Thanks for that Summa,
I will make sure I follow the GM2 MIDI spec from this point forward.
Just think of it, the EX800 will actually be GM2 compatible!
Also, I just fixed the modulation generator which had gone awry after
I made the switch to the new EEPROM code. When you set the frequency
of the MG, the CPU does a lookup into a table of values that are used
to determine the actual cycle rate. Only problem is, the lookup code
could not work across a boundary larger than 256 (8 bits) and when I
relocated the code, what do you think happened but that the table
ended up straddled across an 8 bit boundary (by amazing chance - I
should buy a lottery ticket). This caused the MG to go up and down in
cycles instead of smoothly speeding up as the MG value went up. I
relocated the table back inside an 8 bit boundary and the MG is fixed.
So now I retested my MG controller and it works great.
So we now have three fully functioning controllers that the original
EX800 never had.
Mike.
--- In korgpolyex@yahoogroups.com, "Summa" <flotorian@...> wrote:
> When it comes to the controller numbers, why not using midi standards
> #74 for cutoff and #71 for resonance
> like most of the major companies (Yamaha, Roland, Korg) do and most
> of the controller keyboards having a predefined setting for...
> http://www.midi.org/about-midi/gm/gm2_spec.shtml
> ...Summa
> On 6 Jul 2007 at 1:56, korgpolyex800 wrote:
> > Hi all,
> > Well, today I created to new MIDI controllers for the EX800.
> > Now you can control VCF cutoff and VCF resonance via MIDI controllers
> > 3 and 4.
> > So that's another two new REAL features deployed in the new software.
> > I've also implemented a modulation frequency controller on 5 but I
> > didn't quite get it working right so I can't claim total success on
> > that one - yet.
> > But two and half controllers in one day is good enough for me.
> > Would anyone like to see a youtube video demonstrating the new
features?
> > Have a great weekend all.
> > Mike.
> CZ/VZ mailing list : http://groups.yahoo.com/group/CZsynth
> FMHeaven mailing list : http://groups.yahoo.com/group/fmheaven/
> FS1R mailing list : http://www.ampfea.org/mailman/listinfo/fss-list
> Vokator mailing list : http://groups.yahoo.com/group/vokator
> http://www.summasounds.de/
