Archive for korgpolyex.
NEWBIE is foundering here.
2010-05-25 by rodenthead
seems like this whole group is devoted to the incredably complex HAWK upgrades.
me, i would actually just like to get my 8800mk2 going,
i actually build high end studio gear for top studios world wide, i am NOT an idiot.
but, so far, the tape dump file comes up with an error message, no matter what level i run it at.
i have tried several versions of SOUNDQUEST midiquest, to no avail.
i cant find any 800 specific file for thier program, and trying to send a generic sample dump of the original factory patches got me exactly no where.
now, i have done the two main mods, they work fine...no probs there.
I can of course hand program the thing, but it might have helped to have a plain text list of some original settings from some of the better patches from the stock setup..
there is an XLS file, which when viewed as plain text, seems to have the data, but its unreadable without having msWORD, and EXCELL installed in your system.
so, two questions...can anyone convert the XLS file to plain text easily? or even a screen cap of SOME of the better presets would be great.
second, is the WAV file corrupt or something? i get half way through and it goes to error message and stops
i have tried maybe two dozen settings, including the -5db factory setting and its surrounding area.
i have also tried turning off the sequencer, just in case THAT was the corrupt part.
probably you guys want nothing to do with me, i have to admit, i have no idea why anyone would spend endless hours writing code to redo this synth, with a difficult mod, where i know from experience, the average guy is going to have more than a few problems implementing the thing, without destroying thier synths..(i sell a dead simple high end mic pre kit, have for years, and i cant believe people cant accomplish a basic gain control in a feedback loop, maybe 8 simple parts total and we are talking resistors, pots, and caps here.
i was originally going to use my 800 as a simple midi controller, with a behringer knob and fader midi controller to run in the box synths, which in my experience, if you run em through tube stages, germainum compressors, can sound pretty frigin real sounding.
(no offence to you guys intended...anyone want a built theremin which outputs CV/GATE and TRIGGER? great fun for running analog synths.
also, if i knew more about what did what on this schematic, i would likely be able to design some things on the analog side, that you guys havent thought of yet.
(using a harmonic which tracks another harmonic to run a ring mod, lets you dial up some pretty intereresting ring mod tones, but they TRACK musically, in stead of beimg more of a musical novelty.
i also make LESLIES, very simple stuff, if you use an lFO overlayed with your foot pedal speed control, you get constant accelleration and braking in addition to the basic leslie function.
try flicking the switch on a hammond to simulate that, you will hesr the nicest leslie yo have ever heard.
i also make a butt kicking tube stage, which would make your synths just SING...
as well as a burns buzzaround which outdoes all the current clones out there.
SO, help me out, i will add something interesting to this forum.
or leave me to program my way out of this manually, and i will back out quietly.
cheers...PAT
Re: [korgpolyex] NEWBIE is foundering here.
2010-05-26 by Michael Hawkins
Pat,
I deleted your audio help file because it needs to be discussed, then formatted appropriately, before it becomes part of the documentation.
Feel free to discuss the issues you had and we'll put our two cents worth in to help.
If you're using MS Windows then MIDI-OX is a simple way to get sysex into your MK2. Depending on how cheap your USB midi interface is, you might have problems but MIDI-OX generally works OK with most MIDI interfaces.
LINUX - amidi is built in to most distributions.
I think that you will find that there are many previous discussions (with plenty of hints and tips) regarding audio upload and download problems. Suggest you do some searching in the list archives.
Mike
Sent: Mon, May 24, 2010 11:06:33 PM
Subject: [korgpolyex] NEWBIE is foundering here.
cheers...PAT
Re: NEWBIE is foundering here.
2010-05-26 by narfman96
I uploaded a jpeg of the xls patch sheet. It's rather a big file because of the res needed to view it. This will get you started.
Sending sysex is the best way for the MarkII. Midiquest is a pain with the Poly-800's. Works with some not with others.
Everyone is welcome here! I know the Hawk-800 dominates discussion but there are many of these synths that have been brought back from the dead by the discussions here. Lots of mods too.
Do you have a website detailing your DIY toys? As you may have noticed many of the members are quite proficient with building and modding our own gear.
Fran
--- In korgpolyex@yahoogroups.com, Michael Hawkins <korgpolyex800@...> wrote:
> Pat,
> Mike
> From: rodenthead <rodenthead@...>
> cheers...PAT
2010-05-26 by Gordon JC Pearce
Openoffice will read it. I haven't got OOo installed but I could fire
in on and convert the patch sheet to .csv if you'd prefer.
Gordon MM0YEQ
RE: [korgpolyex] NEWBIE is foundering here.
