's. This allows you to keep all of your Poly-800 joystick goodness etc while also getting the sysex ability when you need it. You power off, flip the ROM select switch, power on, do your sysex. Then power off, flip the ROM select switch, power on, do your keyboard, joystick thing. Not a bad idea at all, for its time.
The biggest problem with fires is the awful damage that happens if electronic stuff is exposed to thick acrid smoke. Did your Poly get affected by the smoke or was it the fall from a great height that messed it up? If it's smoke damage then I would say it's a miracle the dang thing still works at all. And fixing smoke gunge covered PCB's and parts is a professional job unless you like dipping your hands in solvents and other carcinogenic stuff. Soap and water and a long drying time might be worth the trouble.
The tape switch problem you have is NOT the reason you can't get a tape dump to load properly. As long as you can get the thing into Tape mode (which you can) and it stays that way for the duration of your dump, then the switch is good enough. Get some de-oxit and most likely you'll find your tape switch will be fine after some de-oxit treatment.
The Poly-800 schematics (found in the download section of this group) are good enough for the EX-800. Especially with respect to the tape circuit section, they're identical.
Yes, the HAWK would fix your tape problem because the HAWK has no tape functions at all. They are all replaced with sysex and MIDI CC implementation. I do agree that you ought to try to stabilize your patient before you try to transplant a HAWK into it.
Your Poly is functioning which tells me it's not "knackered". Banged up a bit sure, who wouldn't be after a multistory throw by a ham fisted American firemen!
So I would say, give your patient some more TLC. Don't sweat the tape problem too much. And if you can make her reliable then maybe a HAWK brain transplant might be worthwhile.
Mike
Sent: Wednesday, June 19, 2013 3:30 PM
Subject: [korgpolyex] Re: New Member: (constant Load ERR.)
> Gordonjcp MM0YEQ
2013-06-20 by daveyray913
Luckily the Poly was in a 1/2 exposed basement studio. I don't think the smoke hit it too hard. It was tossed about 8' out a near ground level window, so it was more of a hard slide than a fall I'm guessing. (I didn't see, I was busy on the street trying to calm my hysterical mother) Then...it was kicked/stomped on by fireman I guess to get it out of the way(BTW: all we Americans are ham-fisted, that goes w/o saying :) ) It did get a little wet. Anything I had on the floor /leaning on a wall i.e.: a DX11, a drum machine, a couple amps, a few effects pedals, etc. were in a foot+ of water and trashed. I did my best to clean up the few items that survived the fire the next day.
Thanks for all the assistance. Nothing left now then to decide on which mod path to take once I have it fully operational. After everyone's assistance I guess I'm not bothering with the tape load function much longer, I'll make one more effort with the suggestions given, then move on. Besides, I'm still battling getting the keys fixed, and contacts cleaned etc. It will live again by golly!
I'll photo document my progress for posterity and keep anyone who's interested posted.
Thanks for all the assistance!
--- In korgpolyex@yahoogroups.com, Michael Hawkins <korgpolyex800@...> wrote:
> Mike
> From: daveyray913 <sinisterthewicked@...>
> > Gordonjcp MM0YEQ
2013-06-20 by Jason Adkins
Hysterical mother,Hysterical girlfriend take your pick..
Yeah I'd def want to see a big photo of a firemans boot on your Poly 800 then we could tell which bit might be broken.
The moral of this story is:-  don't burn your house down.
The stuff that got wet,should actually function once dryed out especially that DX11 which only got slightly wet,ok yiou might have to do some cleaning up ,contacts erc but should be ok I'd guess most of your stuff is DC ? If so they might work if dryed out.
> Mike
> > Gordonjcp MM0YEQ
Ha, are you getting cheeky with me mate? I may be misinterpreting.
Yea, I'm pretty certain it was my mother, not my girlfriend. Greek king of Thebes, Oedipus, I am not.
The gear on the floor was drown in black, sooty, very hot water for over 2 hours...it had no hope of functioning ever again, and besides the prolonged heat melted part of the DX11.
