numerology and cpu/ram use
2004-07-03 by pete leuenberger @ maetrixsolution.com
dear james, i need a short hint 'bout the resources of numerology: i am working with am g4 alu 1ghz powerbook with one GB ram. just building up my equipment for live use together as a synced device to a monomachine. i am using 3x REAKTOR, 2x ZEBRA 1 x PHATMATIK PRO as AU plugz in one session. no EFX yet! my CPU usage is just on the top - the gui is getting very slow now. so would it be better the dubble up RAM to 2 GB? what will do more RAM to NUMEROLOGY 1.4b7? or do i need a new powerbook with more CPU? :-( i know there would be a possibility to go down on 3375 hz on the sample rate on each AU plug in NUM. but this woul increase my quality standart... any comments on this? and now after closing the SONG in NUM it's not possible to open up the file. this is the console log: ===== Sun Jul 04 2004 ===== 01:18:58 Europe/Zurich ===== ENGINE : Setup MIDI ENGINE: Number of all MIDI sources: 4 MIDI input 2, name: Port 1 MIDI input 3, name: Port 2 ENGINE: Number of used MIDI sources: 4 ENGINE: Number of all MIDI destinations: 6 MIDI dest: 2, name: Port 1 MIDI dest: 3, name: Port 2 MIDI dest: 4, name: Port 3 MIDI dest: 5, name: Port 4 ENGINE: Number of used MIDI destinations: 6 ENGINE: init done NGlobals init >>>>>>>>>>>>> NGlobals readUserDefaults NGlobals: sampleRatePref: 44100.000000 NGlobals: bufferSizePref: 512 NGlobals: inputClockSourcePref: 0 NGlobals: outputClockSourcePref: 0 NGlobals: audioInputPref: None NGlobals: audioOutputPref: Hammerfall DSP Multiface >>>>>>>>>>>>> NGlobals readUserDefaults DONE NGlobals, INIT DONE NAudioManager init NAudioManager enabled: 1 NAudioMgr: initAudioDeviceInfo ..status check: 0 : AudMgr:getNumDevices ..status check: 0 : AudMgr:getDeviceIDs ..status check: 0 : AudMgr: getCFName .. checking: dev id: 11 name: Built-in Audio NAudioMgr : devId: 11 numCh: 2 isInput: 1 NAudioMgr : devId: 11 numCh: 2 isInput: 0 .. add: dev id: 11 hasInputs: 1 hasOutputs: 1 ..status check: 0 : AudMgr: getCFName .. checking: dev id: 10 name: Hammerfall DSP Multiface NAudioMgr : devId: 10 numCh: 18 isInput: 1 NAudioMgr : devId: 10 numCh: 18 isInput: 0 .. add: dev id: 10 hasInputs: 1 hasOutputs: 1 --NAudioManager: Use MatrixMixer-- ..status check: 0 : NAudioMgr : create matrix mixer ..status check: 0 : NAudioMgr : create output NAudioMgr: findDevIdForName: Hammerfall DSP Multiface isInput: 0 NAudioMgr: out device: Hammerfall DSP Multiface id: 10 ### NAudioMgr: outDevice curr buff size: 512 ### NAudioMgr: set sample rate: 44100 buff size: 512 ### NAudioMgr: set clock source id 0 ### NAudioMgr: curr buff size: 512 ..status check: 0 : NAudioMgr: set HAL CurrDevice ### hal out num output channels for stream 0: 18 status: 0 ### hal output sample rate: 44100.000000 setup ch map: 18 channels ..sizeof map: 4 ..status check: 0 : NAudioMgr: set HAL OUT ChannelMap NAudioMgr : set AU stream format for output: 1 ..status check: 0 : NAudioMgr : enable metering on main matrix ..status check: 0 : NAudioMgr : conn matrix to output NAudioMgr : conn matrix mixer : 1 to output: 2 ..status check: 0 : NAudioMgr : update graph NAudioMgr: setup NO input..status check: 0 : NAudioMgr : create input matrix >>> NAudioMgr: inputMatrixNode: 3 ..status check: 0 : set input busses for inputMatrix NAudioMgr : set AU stream format for input: 1, numChannels: 0 NAudioMgr : num input matrix output busses: 0 ..status check: 0 : set output busses for inputMatrix ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create matrix aux mixer ..status check: 0 : NAudioMgr : create aux funnel mixer ..aux funnel mixer: 68 ..status check: 0 : NAudioMgr : create aux funnel mixer ..aux funnel mixer: 69 ..status check: 0 : NAudioMgr : create aux funnel mixer ..aux funnel mixer: 70 ..status check: 0 : NAudioMgr : create aux funnel mixer ..aux funnel mixer: 71 ..status check: 0 : AU graph init NAudioMgr: setup callback for Numer engine processing! clock freq: 41.500882 host ticks per MS: 41500 laTimeHT: 830000 )) ENGINE : initRenderCbData, msPerCtlSample: 0.997732 NAudioMgr, initGraph NMainCtlr: setSessionOpen: 0 2004-07-04 01:19:05.890 Numerology[376] Numerology starting up, version: 1.4b7 NMainCtlr, centerWin: 363.500000 363.500000 