sequencer problems
2013-04-05 by erik
<the problem I'm having is this: when I start the sequencer on (seemingly) any of the patches, it will run just fine for about 1-2 mins. and then it will make a "crash" noise and begins sequencing a high frequency.>
-I would check your power supply and also make sure nothing is close by to the Poly that might be causing a surge or magnetic impulse. I've seen exactly what you're seeing. Mostly, it might be power supply. Have you checked the internal power supply rails to make sure they are +5 and -5 volts? Mike-
<I am kind of new to tracing a circuit path on pcbs, as I have primarily been dealing with tube amps prior. I printed out the schematic to try to aid my pursuit but I'm still kind of unclear as to what voltages I should be seeing, and where I should be looking. I did take some readings around the area where power comes in, and I documented what I was getting from the areas that I was looking. The only place where I was able to get a -5 and +5 volt rating in a close proximity was on pins 2 and 8 of cn6a. I am not really sure where I should be looking exactly and what voltages i should be seeing where. I am still a bit novice in this area. If you could tell me where exactly the power supply rails are on the board, I think that might help me a little more. Thanks again.>
please healp!! ;)
please healp!! ;)
