Index last updated: 2026-04-05 20:10 UTC
Correct components & wiring for Moog Slayer mod?
2008-04-25 by alyerpal
Hi all,
I just picked up a Poly-800 for $100 that already seems to have the mod done - there are
two (knobless) pots above the joystick that seem to control res & cutoff.  They're both really
sticky and tough to turn, so I'm gonna open 'er up this weekend & use some de-oxit.
While I've got the hood open I'd like to do two things:
1) Make sure the job was done correctly, and..
2) Add the "patch values vs. knobs" switch.
Regarding point #1 above, I've checked out Olaf's photos and have a few Qs:
There are two diagrams, called schematic & MoogSlayer.  They show different wiring in each
& different values for the RES pot (50k vs. 10k).  Which is correct?
Regarding point #2, I'm not sure what value resistors to use here, since I bought the synth
with the mod already done, hence no VR2 & VR5 to check.  Any suggestions?
Thanks in advance for any help.
-Alex-
Re: Correct components & wiring for Moog Slayer mod?
2008-04-26 by funkymonkeypeter
Of the two schematics provided by Olaf you probably want to follow the
"moog slayer" one.  The other one simply duplicated the factory trim
pots to the front of the board, while maintaining the option of
switching back to the factory settings.
Each Poly 800 will have a slightly different Ohm setting on those pots
(I think mine were about 2.7k and 35k).  If the Poly you have has had
those pots pulled, then you can't test the pots for their factory
settings.  Your best bet would be to put small trim pots in place of
the resistors in Olaf's diagram.  That way you can still calibrate the
board to reasonable settings by ear when in "factory" and go all
wackadoo with the external pots when switched to them.
When I did mine I left the factory trim pots on the board so if i ever
get an osciliscope for a day or two I can calibrate them as per the
service notes.
--- In korgpolyex@yahoogroups.com, "alyerpal" <alyerpal@...> wrote:
> Hi all,
use some de-oxit.
few Qs:
suggestions?
> -Alex-
Re: [korgpolyex] Correct components & wiring for Moog Slayer mod?
2008-04-27 by David Mochen
Hi
Use the Moog Slayer scheme. Results are worth it.
Dave
Sent: Friday, April 25, 2008 6:34 PM
Subject: [korgpolyex] Correct components & wiring for Moog Slayer mod?
Hi all,
-Alex-