SetModulesVisible: 1 NMainCtlr, create PopupModels ENGINE: set ext sync: 0 <><><>NAudioMgr: initAudioMenus, numSources: 5 >>> NAudioMgr: rebuildAudioDeviceDetailMenus, next out deviceId: 10 ## NAudioMgr: add sample rate: 32000 ## NAudioMgr: add sample rate: 44100 ## NAudioMgr: add sample rate: 48000 ## NAudioMgr: add sample rate: 64000 ## NAudioMgr: add sample rate: 88200 ## NAudioMgr: add sample rate: 96000 ## NAudioMgr: add buffer size: 14 ## NAudioMgr: add buffer size: 16 ## NAudioMgr: add buffer size: 32 ## NAudioMgr: add buffer size: 64 ## NAudioMgr: add buffer size: 128 ## NAudioMgr: add buffer size: 256 ## NAudioMgr: add buffer size: 512 ## NAudioMgr: add buffer size: 1024 ## NAudioMgr: add buffer size: 2048 ## NAudioMgr: add buffer size: 4096 ## NAudioMgr: add buffer size: 6144 ## NAudioMgr: add clock source: internal ENGINE: Alloc new session: 56ba000 ENGINE: session init done MX Ctlr : mono mode on CTLR INIT: 0 FMCtlSeq: init Controller FMCtlSeqCtlr, layout MEDIUM, fromSize: 0 FMGateCtlr, layout MEDIUM, from LARGE CtlSeqCtlr, set recBtn origin: 9.000000 136.000000 FMGateCtlr, layout for size: 3 FMGateCtlr, layout MEDIUM, fromSize: 4 .. from Large NVerSlider, newFrame, height: 103.000000 FMCtlSeq: init Controller FMCtlSeqCtlr, layout MEDIUM, fromSize: 0 FMGateCtlr, layout MEDIUM, from LARGE CtlSeqCtlr, set recBtn origin: 9.000000 136.000000 FMCtlSeq: init Controller FMCtlSeqCtlr, layout MEDIUM, fromSize: 0 FMGateCtlr, layout MEDIUM, from LARGE CtlSeqCtlr, set recBtn origin: 9.000000 136.000000 FMCtlSeq: init Controller FMCtlSeqCtlr, layout MEDIUM, fromSize: 0 FMGateCtlr, layout MEDIUM, from LARGE CtlSeqCtlr, set recBtn origin: 9.000000 136.000000 FM4Track, updateView4Mod DONE NumerSession addGroup NumerSession addGroup: 0 newNumGroups: 1 FMGrooveClock: init Controller NumerSession addGroup NumerSession addGroup: 1 newNumGroups: 2 NumerSession addGroup NumerSession addGroup: 2 newNumGroups: 3 NumerSession addGroup NumerSession addGroup: 3 newNumGroups: 4 $$NMainCtlr, setup Proto AU: Airy: AU303 $$NMainCtlr, setup Proto AU: alphakanal: Buzzer2 $$NMainCtlr, setup Proto AU: Arturia: Moog Modular V $$NMainCtlr, setup Proto AU: Bitshift Audio: pHATmatik PRO $$NMainCtlr, setup Proto AU: GMediaMusic: Oddity $$NMainCtlr, setup Proto AU: Green Oak Software: Crystal $$NMainCtlr, setup Proto AU: MHC: Fatsondo $$NMainCtlr, setup Proto AU: MHC: Spacesynth $$NMainCtlr, setup Proto AU: MHC: Voxynth $$NMainCtlr, setup Proto AU: Native Instruments: Absynth 2 $$NMainCtlr, setup Proto AU: Native Instruments: Intakt $$NMainCtlr, setup Proto AU: Native Instruments: Reaktor $$NMainCtlr, setup Proto AU: Native Instruments: Reaktor Session $$NMainCtlr, setup Proto AU: Native Instruments: Vokator $$NMainCtlr, setup Proto AU: Native Instruments:FM7 $$NMainCtlr, setup Proto AU: Novation: V-Station $$NMainCtlr, setup Proto AU: u-he: Zebra $$NMainCtlr, setup Proto AU: u-he: Zoyd $$NMainCtlr, setup Proto AU: VirSyn: TERA $$NMainCtlr, setup Proto AU: VST: 4Front Bass Module.vst $$NMainCtlr, setup Proto AU: VST: Albino $$NMainCtlr, setup Proto AU: VST: Alpha 2.0.3 $$NMainCtlr, setup Proto AU: VST: Atmosphere VST OSX [k] $$NMainCtlr, setup Proto AU: VST: Claw OSX $$NMainCtlr, setup Proto AU: VST: CM-505 $$NMainCtlr, setup Proto AU: VST: Crazy Diamonds 1.8 $$NMainCtlr, setup Proto AU: VST: CronoX 2.0.2 $$NMainCtlr, setup Proto AU: VST: Crystal 2.2.1 $$NMainCtlr, setup Proto AU: VST: daOrgan 2.0.1 $$NMainCtlr, setup Proto AU: VST: Intakt.vst $$NMainCtlr, setup Proto AU: VST: mda DX10 $$NMainCtlr, setup Proto AU: VST: Moog Modular V.vst $$NMainCtlr, setup Proto AU: VST: PlastiCZ $$NMainCtlr, setup Proto AU: VST: Reaktor4.vst $$NMainCtlr, setup Proto AU: VST: reFX Beast 1.0.1 $$NMainCtlr, setup Proto AU: VST: reFX QuadraSID 1.4.1 $$NMainCtlr, setup Proto AU: VST: reFX Slayer 1.5.1 $$NMainCtlr, setup Proto AU: VST: SampleTank 1.1.9 $$NMainCtlr, setup Proto AU: VST: Scorpion 3.1 $$NMainCtlr, setup Proto AU: VST: Steinberg A1 $$NMainCtlr, setup Proto AU: VST: Steinberg LM-7 $$NMainCtlr, setup Proto AU: VST: Steinberg VB-1 $$NMainCtlr, setup Proto AU: VST: ZR-1 v2.7 $$NMainCtlr, setup Proto AU: VST: ZR-3.1 NumerSession addGroup NumerSession addGroup: 4 newNumGroups: 5 $$NMainCtlr, setup Proto AU: Airy: Speedster $$NMainCtlr, setup Proto AU: Apple: AUBandpass $$NMainCtlr, setup Proto AU: Apple: AUDelay $$NMainCtlr, setup Proto AU: Apple: AUDynamicsProcessor $$NMainCtlr, setup Proto AU: Apple: AUGraphicEQ $$NMainCtlr, setup Proto AU: Apple: AUHighShelfFilter $$NMainCtlr, setup Proto AU: Apple: AUHipass $$NMainCtlr, setup Proto AU: Apple: AULowpass $$NMainCtlr, setup Proto AU: Apple: AULowShelfFilter $$NMainCtlr, setup Proto AU: Apple: AUMatrixReverb $$NMainCtlr, setup Proto AU: Apple: AUMultibandCompressor $$NMainCtlr, setup Proto AU: Apple: AUParametricEQ $$NMainCtlr, setup Proto AU: Apple: AUPeakLimiter $$NMainCtlr, setup Proto AU: Audio Ease: Altiverb $$NMainCtlr, setup Proto AU: Bram @ Smartelectronix: Crazy Ivan $$NMainCtlr, setup Proto AU: Bram @ Smartelectronix: SupaTrigga $$NMainCtlr, setup Proto AU: Destroy FX: Buffer Override $$NMainCtlr, setup Proto AU: Destroy FX: Scrubby $$NMainCtlr, setup Proto AU: digitalfishphones: blockfish $$NMainCtlr, setup Proto AU: digitalfishphones: floorfish $$NMainCtlr, setup Proto AU: digitalfishphones: spitfish $$NMainCtlr, setup Proto AU: Dreampoint: Freeverb3 $$NMainCtlr, setup Proto AU: Elemental Audio Systems: Eqium $$NMainCtlr, setup Proto AU: Elemental Audio Systems: Firium $$NMainCtlr, setup Proto AU: Elemental Audio Systems: Inspector $$NMainCtlr, setup Proto AU: Emagic: ET1 $$NMainCtlr, setup Proto AU: Expert Sleepers: Augustus Loop $$NMainCtlr, setup Proto AU: ExpertSleepers: Phaser $$NMainCtlr, setup Proto AU: IK Multimedia: TRackS Clipper M $$NMainCtlr, setup Proto AU: IK Multimedia: TRackS Clipper S $$NMainCtlr, setup Proto AU: IK Multimedia: TRackS Comp M $$NMainCtlr, setup Proto AU: IK Multimedia: TRackS Comp S $$NMainCtlr, setup Proto AU: IK Multimedia: TRackS EQ M $$NMainCtlr, setup Proto AU: IK Multimedia: TRackS EQ S $$NMainCtlr, setup Proto AU: IK Multimedia: TRackS Limiter M $$NMainCtlr, setup Proto AU: IK Multimedia: TRackS Limiter S $$NMainCtlr, setup Proto AU: IK Multimedia: TRackS M $$NMainCtlr, setup Proto AU: IK Multimedia: TRackS S $$NMainCtlr, setup Proto AU: Koen Tanghe @ Smartelectronix: KTGranulator $$NMainCtlr, setup Proto AU: lowcoders: KingDubby v2 delay $$NMainCtlr, setup Proto AU: Magnus @ Smartelectronix: Ambience $$NMainCtlr, setup Proto AU: mda: RoundPan $$NMainCtlr, setup Proto AU: mda: Talkbox $$NMainCtlr, setup Proto AU: MHC: Flex FX Amp Mod $$NMainCtlr, setup Proto AU: MHC: Flex FX Chaos HPF $$NMainCtlr, setup Proto AU: MHC: Flex FX Chaos LPF $$NMainCtlr, setup Proto AU: MHC: Flex FX Delay $$NMainCtlr, setup Proto AU: MHC: Flex FX Ensemble $$NMainCtlr, setup Proto AU: MHC: Flex FX Resonator $$NMainCtlr, setup Proto AU: MHC: Space Effect $$NMainCtlr, setup Proto AU: MHC: Vox FX Morph AO $$NMainCtlr, setup Proto AU: MHC: Vox FX Morph I to Fictive $$NMainCtlr, setup Proto AU: MHC: Vox FX Shifted Bass E $$NMainCtlr, setup Proto AU: MHC: Vox FX Vocal Character 1 $$NMainCtlr, setup Proto AU: MHC: Vox FX Vocal Character 2 $$NMainCtlr, setup Proto AU: MHC: Vox FX Voconator $$NMainCtlr, setup Proto AU: Native Instruments: Reaktor FX $$NMainCtlr, setup Proto AU: Native Instruments: Reaktor Session FX $$NMainCtlr, setup Proto AU: Native Instruments: Spektral Delay FX $$NMainCtlr, setup Proto AU: Native Instruments: Vokator FX $$NMainCtlr, setup Proto AU: Native Instruments:FM7 Fx $$NMainCtlr, setup Proto AU: Obsolete: bitmodder $$NMainCtlr, setup Proto AU: Ohm Force: Frohmage AU $$NMainCtlr, setup Proto AU: Ohm Force: OhmBoyz AU $$NMainCtlr, setup Proto AU: The Sound Guy: SFX Machine RT $$NMainCtlr, setup Proto AU: u-he: More Feedback Machine $$NMainCtlr, setup Proto AU: VST: Blue CH-2S $$NMainCtlr, setup Proto AU: VST: Blue LM-2S $$NMainCtlr, setup Proto AU: VST: Blue PEQ-2A $$NMainCtlr, setup Proto AU: VST: Blue PEQ-2B $$NMainCtlr, setup Proto AU: VST: Blue PH-2S $$NMainCtlr, setup Proto AU: VST: Blue TLE-2S $$NMainCtlr, setup Proto AU: VST: Bouncy (OS X) $$NMainCtlr, setup Proto AU: VST: camelphatfreeOSX.vst $$NMainCtlr, setup Proto AU: VST: Chorusifier $$NMainCtlr, setup Proto AU: VST: Cyanide 2 $$NMainCtlr, setup Proto AU: VST: dfx Buffer Override mono $$NMainCtlr, setup Proto AU: VST: dfx Buffer Override stereo $$NMainCtlr, setup Proto AU: VST: DFX Geometer $$NMainCtlr, setup Proto AU: VST: dfx Rez Synth mono $$NMainCtlr, setup Proto AU: VST: dfx Rez Synth stereo $$NMainCtlr, setup Proto AU: VST: dfx Skidder $$NMainCtlr, setup Proto AU: VST: dfx Transverb $$NMainCtlr, setup Proto AU: VST: Emigrator.vst $$NMainCtlr, setup Proto AU: VST: Excitifier $$NMainCtlr, setup Proto AU: VST: H2O $$NMainCtlr, setup Proto AU: VST: Liquid Chorus (OS X) [k] $$NMainCtlr, setup Proto AU: VST: Liquid Compressor (OS X) [k] $$NMainCtlr, setup Proto AU: VST: Liquid Delay (OS X) [k] $$NMainCtlr, setup Proto AU: VST: Liquid Flanger (OS X) [k] $$NMainCtlr, setup Proto AU: VST: LiquidVerb (OS X) [k] $$NMainCtlr, setup Proto AU: VST: mda Ambience $$NMainCtlr, setup Proto AU: VST: mda AutoPan $$NMainCtlr, setup Proto AU: VST: mda Bandisto $$NMainCtlr, setup Proto AU: VST: mda BeatBox $$NMainCtlr, setup Proto AU: VST: mda Combo $$NMainCtlr, setup Proto AU: VST: mda De-ess $$NMainCtlr, setup Proto AU: VST: mda Degrade $$NMainCtlr, setup Proto AU: VST: mda Delay $$NMainCtlr, setup Proto AU: VST: mda Detune $$NMainCtlr, setup Proto AU: VST: mda Dither $$NMainCtlr, setup Proto AU: VST: mda DubDelay $$NMainCtlr, setup Proto AU: VST: mda Dynamics $$NMainCtlr, setup Proto AU: VST: mda Envelope $$NMainCtlr, setup Proto AU: VST: mda Image $$NMainCtlr, setup Proto AU: VST: mda Leslie $$NMainCtlr, setup Proto AU: VST: mda Limiter $$NMainCtlr, setup Proto AU: VST: mda Looplex $$NMainCtlr, setup Proto AU: VST: mda Loudness $$NMainCtlr, setup Proto AU: VST: mda MultiBand $$NMainCtlr, setup Proto AU: VST: mda Overdrive $$NMainCtlr, setup Proto AU: VST: mda RePsycho! $$NMainCtlr, setup Proto AU: VST: mda RezFilter $$NMainCtlr, setup Proto AU: VST: mda RoundPan $$NMainCtlr, setup Proto AU: VST: mda SpecMeter $$NMainCtlr, setup Proto AU: VST: mda Splitter $$NMainCtlr, setup Proto AU: VST: mda Stereo $$NMainCtlr, setup Proto AU: VST: mda SubSynth $$NMainCtlr, setup Proto AU: VST: mda Talkbox $$NMainCtlr, setup Proto AU: VST: mda TestTone $$NMainCtlr, setup Proto AU: VST: mda ThruZero $$NMainCtlr, setup Proto AU: VST: mda Tracker $$NMainCtlr, setup Proto AU: VST: mda VocInput $$NMainCtlr, setup Proto AU: VST: mda Vocoder $$NMainCtlr, setup Proto AU: VST: OhmForce Ohmygod $$NMainCtlr, setup Proto AU: VST: Phaserifier $$NMainCtlr, setup Proto AU: VST: Prosoniq NorthPole VST OS X $$NMainCtlr, setup Proto AU: VST: PSP42X $$NMainCtlr, setup Proto AU: VST: PSP84X $$NMainCtlr, setup Proto AU: VST: PSP_VintageMeterX $$NMainCtlr, setup Proto AU: VST: Reaktor4 FX 2x8.vst $$NMainCtlr, setup Proto AU: VST: Reaktor4 FX.vst $$NMainCtlr, setup Proto AU: VST: Reaktor4 Surround.vst $$NMainCtlr, setup Proto AU: VST: reFX Trasher2 1.1 $$NMainCtlr, setup Proto AU: VST: RoomMachine844 $$NMainCtlr, setup Proto AU: VST: RubyTube $$NMainCtlr, setup Proto AU: VST: Silverspike Reverb.it Demo $$NMainCtlr, setup Proto AU: VST: Sound Soap.vst $$NMainCtlr, setup Proto AU: VST: Spectrafier $$NMainCtlr, setup Proto AU: VST: Spektral Delay.vst $$NMainCtlr, setup Proto AU: VST: SupaPhaser $$NMainCtlr, setup Proto AU: VST: TC Compressor DeEsser $$NMainCtlr, setup Proto AU: VST: TC Filtrator $$NMainCtlr, setup Proto AU: VST: TC Graphic EQ $$NMainCtlr, setup Proto AU: VST: TC Limiter $$NMainCtlr, setup Proto AU: VST: TC Native Reverb Plus $$NMainCtlr, setup Proto AU: VST: TC Parametric EQ $$NMainCtlr, setup Proto AU: VST: TC SideChainer $$NMainCtlr, setup Proto AU: VST: Vokator.vst $$NMainCtlr, setup Proto AU: Wave Arts: MasterVerb $$NMainCtlr, setup Proto AU: Wave Arts: TrackPlug $$NMainCtlr, setup Proto AU: Wave Arts: WaveSurround -X-Mod Win Size: 1442.000000 874.000000 ***Nbrowser setProtoSession NBrowserCtlr: setupProtoTreeDataSource NBrowserCtlr, addProtoAU: Airy: AU303 NBrowserCtlr, addProtoAU: alphakanal: Buzzer2 NBrowserCtlr, addProtoAU: Apple: DLSMusicDevice NBrowserCtlr, addProtoAU: Arturia: Moog Modular V NBrowserCtlr, addProtoAU: Bitshift Audio: pHATmatik PRO NBrowserCtlr, addProtoAU: GMediaMusic: Oddity NBrowserCtlr, addProtoAU: Green Oak Software: Crystal NBrowserCtlr, addProtoAU: MHC: Fatsondo NBrowserCtlr, addProtoAU: MHC: Spacesynth NBrowserCtlr, addProtoAU: MHC: Voxynth NBrowserCtlr, addProtoAU: Native Instruments: Absynth 2 NBrowserCtlr, addProtoAU: Native Instruments: Intakt NBrowserCtlr, addProtoAU: Native Instruments: Reaktor NBrowserCtlr, addProtoAU: Native Instruments: Reaktor Session NBrowserCtlr, addProtoAU: Native Instruments: Vokator NBrowserCtlr, addProtoAU: Native Instruments:FM7 NBrowserCtlr, addProtoAU: Novation: V-Station NBrowserCtlr, addProtoAU: u-he: Zebra NBrowserCtlr, addProtoAU: u-he: Zoyd NBrowserCtlr, addProtoAU: VirSyn: TERA NBrowserCtlr, addProtoAU: VST: 4Front Bass Module.vst NBrowserCtlr, addProtoAU: VST: Albino NBrowserCtlr, addProtoAU: VST: Alpha 2.0.3 NBrowserCtlr, addProtoAU: VST: Atmosphere VST OSX [k] NBrowserCtlr, addProtoAU: VST: Claw OSX NBrowserCtlr, addProtoAU: VST: CM-505 NBrowserCtlr, addProtoAU: VST: Crazy Diamonds 1.8 NBrowserCtlr, addProtoAU: VST: CronoX 2.0.2 NBrowserCtlr, addProtoAU: VST: Crystal 2.2.1 NBrowserCtlr, addProtoAU: VST: daOrgan 2.0.1 NBrowserCtlr, addProtoAU: VST: Intakt.vst NBrowserCtlr, addProtoAU: VST: mda DX10 NBrowserCtlr, addProtoAU: VST: Moog Modular V.vst NBrowserCtlr, addProtoAU: VST: PlastiCZ NBrowserCtlr, addProtoAU: VST: Reaktor4.vst NBrowserCtlr, addProtoAU: VST: reFX Beast 1.0.1 NBrowserCtlr, addProtoAU: VST: reFX QuadraSID 1.4.1 NBrowserCtlr, addProtoAU: VST: reFX Slayer 1.5.1 NBrowserCtlr, addProtoAU: VST: SampleTank 1.1.9 NBrowserCtlr, addProtoAU: VST: Scorpion 3.1 NBrowserCtlr, addProtoAU: VST: Steinberg A1 NBrowserCtlr, addProtoAU: VST: Steinberg LM-7 NBrowserCtlr, addProtoAU: VST: Steinberg VB-1 NBrowserCtlr, addProtoAU: VST: ZR-1 v2.7 NBrowserCtlr, addProtoAU: VST: ZR-3.1 NBrowserCtlr, addProtoAU: Airy: Speedster NBrowserCtlr, addProtoAU: Apple: AUBandpass NBrowserCtlr, addProtoAU: Apple: AUDelay NBrowserCtlr, addProtoAU: Apple: AUDynamicsProcessor NBrowserCtlr, addProtoAU: Apple: AUGraphicEQ NBrowserCtlr, addProtoAU: Apple: AUHighShelfFilter NBrowserCtlr, addProtoAU: Apple: AUHipass NBrowserCtlr, addProtoAU: Apple: AULowpass NBrowserCtlr, addProtoAU: Apple: AULowShelfFilter NBrowserCtlr, addProtoAU: Apple: AUMatrixReverb NBrowserCtlr, addProtoAU: Apple: AUMultibandCompressor NBrowserCtlr, addProtoAU: Apple: AUParametricEQ NBrowserCtlr, addProtoAU: Apple: AUPeakLimiter NBrowserCtlr, addProtoAU: Audio Ease: Altiverb NBrowserCtlr, addProtoAU: Bram @ Smartelectronix: Crazy Ivan NBrowserCtlr, addProtoAU: Bram @ Smartelectronix: SupaTrigga NBrowserCtlr, addProtoAU: Destroy FX: Buffer Override NBrowserCtlr, addProtoAU: Destroy FX: Scrubby NBrowserCtlr, addProtoAU: digitalfishphones: blockfish NBrowserCtlr, addProtoAU: digitalfishphones: floorfish NBrowserCtlr, addProtoAU: digitalfishphones: spitfish NBrowserCtlr, addProtoAU: Dreampoint: Freeverb3 NBrowserCtlr, addProtoAU: Elemental Audio Systems: Eqium NBrowserCtlr, addProtoAU: Elemental Audio Systems: Firium NBrowserCtlr, addProtoAU: Elemental Audio Systems: Inspector NBrowserCtlr, addProtoAU: Emagic: ET1 NBrowserCtlr, addProtoAU: Expert Sleepers: Augustus Loop NBrowserCtlr, addProtoAU: ExpertSleepers: Phaser NBrowserCtlr, addProtoAU: IK Multimedia: TRackS Clipper M NBrowserCtlr, addProtoAU: IK Multimedia: TRackS Clipper S NBrowserCtlr, addProtoAU: IK Multimedia: TRackS Comp M NBrowserCtlr, addProtoAU: IK Multimedia: TRackS Comp S NBrowserCtlr, addProtoAU: IK Multimedia: TRackS EQ M NBrowserCtlr, addProtoAU: IK Multimedia: TRackS EQ S NBrowserCtlr, addProtoAU: IK Multimedia: TRackS Limiter M NBrowserCtlr, addProtoAU: IK Multimedia: TRackS Limiter S NBrowserCtlr, addProtoAU: IK Multimedia: TRackS M NBrowserCtlr, addProtoAU: IK Multimedia: TRackS S NBrowserCtlr, addProtoAU: Koen Tanghe @ Smartelectronix: KTGranulator NBrowserCtlr, addProtoAU: lowcoders: KingDubby v2 delay NBrowserCtlr, addProtoAU: Magnus @ Smartelectronix: Ambience NBrowserCtlr, addProtoAU: mda: RoundPan NBrowserCtlr, addProtoAU: mda: Talkbox NBrowserCtlr, addProtoAU: MHC: Flex FX Amp Mod NBrowserCtlr, addProtoAU: MHC: Flex FX Chaos HPF NBrowserCtlr, addProtoAU: MHC: Flex FX Chaos LPF NBrowserCtlr, addProtoAU: MHC: Flex FX Delay NBrowserCtlr, addProtoAU: MHC: Flex FX Ensemble NBrowserCtlr, addProtoAU: MHC: Flex FX Resonator NBrowserCtlr, addProtoAU: MHC: Space Effect NBrowserCtlr, addProtoAU: MHC: Vox FX Morph AO NBrowserCtlr, addProtoAU: MHC: Vox FX Morph I to Fictive NBrowserCtlr, addProtoAU: MHC: Vox FX Shifted Bass E NBrowserCtlr, addProtoAU: MHC: Vox FX Vocal Character 1 NBrowserCtlr, addProtoAU: