Elektron Musical Instruments
Index last updated: 2026-04-28 23:22 UTC
Dead elektron
Dead elektron
2004-10-17 by davidcliffordbrown
My elektron has died.  The transformer has been checked and is OK.  Is there
any easy button to press/start up method to get the MD going or do I have to
contact local repairman in san francisco US.
Thanks in advance
David
Re: Dead elektron
2004-10-22 by jderouchie
david,
when did you get it your MD cause mine did the same thing almost a
year ago, i had to send it to sweden to have it come back with all
new guts and the new knob caps without the little nuts that were
originally used to prevent the bottoms of the knobs from coming in
contact with the case.  it wasnt the transformer in my case also.
this was of course before the local area repair program.  if you have
an older machine like i did, it was definitely worth sending away to
get the new hardware upgrade.  good luck.
j.
--- In elektron-users@yahoogroups.com, "davidcliffordbrown"
Is there
I have to
> Thanks in advance
> David
