Poly800 New Modification - HELP!!!
2003-05-22 by pinheadx
I got a mint Poly800 sometime ago and I need some tips to perform the mods I want.
In fact it´s already bloody red and I will add the moog slayer, the filter mode switch and add the EX eprom to use sysex...this last one is the one that makes me think about a deeper modification. To do this mod I´ll need to burn an eprom w/ the EX firmware I found on the web and put this over the P800´s eprom (excluding the leg 20)...this is the normal mod.
I´m thinking if it´s possible to do the same, but using a P800 MkII eprom, will it work? Doing this I´ll have the keyboard and the sysex at the same time, plus the delay. Someone could help me??? At least sending me the P800 MkII firmware or telling me were can I get this?
Cheers from Brazil,
RivetheadX