MHC: Vox FX Vocal Character 2 NBrowserCtlr, addProtoAU: MHC: Vox FX Voconator NBrowserCtlr, addProtoAU: Native Instruments: Reaktor FX NBrowserCtlr, addProtoAU: Native Instruments: Reaktor Session FX NBrowserCtlr, addProtoAU: Native Instruments: Spektral Delay FX NBrowserCtlr, addProtoAU: Native Instruments: Vokator FX NBrowserCtlr, addProtoAU: Native Instruments:FM7 Fx NBrowserCtlr, addProtoAU: Obsolete: bitmodder NBrowserCtlr, addProtoAU: Ohm Force: Frohmage AU NBrowserCtlr, addProtoAU: Ohm Force: OhmBoyz AU NBrowserCtlr, addProtoAU: The Sound Guy: SFX Machine RT NBrowserCtlr, addProtoAU: u-he: More Feedback Machine NBrowserCtlr, addProtoAU: VST: Blue CH-2S NBrowserCtlr, addProtoAU: VST: Blue LM-2S NBrowserCtlr, addProtoAU: VST: Blue PEQ-2A NBrowserCtlr, addProtoAU: VST: Blue PEQ-2B NBrowserCtlr, addProtoAU: VST: Blue PH-2S NBrowserCtlr, addProtoAU: VST: Blue TLE-2S NBrowserCtlr, addProtoAU: VST: Bouncy (OS X) NBrowserCtlr, addProtoAU: VST: camelphatfreeOSX.vst NBrowserCtlr, addProtoAU: VST: Chorusifier NBrowserCtlr, addProtoAU: VST: Cyanide 2 NBrowserCtlr, addProtoAU: VST: dfx Buffer Override mono NBrowserCtlr, addProtoAU: VST: dfx Buffer Override stereo NBrowserCtlr, addProtoAU: VST: DFX Geometer NBrowserCtlr, addProtoAU: VST: dfx Rez Synth mono NBrowserCtlr, addProtoAU: VST: dfx Rez Synth stereo NBrowserCtlr, addProtoAU: VST: dfx Skidder NBrowserCtlr, addProtoAU: VST: dfx Transverb NBrowserCtlr, addProtoAU: VST: Emigrator.vst NBrowserCtlr, addProtoAU: VST: Excitifier NBrowserCtlr, addProtoAU: VST: H2O NBrowserCtlr, addProtoAU: VST: Liquid Chorus (OS X) [k] NBrowserCtlr, addProtoAU: VST: Liquid Compressor (OS X) [k] NBrowserCtlr, addProtoAU: VST: Liquid Delay (OS X) [k] NBrowserCtlr, addProtoAU: VST: Liquid Flanger (OS X) [k] NBrowserCtlr, addProtoAU: VST: LiquidVerb (OS X) [k] NBrowserCtlr, addProtoAU: VST: mda Ambience NBrowserCtlr, addProtoAU: VST: mda AutoPan NBrowserCtlr, addProtoAU: VST: mda Bandisto NBrowserCtlr, addProtoAU: VST: mda BeatBox NBrowserCtlr, addProtoAU: VST: mda Combo NBrowserCtlr, addProtoAU: VST: mda De-ess NBrowserCtlr, addProtoAU: VST: mda Degrade NBrowserCtlr, addProtoAU: VST: mda Delay NBrowserCtlr, addProtoAU: VST: mda Detune NBrowserCtlr, addProtoAU: VST: mda Dither NBrowserCtlr, addProtoAU: VST: mda DubDelay NBrowserCtlr, addProtoAU: VST: mda Dynamics NBrowserCtlr, addProtoAU: VST: mda Envelope NBrowserCtlr, addProtoAU: VST: mda Image NBrowserCtlr, addProtoAU: VST: mda Leslie NBrowserCtlr, addProtoAU: VST: mda Limiter NBrowserCtlr, addProtoAU: VST: mda Looplex NBrowserCtlr, addProtoAU: VST: mda Loudness NBrowserCtlr, addProtoAU: VST: mda MultiBand NBrowserCtlr, addProtoAU: VST: mda Overdrive NBrowserCtlr, addProtoAU: VST: mda RePsycho! NBrowserCtlr, addProtoAU: VST: mda RezFilter NBrowserCtlr, addProtoAU: VST: mda RoundPan NBrowserCtlr, addProtoAU: VST: mda SpecMeter NBrowserCtlr, addProtoAU: VST: mda Splitter NBrowserCtlr, addProtoAU: VST: mda Stereo NBrowserCtlr, addProtoAU: VST: mda SubSynth NBrowserCtlr, addProtoAU: VST: mda Talkbox NBrowserCtlr, addProtoAU: VST: mda TestTone NBrowserCtlr, addProtoAU: VST: mda ThruZero NBrowserCtlr, addProtoAU: VST: mda Tracker NBrowserCtlr, addProtoAU: VST: mda VocInput NBrowserCtlr, addProtoAU: VST: mda Vocoder NBrowserCtlr, addProtoAU: VST: OhmForce Ohmygod NBrowserCtlr, addProtoAU: VST: Phaserifier NBrowserCtlr, addProtoAU: VST: Prosoniq NorthPole VST OS X NBrowserCtlr, addProtoAU: VST: PSP42X NBrowserCtlr, addProtoAU: VST: PSP84X NBrowserCtlr, addProtoAU: VST: PSP_VintageMeterX NBrowserCtlr, addProtoAU: VST: Reaktor4 FX 2x8.vst NBrowserCtlr, addProtoAU: VST: Reaktor4 FX.vst NBrowserCtlr, addProtoAU: VST: Reaktor4 Surround.vst NBrowserCtlr, addProtoAU: VST: reFX Trasher2 1.1 NBrowserCtlr, addProtoAU: VST: RoomMachine844 NBrowserCtlr, addProtoAU: VST: RubyTube NBrowserCtlr, addProtoAU: VST: Silverspike Reverb.it Demo NBrowserCtlr, addProtoAU: VST: Sound Soap.vst NBrowserCtlr, addProtoAU: VST: Spectrafier NBrowserCtlr, addProtoAU: VST: Spektral Delay.vst NBrowserCtlr, addProtoAU: VST: SupaPhaser NBrowserCtlr, addProtoAU: VST: TC Compressor DeEsser NBrowserCtlr, addProtoAU: VST: TC Filtrator NBrowserCtlr, addProtoAU: VST: TC Graphic EQ NBrowserCtlr, addProtoAU: VST: TC Limiter NBrowserCtlr, addProtoAU: VST: TC Native Reverb Plus NBrowserCtlr, addProtoAU: VST: TC Parametric EQ NBrowserCtlr, addProtoAU: VST: TC SideChainer NBrowserCtlr, addProtoAU: VST: Vokator.vst NBrowserCtlr, addProtoAU: Wave Arts: MasterVerb NBrowserCtlr, addProtoAU: Wave Arts: TrackPlug NBrowserCtlr, addProtoAU: Wave Arts: WaveSurround Create blank session ENGINE: Alloc new session: a7d5000 ENGINE: session init done NumerSession : Create clock group GC : set is master clock FMGrooveClock: init Controller NumerSession addGroup NumerSession addGroup: 0 newNumGroups: 1 FMCtlSeq: init Controller FMCtlSeqCtlr, layout MEDIUM, fromSize: 0 FMGateCtlr, layout MEDIUM, from LARGE CtlSeqCtlr, set recBtn origin: 9.000000 136.000000 blank session, add one group NumerSession addGroup NumerSession addGroup: 1 newNumGroups: 2 Create blank session - DONE ***NMainCtlr: setSession*** NMainCtlr session path name 0: (null) NMainCtlr: setSessionOpen: 1 NMainCtlr session path name 1: (null) ENGINE: queue new sessionData a7d5000 ENGINE: write session action: 0 GC : set is master clock NMainCtlr: layout modules for each group ENGINE: read session action: 0 ENGINE: set new gSession: a7d5000, numModules: 514 ENGINE: set ext sync: 0 ************************ENGINE: set master clock module, Id: 0 NMainCtlr: layout modules DONE NMainCtlr, groupChOwner setCurrGroup done ***NAudioMgr: groupAudioInputMenu: 1d7fb30 ***NAudioMgr: groupAudioInputMenu: 1d7fb30 tracksViewHeight: 516.000000 NTracksBgView: setHZoom: 1.000000 NTracksBgView: setHZoom: 1.000000 NTrCtlr, initial groupYCursor: 476.000000 prev scroll point x: 0.000000 y: 0.000000 scroll to point: 2.000000 NMainCtlr, setSession for Browser done **NMainCtlr, setup audio for new session NAudioMgr: assignMixerChannels NAudioMgr: assignMixerChannels DONE NMainCtlr, setSession, update mods done **NMainCtlr, setup audio for new session NAudioMgr: assignMixerChannels NAudioMgr: assignMixerChannels DONE NMainCtlr, setSession, set selected group to 0 GroupModChOwner, updateView4Model DONE NMainCtlr: setSession DONE **NO SYNC DEBUG === NMainCtlr: init DONE NMixerScrollView awakeFromNib NMenuContentView: force initImages, first item: None NMenuContentView: force initImages, DONE NMenuContentView: force initImages, first item: None NMenuContentView: force initImages, DONE NMenuContentView: force initImages, first item: None NMenuContentView: force initImages, DONE NMenuContentView: force initImages, first item: Built-in Audio NMenuContentView: force initImages, DONE skip wiper restore cached image NVertMeter: createIndicatorImage NVertMeter: createIndicatorImage NMainCtlr: open file : /Users/ple/Desktop/schulung.ns **NAudioMgr, Disconnect group 0 from AU graph ERROR : NAudioMgr : unexpected mixer index: -1 (disconnGroupFromAuGraph) **NAudioMgr, Disconnect group 1 from AU graph ERROR : NAudioMgr : unexpected mixer index: -1 (disconnGroupFromAuGraph) NMainCtlr: setSessionOpen: 0 --decoding NumerSession: curr Version ENGINE: Alloc new session: b3ff000 ENGINE: session init done ##NumerVersion: NumerVersion: 1 : 1 . 3 . -2 .. aux send: 0 level: 0.000000 .. aux send: 1 level: 0.000000 .. aux send: 2 level: 0.000000 .. aux send: 3 level: 0.000000 ***NumerGroup: read AudioOutPort from array, busNum: 0 FMGroupModule: init private data DONE FModule initWithCoder: (null), modID: 512 >>> decodeFileMapWithCoder FModule, decode fileMap of size: 6 filePresetSize: 24 .. setLoadingFileMap w/ Key: 100 Group Module FModule, decoded maps equal: 1 presetDataEqual: 1 ##FModule, copying preset data directly FModule, copy presets done FModule Done w/ priv data init ^^^^^^^^^^^^^^^^^^^^^^^^FMGrooveClock: init private data FMGrooveClock: init private data DONE FModule initWithCoder: Master Clk, modID: 0 >>> decodeFileMapWithCoder FModule, decode fileMap of size: 23 filePresetSize: 164 .. setLoadingFileMap w/ Key: 101 Groove Clock FModule, decoded maps equal: 1 presetDataEqual: 1 ##FModule, copying preset data directly FModule, copy presets done FModule Done w/ priv data init FMGrooveClock: init Controller .. aux send: 0 level: 0.000000 .. aux send: 1 level: 0.000000 .. aux send: 2 level: 0.000000 .. aux send: 3 level: 0.000000 ***NumerGroup: read AudioOutPort from array, busNum: 3 FMGroupModule: init private