Trust me, I know dead when I see it. I do still have one other item that survived even though it melted a bit.. a Casio SK-1 …still works too.
It's pretty obvious which keys were broken; they were sticking up at Picasso-esque odd angles.
And besides, this all happened a long time ago, I just happen to still have my poly800 and recently have been feeling nostalgic enough to try and fix it.
"...And this is where I met the leprechaun... He told me to burn things."
> > fire the next day.
> > interested posted.
> > treatment.
> > > Mike
> > > From: daveyray913 <sinisterthewicked@>
> > > Â
> > Joystick control?
> > > > Gordonjcp MM0YEQ
2013-06-21 by Jason Adkins
no I didn't mean you fucked your mother I meant ALL women are Hysterical...
Regarding the SK1,Casio always makes great gear,I used to have one myself,i love the drum sounds in that (like i love the Vl-Tone) and the 4/6/8-bit sampling is interesting my first sampler then another home keyboard Yamaha VSS-100 I think (crap) then an Akai X7000 great but used bloody 2.8inch quickdisks as storage and had a stupid way of giving it 6 seperate out's,was a 13 pin din to 6 jacks,nightmare to solder up and kept needing repairing.
The Poly800 is worth bothering with,its real analogue not virtual and has as I have said a million times before you can tell the difference.
J
> > fire the next day.
> > interested posted.
> > treatment.
> > > Mike
> > > Â
> > Joystick control?
> > > > Gordonjcp MM0YEQ
Re: [korgpolyex] Re: P800 analog?
2013-06-21 by Daniel Forró
Poly 800 is real analog? Are you sure?
Daniel Forro
Ok it's not VCO but DCO ok I fucking realise that,I didn't want to buy the EX-800 actually I wanted a Roland JX8P but now silly money I bid £425 for one and i got outbid.
I know DCO's are not the same as VCO's but I can't afford a Minimoog although I have since bought a Minibrute.
Daniel Forro
2013-06-21 by Gordon JC Pearce
Minimoogs are shit anyway. You don't want one.
They've got crappy unstable oscillators and the filters are shite.
Gordonjcp MM0YEQ
2013-06-21 by daveyray913
" …didn't mean you fucked your mother" Ha! So glad I misinterpreted that.
You are right of course. I'm married to one of those `women' things. And they can be quite hysterical at times (no offense to any ladies on this forum).
If my Little Casio SK-1 wasn't in such rough shape, I'd consider circuit-bending that! It is a fun & cheap little toy, and it was my very 1st keyboard when I was 13-ish.
I started digging into the Poly last night. I found some very interesting things inside: A couple moth cocoons, a 5 cent nickel (now THAT could have cause serious short circuits), and a tiny round wad of duct tape. Why? From its shape I guess it was wadded up and put into a rubber boot of one of the key contacts that was no longer depressing far enough? I took it in to have the joystick repaired once; it had to be the service tech that did that, it wasn't me.
I think I can move the patient out of ICU and into the recovery ward. I did the isopropyl and cotton swab trick and got all the key contacts working again. I ordered 4 replacement keys and also fixed a crackling/misfiring ¼" output jack with a little solder.
I think it's almost time to order me a Hawk800 kit.
Exciting!
> Hi,
> Hysterical...
> J
> > works too.
> > things."
> > have to
> > think
> > ground
> > my
> > fisted,
> > had on
> > couple
> > > > fire the next day.
> > suggestions
> > who's
> > > > interested posted.
> > the
> > it.
> > sysex.
> > happens if
> > get
> > and a
> > get a
> > of
> > most
> > oxit
> > > > treatment.
> > no
> > CC
> > by a
> > maybe a
> > > > > Mike
> > > > > Â
> > into a
> > lack of
> > lose
> > > > Joystick control?
> > SO I
> > an
> > > > > > Gordonjcp MM0YEQ
2013-06-21 by Eanna Butler
Well done!
