emulatorII-list
Archive for emulatorII-list.
Index last updated: 2026-03-30 01:09 UTC
Debug EPROM - Device Type
2012-05-01 by guitar5l50
Hey Fellas,
I am going the EALnet route to get a debug EPROM flashed.
I sent out an initial email with the attached .bin file to EALnet regarding the EPROM flash.
Now Doug at EAL net is asking what the device type is so that they can source a proper chip for the job.
>>Do you know what the device type number of the chip is?
>>Thanks,
>>Doug
Following the step list that was recently posted, I believe this will help me get my EII rev 1 off the ground.
Thanks. I can't wait to Emulate!
Re: [emulatorII-list] Debug EPROM - Device Type
2012-05-01 by Rish
Doug
�   �I think I have these on hand, I will chk.
Rish
Life is like MIDI, your either IN, OUT or THRU.
On May 1, 2012, at 2:37 PM, "guitar5l50" <guitar5l50@...> wrote:
Hey Fellas,
>>Thanks,
>>Doug
2012-05-01 by Robert Van Kuran
Great news.
By the way my name is Robert.
Thanks for checking it's a great help.
-RVK
On May 1, 2012, at 1:04 PM, Rish <rish@...> wrote:
Doug
� � �I think I have these on hand, I will chk.
Rish
Hey Fellas,
>>Thanks,
>>Doug
2012-05-02 by Robert Van Kuran
I'm not sure. The manual lists IC28 as the main eprom. They call it a 2764 Eprom But on the chip is a label that says E2 Scanner 2.1. And it doesn't look like I can read whatever is written directly on the chip itself.
Can anyone please confirm the device type number needed for the main EPROM for the debug ROM to be flashed?
Thanks for the help.
Doug
Rish
On May 1, 2012, at 2:37 PM, "guitar5l50" <guitar5l50@yahoo.com> wrote:
Hey Fellas,
>>Thanks,
>>Doug
2012-05-02 by Rish
Yes It's a 2764, not a 27C64.
Rish
Doug
Rish
Hey Fellas,
>>Thanks,
>>Doug
2012-05-02 by Rish
Is the test Rom the same as the debug Rom?
Rish
Doug
Rish
Hey Fellas,
>>Thanks,
>>Doug
2012-05-02 by Do It Yourself Synth
2764-25 should be fine. The 25 is for the access time.
Rish
Re: Debug EPROM - Device Type
2012-05-02 by guitar5l50
After drilling down the text file in the EPROM Binaries folder of the files section, the info is clearly stated there.
Doug at EALnet is saving the day. I just ordered 3 EPROM chips.
1 for the Main 2.1 upgrade, 1 for the Scanner 3.1 upgrade, and 1 for the Debug. Each ROM programmed on 2764 chips.
My rev.1 with Dual drives and 512k memory has Scanner 2.1 from the factory. I assume that I will have no catch 22 situation just dropping in and updating the Main and Scanner EPROM with the new chips. If anyone can confirm the upgrade process, is it that simple?
Thanks to the info in the text file I'm closer to sleuthing out the issues with my rev.1 EII this week than I have been in almost two years running now. Redoing the PSU now and then on to the Debug procedure using the Debug EPROM.
This forum rocks:)
Can't wait to Emulate!
> Rish
> >> Doug
> >> Rish
> >>> Hey Fellas,
> >>> >>Thanks,
> >>> >>Doug
Re: [emulatorII-list] Re: Debug EPROM - Device Type
2012-05-02 by Rish
How much did he charge you for the EPROMs?
Rish
This forum rocks:)
> Rish
> > On May 1, 2012, at 1:04 PM, Rish wrote:
> >> Doug
> >> Rish
>; >> Life is like MIDI, your either IN, OUT or THRU.
> >> On May 1, 2012, at 2:37 PM, "guitar5l50" wrote:
> >>> Hey Fellas,
> >>> >>Thanks,
> >>> >>Doug
> >;>> Thanks. I can't wait to Emulate!
Very reasonable. just email Doug for a quote and he will get back with as soon as he can. In my case it was very fast.
Doug rocks.
Rish
This forum rocks:)
> Rish
> >> Doug
> >> Rish
> >>> Hey Fellas,
> >>> >>Thanks,
> >>> >>Doug
