If you have the later versions of the HAWK board, then there is in fact an unused latch available. However, I would have to rewrite some of the software to ensure that the software compatible with all versions of HAWK's (not something I want to do).
But, there are three completely unused latches on the HAWK board now, that just need to be brought out (with care).
I will certainly modify the HAWK board to bring them all out to a pin header.
I shall have a look at the board design and see if I can write up the mod's needed for you. Will take me a few weeks at least. So email me again if you don't hear from me.
Mike
Sent: Monday, January 30, 2012 12:23 AM
Subject: [korgpolyex] AtomaHawk'd MkII - voltage control trigger output needed
rather than continuing to rely on a Kenton box to generate analog triggers via MIDI, I'd like to ask if there's anywhere inside Poly-800 that one can find like a +5V signal that goes high when you trigger a new note.
If not, are there any unused latches of any sort on the Hawk board that could be addressed from the EG 3 routines?
This would certainly be a groovy addition to the "Stage Two" idea.
W Griffin