You're able to load patch banks now?
Exciting!
> Hi,
> Hysterical...
> J
> > works too.
> > things."
> > have to
> > think
> > ground
> > my
> > fisted,
> > had on
> > couple
> > > > fire the next day.
> > suggestions
> > who's
> > > > interested posted.
> > the
> > it.
> > sysex.
> > happens if
> > get
> > and a
> > get a
> > of
> > most
> > oxit
> > > > treatment.
> > no
> > CC
> > by a
> > maybe a
> > > > > Mike
> > > > > Â
> > into a
> > lack of
> > lose
> > > > Joystick control?
> > SO I
> > an
> > > > > > Gordonjcp MM0YEQ
EBu
Re: constant Load ERR.
Nope, 'tape' loading is still an issue. But I'm putting that on the backburner for now. I did buy new 1/8 jacks to solder in, but I have a feeling that may not be the problem. My mini voltmeter and a stripped wire 1/8 male plug tells me the signal path is valid from wires to board. The problem is more likely downstream, beyond the jack. But like I said, I stopped messing with that for now while the Poly is all dismantled on my kitchen/operating table.
I manually installed the first bank of original patches 11-18, and they are holding just fine. My battery and battery case just arrived in the mail last night. So I'll install direct board memory this weekend so I dont have to worry about C cells.
I did find one more problem... the rate/speed slider for the sequencer is not working well. Sad since, even tho the sequencer on it is very limited, its still alot of fun to mess with.
--- In korgpolyex@yahoogroups.com, Eanna Butler <eanna.butler@...> wrote:
> Well done!
> > forum).
> > wasn't me.
> > Exciting!
> > --- In korgpolyex@yahoogroups.com, Jason Adkins <jason_ralf808@> wrote:
> > > Hi,
> > > Hysterical...
> > > J
> > > > works too.
> > > > things."
> > > > have to
> > > > think
> > > > ground
> > > > my
> > > > fisted,
> > > > had on
> > > > couple
> > > > > > fire the next day.
> > > > suggestions
> > > > who's
> > > > > > interested posted.
> > > > the
> > > > it.
> > > > sysex.
> > > > happens if
> > > > get
> > > > and a
> > > > get a
> > > > of
> > > > most
> > > > oxit
> > > > > > treatment.
> > > > no
> > > > CC
> > > > by a
> > > > maybe a
> > > > > > > Mike
> > > > > > > Â
> > > > into a
> > > > lack of
> > > > lose
> > > > > > Joystick control?
> > > > SO I
> > > > an
> > > > > > > > Gordonjcp MM0YEQ
> EBu
Re: P800 analog?
2013-06-21 by KurtF
Digital = evil?
Luddites.
If the original acronym had been DTO for digitally tuned oscillator, would that have created as big of a bogeyman as makes some people's skin crawl today? I have heard a properly programmed Micron or Proteus 2000 sound like a Minimoog, an Odyssey, and an SEM,as well as producing some sounds none of those could attempt, such as the SID. The biggest limitation of any instrument is the musician using it.
> > Daniel Forro
> >> difference.
2013-06-21 by Sami Jumppanen
This is true! :)
> > > Daniel Forro
> > >> difference.
2013-06-22 by Jason Adkins
Minimoogs are shit? Thats a new one.
Leave them on for the first five minutes before using (until they warm up and get stable,like the reverse of the air-con in your motor) like my Minibrute and Monotribe.
J
Gordonjcp MM0YEQ
Bummer you got the thing working coz I will miss your stream of consciousness,because I thought I was the lyrical one on this group/
Exciting!
> Hi,
> Hysterical...
> J
> > works too.
> > things."
> > have to
> > think
> > ground
> > my
> > fisted,
> > had on
> > couple
> > > > fire the next day.
> > suggestions
> > who's
> > > > interested posted.
> > the
> > it.
> > sysex.
> > happens if
> > get
> > and a
> > get a
> > of
> > most
> > oxit
> > > > treatment.
