md - variable track length?
2004-09-18 by logansquarewave
Index last updated: 2026-04-28 23:22 UTC
is there any way to set the length of each instrument track on the MD to a different length? seems there's only a global length adjustment but i thought maybe i'm missing something. and if there is none... why not? that would add an incredible amount of flexibility to the MD.. or the MnM even. -logan
2004-09-19 by Federico Ciapi
have you tried changing the scale setup (function + scale setup) ? Il giorno 18/set/04, alle 19:16, logansquarewave ha scritto:
> is there any way to set the length of each instrument track on the MD > to a different length? seems there's only a global length adjustment > but i thought maybe i'm missing something. and if there is none... > why not? that would add an incredible amount of flexibility to the > MD.. or the MnM even. > > -logan
2004-09-19 by Paul Love
Hi I just joined the forum today because I ordered my machinedrum yesterday so I am not yet a MD user but will be by next week. Is it cool? are the sounds good or at least flexiable for tweaking ive heard nothing but positive reviews so far on this unit Ill let you know when I get mine if I can figure out what your wanting to know Im fairly savvy with drum machines but we will see each one is a totally different animal!!! Take care regards Paul On Sep 18, 2004, at 7:54 PM, Federico Ciapi wrote: > have you tried changing the scale setup (function + scale setup) ? > > Il giorno 18/set/04, alle 19:16, logansquarewave ha scritto: > > > is there any way to set the length of each instrument track on the > MD > > to a different length?� seems there's only a global length > adjustment > > but i thought maybe i'm missing something.� and if there is none... > > why not?� that would add an incredible amount of flexibility to the > > MD.. or the MnM even. > > > > -logan > > > > > Yahoo! Groups Sponsor > > ADVERTISEMENT > <122603_LREC_bkup_BR_Ashanti.jpg> > <l.gif> > > Yahoo! Groups Links > > � To visit your group on the web, go to: > http://groups.yahoo.com/group/elektron-users/ > � > � To unsubscribe from this group, send an email to: > elektron-users-unsubscribe@yahoogroups.com > � > � Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > [Non-text portions of this message have been removed]
2004-09-20 by jmelnyk@cs.kent.edu
> is there any way to set the length of each instrument track on the MD > to a different length? no, each track has the same length. yes, it would be cool if they were of different length. but I think the main reason for "why not?" would be that I don't believe that either machine was designed that way. thus working it into the interface would prove to be less than ideal - and we all know that Elektron values the ease-of-use and immediacy of their interfaces. so that would be my guess....
2004-09-20 by drammy2004
Also - if at the end of the playing pattern another pattern is selected then where should it change as each track will have different end-points. Drammy --- In elektron-users@yahoogroups.com, jmelnyk@c... wrote: > > is there any way to set the length of each instrument track on the MD > > to a different length? > > no, each track has the same length. yes, it would be cool if they were of > different length. but I think the main reason for "why not?" would be that > I don't believe that either machine was designed that way. thus working it > into the interface would prove to be less than ideal - and we all know > that Elektron values the ease-of-use and immediacy of their interfaces. > so that would be my guess....
2004-09-20 by CB
probably after the end of the longest pattern. i believe the kawai sq-80 works like that (it has the capability of having each track be a different length)
----- Original Message ----- From: drammy2004 <martyn@...> Date: Mon, 20 Sep 2004 16:11:13 -0000 Subject: Re: [elektron] md - variable track length? To: elektron-users@yahoogroups.com Also - if at the end of the playing pattern another pattern is selected then where should it change as each track will have different end-points. Drammy --- In elektron-users@yahoogroups.com, jmelnyk@c... wrote: > > is there any way to set the length of each instrument track on the MD > > to a different length? > > no, each track has the same length. yes, it would be cool if they were of > different length. but I think the main reason for "why not?" would be that > I don't believe that either machine was designed that way. thus working it > into the interface would prove to be less than ideal - and we all know > that Elektron values the ease-of-use and immediacy of their interfaces. > so that would be my guess.... Yahoo! Groups Sponsor ADVERTISEMENT ________________________________ Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/elektron-users/ To unsubscribe from this group, send an email to: elektron-users-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