2010-05-26 by backshall1 (dsl)
I too have had a Poly-800 that would never show "Good" after loading. At lower levels, it would just seem to keep waiting, but bump it up anywhere above that and you get Err even though the memory seems to have all the patches loaded. I figured it was because of the coarse volume steps on the little Sony CD Walkman I was using to play the file. I always meant to tweak the level of the file a tiny bit in an audio editor but never got around to it, and I sold that Poly-800.
According to the manual, you will get Err at low levels and at high levels:
High level - Err indicated
Good level - Good indicated
Low level - Err indicated
Very low - signal ignored
So, the first level where you see Err is probably a bit low, and up one more notch from there should be good.
If you want to read xls files, I would suggest downloading the free Open Office suite. Open Office Math can open Excell files.
Don B.
From: korgpolyex@yahoogroups.com [mailto:korgpolyex@yahoogroups.com] On Behalf Of rodenthead
Sent: Monday, May 24, 2010 11:07 PM
cheers...PAT
2010-05-26 by Wayne
OpenOffice will view it as well as the free viewer that Microsoft has for download.
--- On Wed, 5/26/10, Gordon JC Pearce <gordon@...> wrote:
Subject: Re: [korgpolyex] NEWBIE is foundering here.
Date: Wednesday, May 26, 2010, 2:48 AM
Gordon MM0YEQ
2010-05-27 by zoinky420
I dumped mine through a headphone jack from a cable that split to left and right, and I found I had to leave the headphone plug halfway plugged in in order for it to get to the Poly800. I'm not exactly sure why, I thought it would play either out of the right or the left with the headphone plug plugged in all the way into the jack, but nope, the headphone jack has to be plugged in only halfway to work.
--- In korgpolyex@yahoogroups.com, "backshall1 \(dsl\)" <backshall1@...> wrote:
> Don B.
> _____
> upgrades.
> an idiot.
> system.
> corrupt part.
> caps here.
> thought of yet.
> SING...
> there.
> quietly.
> cheers...PAT
HAWK-800 Sysex single patch dump and send
2010-05-27 by Michael Hawkins
I recently realized that the sysex single patch dump send and receive functions are extremely inefficient.
They are this way because I send each parameter value (11-88 x 2) as two MIDI data bytes. But since the maximum value for any parameter value is 127 or lower, there is no need to send the data values as two MIDI data bytes.
So I am thinking about changing the code to use single data bytes instead. However, I fear that some of you may have done quite a bit of work with writing templates based around the two byte format.
How many of you would be very inconvenienced by me making this change?
Mike
Re: HAWK-800 Sysex single patch dump and send
2010-05-27 by narfman96
Will the bank dumps still work properly? I have singles saved but if I could load the bank and then dump each single again that wouldn't be a big deal. Would it be a pain to read both but save the new as single byte data. Because the patches are so small they dump to midi-ox in a heartbeat. Dump a Kawai K11/Gmega sometime and go make some coffee. Or send an Alesis 8mb Soundbridge image thru the MAC port and wait an hour and seventeen minutes. On my Alesis QS6 I have to be there at the end to cancel the last byte or it overwrites the first data block rendering the card as unusable. Hmmmph!
One more thought... Will this change the dump size or only affect the transmission of the data?
Fran
> Mike
Re: [korgpolyex] Re: HAWK-800 Sysex single patch dump and send
2010-05-29 by Michael Hawkins
Yes, I think what I will do is just implement new patch dump and send commands and keep the existing ones too.
Keep everything backward compatible!
Yes, the size of the patch dump will drop almost in half.
The bulk dump commands also need the same treatment.
But for now, I might just hold off and leave them as is since you seem happy with how they work now.
Mike
Sent: Thu, May 27, 2010 7:24:07 PM
Subject: [korgpolyex] Re: HAWK-800 Sysex single patch dump and send
Fran
> Mike
Re: [korgpolyex] Re: NEWBIE is foundering here.
2010-06-06 by Nick
Guys, me and my cousin Critterbug, his son Jimmy or Junebug, and his woman Fanny circuit bent mine, and we've been playin around with my poly.  Let me just say as we say here in kentucky, It'll blow the hose of the wall!
--- On Thu, 5/27/10, zoinky420 <zoinky420@...> wrote:
Subject: [korgpolyex] Re: NEWBIE is foundering here.
Date: Thursday, May 27, 2010, 5:50 AM
> Don B.
> _____
> upgrades.
> an idiot.
> system.
> corrupt part.
> caps here.
> thought of yet.
> SING...
> there.
> quietly.
> cheers...PAT