> > no
> > CC
> > by a
> > maybe a
> > > > > Mike
> > > > > Â
> > into a
> > lack of
> > lose
> > > > Joystick control?
> > SO I
> > an
> > > > > > Gordonjcp MM0YEQ
Hmm Proteus,got a 1000 same as yours but only 2 card slots instead of your 4 ,nice machine better than my Jv1080  which has Techno and HipHop cards,bastard the Proteus cards are so rare and so expensive in the UK I want the Vintage,Pure Phatt or Ensoniq cards prob the Ensoniq one,all silly money though.
On 21 Jun 2013, at 17:56, KurtF wrote:
Digital = evil?
Luddites.
> > Daniel Forro
> >> difference.
Actually got grade 2 piano but not as good as used to be coz of 20 years using sequencers.
This is true! :)
> > > Daniel Forro
> > >> difference.
2013-06-22 by Gordon JC Pearce
They have horrible filters. There's no definition, just a big blurry squelch of noise. It's like smearing undercooked chocolate cake all over your mix.
Hate them.
Gordonjcp MM0YEQ
2013-06-22 by Peter van Beerendonk
Ah,
horrible filters. That must be the reason why all other synthmakers try to copy them. (except arturia of course)
Sent: Saturday, June 22, 2013 4:21 PM
Subject: Re: [korgpolyex] Re: P800 analog?
Hate them.
Gordonjcp MM0YEQ
Hi Peter,
I think Gordon,was probably trying to be funny,either that or he is an idiot. ;)
Oh yeah the Steiner-Parker filter on the Minibrute is brilliant,hence why I paid £409 for one.
I love the filter on the Monotribe too,I was thinking about buying the MS-20 remake too but the Minibrute looked more interesting.
On 22 Jun 2013, at 15:30, Peter van Beerendonk wrote:
Ah,
Hate them.
Gordonjcp MM0YEQ
2013-06-22 by Daniel Forró
That "legendary" ladder filter? It looks nice in schematics... I
didn't mind its sound, this is not the worse thing on Minimoog.
I had three, sold them all. Never understood why everybody wants them,
and why even it's copied in other instruments. Nice piece of furniture
and technology, for sure. But why everybody wants to sound like
thousands of other players? Minimoog has rather limited possibilities,
I was disappointed from its concept. No dedicated LFO, VCO sync,
limited audio FM, simple envelopes... Just boring. There are really
more interesting instruments, I still keep my Multimoog. It offers more.
Daniel Forro
> Hate them.
IMVHO just a myth and fashion.
Fortunately not all makers followed this route. I prefer Yamaha EX5, FS1R, VL1 or Technics WSA1. And there are even usable instruments with no filters - Yamaha FM, Casio PD...
Daniel Forro
On 22 Jun, 2013, at 11:30 PM, Peter van Beerendonk wrote:
Ah,
What about another possibility: he has just different opinion than you.
Daniel Forro
Hi Jason,
I excluded Arturia only because they only have the Minibrute as a hardware synth and luckily put the Steiner-Parker filter inside. (Like in the old EVI's and EWI's)
Very distinct sound, like it a lot.
There's more than enough Moog sounds available, so (except for marketing purposes) why build more of them ? Get the real thing, buy a Moog (or Realistic MG-1)
Now, back to noodling on the Model D ;-)
Cheers, Peter
Sent: Saturday, June 22, 2013 4:54 PM
Hi Peter,
Ah,
Hate them.
Gordonjcp MM0YEQ
Hello Daniel,
I do like the sound and filter, but I agree the Model D is limited, but has a very distinct sound and isn't boring afaik.
I use the Moog model D together with other mono's (Realistic MG-1, Teisco 110F, Yamaha CS-15 + modulized CS-5, Crumar DS-2 and Elektor Modular)
But we are hi-jacking this thread I believe.
So for the TS: Yes Poly800 is analog and highly modifiable !!
