Re: [korgpolyex] Re: Poly 800 help!
2006-05-31 by David Mochen
Yes, go that way. Unfortunately I havent got any pix from that
repair but I can tell you it works. YEs, by filling the space around the spring,
you'll be creating a tight unit that will prevent the tab from unglueing. Just
make sure to have a "healthy" key around so as to compare and be sure the epoxi
doesnt go over. should that happen, you can always remove it with a cutter or
something similar. Of course, the "free" part of the spring, i.e. the one that
proturudes from the key, shouldnt be glued at all. Just the part that sits IN
the key.
best luck!
Dave
----- Original Message -----From: Philip LindeSent: Sunday, June 04, 2006 2:15 PMSubject: [korgpolyex] Re: Poly 800 help!Wow, thank you!
Yes, it was the tabs that broke off. I found the pieces and I will try
gluing them together tomorrow.
Just making sure I get this straight: I should fill the space around
the spring with epoxi so it can't wiggle from side to side?
Thanking you again for the helpful information,
Philip
--- In korgpolyex@yahoogroups.com, "Dave Bowman" wrote:
> Hi Philip,
> Don't despair so quickly. I've had a similar problem myself and fixed
> it.
> As long as you still have the broken bits you're not lost
> altoghether. I assume the broken parts are those tiny tabs that fit
> into the pair of holes that the metal keyboard chassis has per key.
> If that happens to be true, do the following: glue the tabs --
> provided they still lodge into the remaining part of the key-- with
> some cyanoacrylate. ONce it's dry, put the spring in place. THen fill
> the space surrounding the spring with epoxi adhesive, taking care not
> to let the glue go over the void space between the two tabs. Take an
> unbroken key and figure out by comparing.
> ONce the epoxi is dry, you'll have the spring fixed, which is not bad
> since anyway that's the way it should be. The epoxi and spring will
> form a tight bounding unit, so the broken tabs or latches will have
> enough resistance for the task required. Just stick the key carefully
> in place and that's all. It worked for me and so it should work for
> you. BTW I had other issues with my keys, such as broken keys at the
> playing surface and breaking of the tiny tab located under the keys
> that prevents them from going upwards beyond the normal level. I
> succedeed in fixing those problemas as well.
> Best,
> David
