now it;'s a question about sysex!
2012-08-11 by dpaulo2
Index last updated: 2026-03-31 01:36 UTC
2012-08-13 by Michael Hawkins
2012-08-13 by dpaulo2
--- In korgpolyex@yahoogroups.com, Michael Hawkins <korgpolyex800@...> wrote:
> You can send a global sysex message to change globals. But the sysex for that is a global bulk type message. There are no CC's or Sysex to change individual global parameters (I have just added that as a feature request to sourceforge).
> Yes, MIDI CC 21 allows control of the sequencer. Not sure why it wouldn't be working. I shall have to check that it is still functioning in the software, it should be.
> Mike
> From: dpaulo2 <dpaulo@...>
> To: korgpolyex@yahoogroups.com
> Sent: Saturday, August 11, 2012 12:10 PM
> Subject: [korgpolyex] now it;'s a question about sysex!
> Â
> Mike, hello again,
> my software editor is looking good, however I'd like to integrate controls for the sequencer also.
> So far I've used the "Quick Parameter Change" method to get communication for everything else, but I see I need to access one or two Global Parameters and also MIDI control no. 21. Alas I've found no way to do this, I guess it's via a sysex message, but so far all sysex messages I've tried have not registered on the synth.
> Hope you can help,
> Dan
> Mike
> Â
> Mike, hello again,
> Hope you can help,
> Dan
2012-08-14 by dpaulo2
> With MIDI CC 21, you just send the required data value for the specific command on MIDI CC 21. It's not an NRPN or RPN type CC.
> So you just send data on MIDI CC 21 and set the value according to the list of commands.
> 0=Start sequencer.
> 1=Stop sequencer.
> 2=Enter sequencer edit mode.
> 3=Sequencer edit step forward.
> 4=Sequencer edit step back.
> 5=Exit Sequencer edit mode.
> 6=Lock current sequence to disable editing.
> 7=Unlock current sequence to allow editing.
> 8=Mute local sequencer.
> 9=Un mute local sequencer.
> So, the message (in hex) would be:
> "Bx 15 yy" - where B means MIDI control change, x is the MIDI channel (0 to F corresponds to MIDI channels 1 thru 16), 15 is hex equivalent of 21 and yy is the desired command data value.
> Mike
> Sent: Monday, August 13, 2012 3:44 PM
> Subject: [korgpolyex] Re: now it;'s a question about sysex!
> Â
> Mike,
> I'm confused as on the Midi Implementation Chart many of the numbers duplicate those on the Parameter CC list. So I try CC21 for the sequencer and it comes up CC36 on the synth (which is Mk2 Effects Mod Freq - I have a Mk1).
> Surely I'm doing something wrong here?
> Dan
> > Mike
> > From: dpaulo2 <dpaulo@>
> > ÃÂ
> > Mike, hello again,
> > Hope you can help,
> > Dan
2012-08-14 by Michael Hawkins
> 0=Start sequencer.
> 1=Stop sequencer.
> Mike
> Â
> Mike,
> Dan
> > Mike
> > ÂÂ
> > Mike, hello again,
> > Hope you can help,
> > Dan