Cheers Peter
Sent: Saturday, June 22, 2013 5:12 PM
Daniel Forro
> Hate them.
Yeah the Model D is well limited,cough,I have used a Micromoog and a Rogue too but never a Multimoog so can't comment.
They used to sell the Realistic MG-1 here in the UK in Tandy/Radio Shack stores I think it got totally ignored.
Teisco 110F though was interesting,Kawai wasn't it,they have made some great stuff I used to have the SX240 and I still have the K4R,K1,K1M,K50e drum machine.
Can't say |I love Yamaha analogue synths too much or Italian synths apart from the Bit99,although I have never heard of the Elektor Modular guess kit built like a Maplin5600,Transcendent2000 etc
On 22 Jun 2013, at 16:37, Peter van Beerendonk wrote:
Hello Daniel,
Cheers Peter
Daniel Forro
> Hate them.
Hi Jason,
Teisco is Kawai, the sound of the 110F is kind of ARP like.
MG-1 is really nice, except for the fact that it has only 2 waveforms per osc. But 5 soundsources (2 osc's, noise, bell tone = ringmod, polyphony = sqw organ) and osc sync and s&h besides the normal options.
Elektor was/is an electronics magazine, the modular is indeed a kit (late 70's/early 80's) and rather bulky. But sounds ok.
Cheers Peter
Sent: Saturday, June 22, 2013 6:12 PM
Hello Daniel,
Cheers Peter
Daniel Forro
> Hate them.
why is your  txt so small?
On 22 Jun 2013, at 18:24, Peter van Beerendonk wrote:
Hi Jason,
Cheers Peter
Hello Daniel,
Cheers Peter
Daniel Forro
> Hate them.
Re: P800 analog?
2013-06-23 by k9k9dog
everyone was having fun yesterday then ;)
always good to see a synth myth being poked at.
the StudioElectronics SE1(-x) is a very nice piece
of gear, supposed to be a Mini clone, but with presets
and a nicer format. do not have, sadly, but remember
seeing one stupid cheap in a cashconverters in London
once when i was skint(i'm still skint)
> > Hello Daniel,
> > Modular)
> > Cheers Peter
> > ----- Original Message -----
> > From: Daniel Forró
> > more.
> > Daniel Forro
> > > Hate them.
2013-06-23 by Jason Adkins
Oh yes SE-1 Minimoog in a rack,my friend used to have a kenton midi retrofitted original Minimoog Model D,he swapped it and a Cheetah MS6 plus a Casio FZ1 for an ASR10 keyboard,I told him not to do it....
But nobody listen's to a word I say.
J
> > Hello Daniel,
> > Modular)
> > Cheers Peter
> > From: Daniel Forró
> > more.
> > Daniel Forro
> > > Hate them.
2013-06-23 by Gordon JC Pearce
> it....
The ASR10 is a beast of a machine. I quite liked the FZ1, and I've played about with an MS6 which is alright but has fairly horrible software.
Still not convinced by Minimoogs though. Maybe if they had a 12dB/octave filter setting...?
Gordonjcp MM0YEQ
Yeah the ASR10 is a beast,I used to have the EPS16+ so know how good they are.but would still rather have a midi Minimoog and an MS6 and an FZ-1.
I agree with you about the MS6,programmable from the front panel and multi-timbral unlike the Matrix-1000 (but a pain up the proverbial like said) ,which were similar price at time although I think the Matrix-1000 was about £100 more and only mono-timbral and needed an Atari/PC to program it.
I guess the Minimoog is love or hate,I love the Arp Odyssey more I used to have the single oscillator version the Axxe,its really funky,def what did Itchiban Scratch bassline,sorry a classic electro tune if you wondered what the hell I was on about. The Minibrute does a great impression of that bassline with compression.
J
> it....
Gordonjcp MM0YEQ
Re: P800 analog?
2013-06-24 by bimmerfan222
Seems anymore that the old analog gear just isnt worth the coin spent and all the headache of patch cords, midi cords, mixers, midi patch bay/switcher/routers and FX units all hooked up together in a maze of wiring.
