Emulator Archive states some info here:
http://www.emulatorarchive.com/Archives/Samplers/E2Overview/E2Floppy/e2floppy.html
Anyone know if the Shugart SA455 of the same series works? The only difference I can find is that the 455 has a 0.5 MB capacity whereas the 465 has 1.0 MB.
--- In emulatorII-list@yahoogroups.com, "WT" <waveterm@...> wrote:
> Ok thanks.
> but the Teac works as a replacement with no modifications needed other than
> driveselect ?
> WT
> From: "emulator_island" <mothrecords@...>
> To: <emulatorII-list@yahoogroups.com>
> Sent: Wednesday, February 03, 2010 11:48 PM
> Subject: Re: [emulatorII-list] Re: Just joined the group and considering
> buying a E-II...
> the original drives are Shugart SA465-3AA (same number for "full height"
> drive as well)
> cheers, emulator_island
> --- On Wed, 2/3/10, WT <waveterm@...> wrote:
> From: WT <waveterm@...>
> buying a E-II...
> To: emulatorII-list@yahoogroups.com
> Date: Wednesday, February 3, 2010, 1:49 PM
> What drive is the original E2 drive ?
> Teac FD 55GFR are available on ebay.
> WT
> From: "emulator_island" <mothrecords@ yahoo.com>
> To: <emulatorII-list@ yahoogroups. com>
> Sent: Wednesday, February 03, 2010 9:09 PM
> Subject: Re: [emulatorII- list] Re: Just joined the group and considering
> buying a E-II...
> ok, so after some more testing of drives, I have a TEAC FD-55GFR (in a
> lovely tan color!) as an available parts drive. The only difference is the
> original EII drives have a set-screw to hold the lever in place. The
> FD-55GFR lever simply slides on/off (lever shaft is "half-moon" style). You
> are more than welcome to the part if needed..
> --- On Fri, 1/29/10, Gil <gilwe@hotmail. com> wrote:
> From: Gil <gilwe@hotmail. com>
> Subject: [emulatorII- list] Re: Just joined the group and considering buying
> a E-II...
> To: emulatorII-list@ yahoogroups. com
> Date: Friday, January 29, 2010, 1:13 PM
> OK friends, thanks for your "warm" welcome and assistance.
> I had quite many synths running under my hand, as a player and electrician
> (fixed and restored quite many ones so far), but I always wanted this E-II
> monster, so here it is ;)
> Here goes my first tip to the Emulator craziness community :P
> Once I opened the monster up I realized that like many other synths, it uses
> quite many tantalum caps. My first job would be replacing them all, as they
> tend to die by burning themselves out and shorting out circuits. So - first
> thing to do !
> emulator_island, I'd love to get the lever for my "borken" drive if
> possible. I got some synth parts if you need anything as well ;)
> --- In emulatorII-list@ yahoogroups. com, emulator_island <mothrecords@ ...>
> wrote:
> > welcome to the Emulator's mysterious charm.. I remember my first E2
> > purchase.. $90 for 2 of them including 200+ disks, happiest day of my life
> > really.. I learned alot from those two fixer-uppers. . this was many years
> > ago.. in today's E2 market your purchase is very fortunate ..the E2 gods
> > were certainly on your side! ..before you know it you will be a pro w/a
> > "little" help from some good friends here of course.. take much caution if
> > you are doing the cap replacement yourself, as it is extremely !! high
> > voltage in there !! ..though I couldn't think of a better way to "go"
> > (Death By Emulator)..Ã a strong E2 heart is always beneficial, and should
> > keep your E2 healthy for 2010 and beyond.. also, make sure to check all 8
> > outs to see if your key problem is not a possible voice chip failure.. if
> > it is a key contact problem it may work
> > itself out since it seems your E2 has not been used in quite some time..
> > I would refrain from using any solvents to clean contacts, and simply dry
> > brush the dust bits if any.. have you thought about a 3.5" replacement kit
> > from Route66 for your bottom drive? I may have a bad drive around here
> > available for parts if a lever is needed..
> > --- On Fri, 1/29/10, Gil <gilwe@> wrote:
> > From: Gil <gilwe@>
> > buying a E-II...
> > Date: Friday, January 29, 2010, 9:11 AM
> > Ã
> > Thanks !
> > OK so I opened it up, took a few connectors out and in - and viola ! it
> > works !!
> > I could load and play a few disks so far. I found 3 keys which doesn't
> > respond. I guess this monster will need some service and refurbishment. I
> > might go and replace some caps in the power supply and in few other
> > places.
> > Does anyone know which type of keys are these ? I heard they are the same
> > as the Kawai K1... Do they match the keys of other synths ?
> > The lock handle of the bottom drive is missing as well... Which type of
> > drive should I look for ?
> > --- In emulatorII-list@ yahoogroups. com, "hexafuzz" <gclip@> wrote:
> > > --- In emulatorII-list@ yahoogroups. com, "Gil" <gilwe@> wrote:
> > > > Now we need to get it work :)
> > > Just to further clarify what has already been said: When powered on with
> > > a latched disk in either drive, the E-II should boot on its own. Top or
> > > bottom drive makes no difference; it should locate and auto-boot from
> > > either one on a dual floppy E-II.
> > > When powered on -without- a disk in the drives, the display message
> > > should quickly change from "Boot in Progress" to "Insert Diskette", and
> > > both drive status LEDs should begin flashing in an alternate pattern. If
> > > your display message doesnt change, and your drive LEDs never get lit,
> > > it may not be seeing the drives.
> > > If you are knowledgeable working on electronics (dont get zapped!), do
> > > as Elm suggested: Inspect, remove, and clean all floppy drive data &
> > > power cable connections (Deoxit and q-tips may help). Then hit the
> > > drives with compressed air to remove any built up dust or debris.
> > > Reconnect everything and look for improved/changed behavior.
> > > PS: Whenever the E-II is transported, remember to latch scrap disks in
> > > both drives to avoid damage.
> > [Non-text portions of this message have been removed]
