Index last updated: 2026-03-31 01:36 UTC
HAWK-800 and VCF modulation
2012-10-09 by tim.tashpulatov
Hello all,
Smee again, fiddling with VCF modulation. Looking at parameters, I can see the VCF Modulation Group making use of two arbitrary LFOs. There is also a Resonance Modulation Group, again using an LFO.
Does the VCF Modulation Group mean the filter's cut off control? and how does using 2 LFOs work for that?
Regards
Tim
Re: [korgpolyex] HAWK-800 and VCF modulation
2012-10-09 by Michael Hawkins
Yes, VCF modulation group is for filter cut off.
Here's an example of using two LFO's with VCF cutoff.
Set up a patch as follows:
P1-41 to 20. VCF cut off set low.
P2-11 to 0. LFO1 slow.
P2-12 to 0. No delay on LFO1.
P2-13 to 1. LFO1 free running.
P2-21 to 8. LFO2 medium speed.
P2-12 to 0. No delay on LFO2.
P2-13 to 1. LFO2 free running.
P2-41 to 3. right hand sawtooth waveform
P2-42 to 1. use LFO1
P2-43 to 4. modulation level
P2-44 to 1. triangle waveform
P2-45 to 2. use LFO2
P2-46 to 3. modulation level
Now you will hear LFO1 (in sawtooth) slowly go from low to high VCF. But LFO2 will insert a small VCF "warble" as it also modules VCF faster.
Enjoy!
Mike
Sent: Tuesday, October 9, 2012 3:03 PM
Subject: [korgpolyex] HAWK-800 and VCF modulation
Hello all,
Regards
Tim
Re: HAWK-800 and VCF modulation
2012-10-10 by tim.tashpulatov
Mike, thanks!
Regards
Tim
--- In korgpolyex@yahoogroups.com, Michael Hawkins <korgpolyex800@...> wrote:
> Enjoy!
> Mike
> From: tim.tashpulatov <tim.tashpulatov@...>
> Â
> Hello all,
> Regards
> Tim