I'm sure I'll get flamed for saying it, but the virtual instrument DAW's seem to be the way to go anymore for all my favorite sounds.
Don't get me wrong, I love my hardware gear. My HAWK 800 has a lot of value to me and I intend to keep it around, but I've about had it with this maze of wiring and conundrum of making everything work together.
I've got a pile of gear and it just sits there not being used since it's such a PITA to hook all of it up together and not take up an entire living room to do so.
I've decided I'm going to start liquidating some of my gear and head into the world of virtual synths. I've played around with a few good ones like Korg's MonoPoly and M1 softsynths.. I REALLY like the MonoPoly!
I recently also tried out Kontakt 5. Awesome sampler! Sure beats the hell outta getting scuzzied around with an Akai S2000! And it dont weigh 40 pounds and takes up 2 rack spaces(or half a tabletop)... along with the fat scsi cords, huge ass external CDROM and the Zip Drives to attach to it and have them taking up valuable space too.
Arturia has made a practically flawless rendition of a Jupiter 8. It sure beats spending thousands on some beast of a keyboard that takes up an area where a loveseat might go.
Like I said, dont get me wrong.. if I had it my way, I'd have all the classic synths on every wall in my house, if I could. But I dont have the coin, room, time or patience to own them all.
But I could fit quite a few of them inside a newer CPU'd PC. All of them easily tucked away with a mouse click..
I know.. it sounds so soulless. But after trying out for awhile, it has caught on with me.
It really has changed my outlook on gear. I no longer seem to have this insatiable desire to buy up old ass gear and then bang my head against it to get it to play nice with the rest of the gear.
Anymore I see a nice item for sale and think.. gee, it'd be nice to have that.. oh wait, I DO have that.. it's inside my PC!
Yes.. even the minimoog can be in there too.
Heck, Google gave us a free minimoog not too long ago for a day that came with a built in sequencer.
Times have changed so much since the 80's.. so very much.
-Blaine
> FZ-1.
> J
> > > it....
> > software.
> > Gordonjcp MM0YEQ
2013-06-24 by daveyray913
"stream of consciousness" is absolutely the kindest way anyone has ever told me I tend to prattle on :)
I'm not going anywhere. I'm growing fond of this forum and I still have lots of work to do on my poly800. Also being a man of modest electronics repair skills, I'll require much more advice I'm thinking.
Cheers
-Davey the Ham Fisted American
> > that.
> > on this forum).
> > Exciting!
> > wrote:
> > > Hi,
> > > Hysterical...
> > of
> > and
> > difference.
> > > J
> > for
> > besides
> > item
> > > > works too.
> > up at
> > > > things."
> > your Poly
> > > > have to
> > most of
> > > > think
> > > > ground
> > calm
> > > > my
> > fireman I
> > > > fisted,
> > > > had on
> > > > couple
> > survived the
> > > > > > fire the next day.
> > decide on
> > tape load
> > > > suggestions
> > keys
> > > > who's
> > > > > > interested posted.
> > top" of
> > or
> > > > the
> > joystick
> > need
> > > > it.
> > > > sysex.
> > > > happens if
> > Poly
> > > > get
> > that
> > miracle
> > covered
> > dipping your
> > > > and a
> > > > get a
> > into
> > duration
> > > > of
> > and
> > > > most
> > de-
> > > > oxit
> > > > > > treatment.
> > this
> > respect to
> > has
> > > > no
> > MIDI
> > > > CC
> > stabilize your
> > "knackered".
> > > > by a
> > sweat the
> > > > maybe a
> > > > > > > Mike
> > > > > > > Â
> > up.
> > as a
> > > > into a
> > btw).
> > much
> > > > lack of
> > > > lose
> > > > > > Joystick control?
> > <gordon@>
> > > > SO I
> > losing them
> > bung
> > > > an
> > > > > > > > Gordonjcp MM0YEQ
