Index last updated: 2026-04-28 23:27 UTC
different pots for filter mod
2006-02-24 by devetron
Hey Poly 800 fans. I did the standard (non-moog slayer) filter cutoff
and resonance mod to my 800 and am happy with the results, but the
range of effect of the pots is not ideal. I used pots of the same
values as the trimmers that the pots replaced (100K for the cutoff and
10K for the resonance) as advised by this german page (
http://www.msc175.de/projekte/poly800/ ). They only seem to have
effect at the very top end of their movement. Anybody out there have
better luck with different pot values? Would you mind sharing them
with me? Thanks!
Re: different pots for filter mod
2006-02-26 by narfman96
Devetron,
The values for the pots are most likely correct it appears as thought
the tapers are wrong. I apologize if this is review but there are 3
kinds of tapers that control how the resistance changes as the pot is
moved. Linear taper has the same gain change from start to finish.
Audio taper starts out with very little gain and really cranks it in
for the last little bit. (This sounds like the problem you described.)
Reverse audio taper starts out fast with very little change at the end
of its travel. Try getting the pot that will reverse whatever taper
your using now and the filters will most likely exhibit the response
you're looking for. Also double check the 3 connections on the pot
switching the leads around can cause this too. E-mail me offline if
you're still having problems.
Narfman
and
> with me? Thanks!
Re: [korgpolyex] Re: different pots for filter mod
2006-03-01 by Epiik Soul
I found that the amount of the effect was insufficient usin the standard (non-powered) mod with the majority of effect at the end of the knobs travel using both audio and linear tapered pots.
Juice that filter! Perform the whole slayer mod. You are already 99% there. It's well worth it. The non powered mod is a waste of time IMHO.
narfman96 wrote:
Devetron,
Narfman
and
> with me? Thanks!
Yahoo! Mail
Bring photos to life! New PhotoMail makes sharing a breeze.
