Index last updated: 2026-03-31 23:23 UTC
Weird static soundwhen turning volume knob
2013-01-24 by danstetich
Hello everyone,
my Poly-800 has been acting up recently.
As I turn the volume knob, I hear a little bit of static (almost like a ground hum). It shifts from the left to right signal and disappears when it's on full volume. Of course this is a problem when recording because when I have a clear signal it's likely that the volume will be too loud resulting in distortion. Does anyone have an idea for a quick fix on this? What could it be?
Thanks in advance!
Dan
Re: Weird static sound when turning volume knob
2013-01-24 by Jill Saphic
IF you can hear the same noise through you "headphone out"
easy one usually! (ex: most of the time)
buy some "real" tuner cleaner, "without lube" like from EZstreet,
or blue shower, any of the expensive ones that don't melt
plastic components.
Dont get the cheap Radio Shack versions, or any of those
from the american hard ware stores. They will ruin your Poly-800 forever.
Then just spray it in the little holes on the volume pot, turn it from
OFF to FULL volume about a hundred times fairly quickly.
If you cant get the tuner cleaner, you can sometimes
get it to work for very short periods of time by just the hundred or so quick turns.
If you cant get inside, you can spray a little right on the metal post
under the plastic volume knob , and it will seep down into the pot.
takes awhile of doing it a few times to get enough to seep in.
OR, your pot is bad, and its a goner! LOL!!!
90% of the time it a little bit of dirt... typical "mature" keyboard stuff.
--- On Thu, 24/1/13, danstetich <danstetich@...> wrote:
Subject: [korgpolyex] Weird static soundwhen turning volume knob
Date: Thursday, 24 January, 2013, 12:29
Hello everyone,
Thanks in advance!
Dan
Re: [korgpolyex] Re: Weird static sound when turning volume knob
2013-01-24 by Daniel Stetich
Hi Jill,
Thanks for the input. I appreciate it. I'm located in Berlin, Germany. Any tips for getting tuner cleaner in Europe?
I will try turning the knob back and forth a lot. Hopefully that will fix it.
Best,
Daniel
plastic components.
Hello everyone,
Thanks in advance!
Dan
2013-01-24 by Michael Hawkins
You can turn that knob back for forth thousands of times and it won't fix it.
But deoxit will! http://www.caig.com/
Mike
Sent: Thursday, January 24, 2013 11:54 AM
Subject: Re: [korgpolyex] Re: Weird static sound when turning volume knob
Hi Jill,
Best,
Daniel
plastic components.
Hello everyone,
Thanks in advance!
Dan
RE: [korgpolyex] Re: Weird static sound when turning volume knob
2013-01-24 by backshall1
Yup, turning the knob with no cleaner in it can’t do anything but grind the dirt in deeper and possibly damage the pot. Deoxit is definitely the gold standard for low residue cleaners. Last time I looked, Radio Shack actually had a couple of Caig products, but they were tiny cans and were a lot more money than you would pay online. Unless you are in a big hurry and have a Radio Shack around the corner, shop around.
Don B.
From: korgpolyex@yahoogroups.com [mailto: korgpolyex@yahoogroups.com ] On Behalf Of Michael Hawkins
Sent: Thursday, January 24, 2013 11:58 AM
Mike
Hi Jill,
Thanks for the input. I appreciate it. I'm located in Berlin , Germany . Any tips for getting tuner cleaner in Europe ?
Best,
Daniel
plastic components.
Hello everyone,
Thanks in advance!
Dan
2013-01-27 by Jill Saphic
Now boys, did I say working the pot dry
would FIX it... lets see... NO! I didn't.
silly buggers!
I didn't say it would fix it Daniel,
but if you need it ASAP, as in, you are a
PRO keyboard player like me and need it onstage tonight,
working the potentiometer dry most definitely gets it
working for a limited time, and won't hurt it a bit,
That is true of any old stlyle pot like we have in our 800.
Its an old remedy from the days of CRT tele's and radios.
Unless the pot is DAMAGED, like champagne spilled
into it or something. My Father taught me this one 4 or 5 years ago.
But HIGH QUALITY tuner cleaner will fix it nicely & fast!
As I have already said.
Let me know if it helps...
--- On Thu, 24/1/13, backshall1 <backshall1@...> wrote:
Subject: RE: [korgpolyex] Re: Weird static sound when turning volume knob
Date: Thursday, 24 January, 2013, 18:01
Don B.
Mike
Hi Jill,
Best,
Daniel
plastic components.
Hello everyone,
Thanks in advance!
Dan
2013-01-27 by backshall1
Watch out for the “tuner” cleaners that have lubricants mixed in. They can be a quick fix and work great for a while but then they generally just gunk up the contacts and collect more dirt. You should be using a zero residue cleaner, which doesn’t leave any lubricant behind after it evaporates. Long-travel linear faders can benefit from a good fader lube but rotary pots generally do not.
Don B.
From: korgpolyex@yahoogroups.com [mailto: korgpolyex@yahoogroups.com ] On Behalf Of Jill Saphic
Sent: Sunday, January 27, 2013 12:14 AM
silly buggers!
Don B.
Mike
Hi Jill,
Best,
Daniel
plastic components.
Hello everyone,
Thanks in advance!
Dan