data DONE FModule initWithCoder: (null), modID: 513 >>> decodeFileMapWithCoder FModule, use existing file map for: 100 Group Module FModule, decoded maps equal: 0 presetDataEqual: 1 FModule, extract presets done FModule Done w/ priv data init FModule initWithCoder: Pitch, modID: 1 >>> decodeFileMapWithCoder FModule, decode fileMap of size: 28 filePresetSize: 484 .. setLoadingFileMap w/ Key: 222 Control Sequencer FModule, decoded maps equal: 1 presetDataEqual: 1 ##FModule, copying preset data directly FModule, copy presets done FModule Done w/ priv data init FMCtlSeq: init Controller FModule initWithCoder: Gate, modID: 2 >>> decodeFileMapWithCoder FModule, decode fileMap of size: 29 filePresetSize: 488 .. setLoadingFileMap w/ Key: 223 Gate Sequencer FModule, decoded maps equal: 1 presetDataEqual: 1 ##FModule, copying preset data directly FModule, copy presets done FModule Done w/ priv data init FModule initWithCoder: Note Output, modID: 3 >>> decodeFileMapWithCoder FModule, decode fileMap of size: 24 filePresetSize: 112 .. setLoadingFileMap w/ Key: 111 MIDI Note Output FModule, decoded maps equal: 1 presetDataEqual: 1 ##FModule, copying preset data directly FModule, copy presets done FModule Done w/ priv data init .. aux send: 0 level: 0.000000 .. aux send: 1 level: 0.000000 .. aux send: 2 level: 0.000000 .. aux send: 3 level: 0.000000 ***NumerGroup: read AudioOutPort from array, busNum: 2 FMGroupModule: init private data DONE FModule initWithCoder: (null), modID: 514 >>> decodeFileMapWithCoder FModule, use existing file map for: 100 Group Module FModule, decoded maps equal: 0 presetDataEqual: 1 FModule, extract presets done FModule Done w/ priv data init FModule initWithCoder: MIDI Input, modID: 5 >>> decodeFileMapWithCoder FModule, decode fileMap of size: 4 filePresetSize: 28 .. setLoadingFileMap w/ Key: 115 MIDI Note Input FModule, decoded maps equal: 1 presetDataEqual: 1 ##FModule, copying preset data directly FModule, copy presets done FModule Done w/ priv data init FGenericAudioModule, decoded ModuleClassWithCoder, cdo nil: 0 mod class nil: 0 FModule initWithCoder: Zebra, modID: 6 --Gen loadingMapKey: aumuSMD1UHfX >>> decodeFileMapWithCoder FModule, decode fileMap of size: 3 filePresetSize: 20 .. setLoadingFileMap w/ Key: 900 Audio Unit:aumuSMD1UHfX FModule, decoded maps equal: 1 presetDataEqual: 1 ##FModule, copying preset data directly FModule, copy presets done FModule Done w/ priv data init .. aux send: 0 level: 0.000000 .. aux send: 1 level: 0.000000 .. aux send: 2 level: 0.000000 .. aux send: 3 level: 0.000000 ***NumerGroup: read AudioOutPort from array, busNum: 2 FMGroupModule: init private data DONE FModule initWithCoder: (null), modID: 515 >>> decodeFileMapWithCoder FModule, use existing file map for: 100 Group Module FModule, decoded maps equal: 0 presetDataEqual: 1 FModule, extract presets done FModule Done w/ priv data init #### Matrix Seq, num voice names: 12 FModule initWithCoder: Matrix, modID: 7 >>> decodeFileMapWithCoder FModule, decode fileMap of size: 37 filePresetSize: 484 .. setLoadingFileMap w/ Key: 283 Matrix Sequencer FModule, decoded maps equal: 1 presetDataEqual: 1 ##FModule, copying preset data directly FModule, copy presets done FModule Done w/ priv data init MX Ctlr : mono mode on CTLR INIT: 0 FModule initWithCoder: Note Output, modID: 8 >>> decodeFileMapWithCoder FModule, use existing file map for: 111 MIDI Note Output FModule, decoded maps equal: 0 presetDataEqual: 1 FModule, extract presets done FModule Done w/ priv data init FGenericAudioModule, decoded ModuleClassWithCoder, cdo nil: 0 mod class nil: 0 FModule initWithCoder: Zebra, modID: 9 --Gen loadingMapKey: aumuSMD1UHfX >>> decodeFileMapWithCoder FModule, use existing file map for: 900 Audio Unit:aumuSMD1UHfX FModule, decoded maps equal: 0 presetDataEqual: 1 FModule, extract presets done FModule Done w/ priv data init .. aux send: 0 level: 0.000000 .. aux send: 1 level: 0.000000 .. aux send: 2 level: 0.000000 .. aux send: 3 level: 0.000000 ***NumerGroup: read AudioOutPort from array, busNum: 3 FMGroupModule: init private data DONE FModule initWithCoder: (null), modID: 516 >>> decodeFileMapWithCoder FModule, use existing file map for: 100 Group Module FModule, decoded maps equal: 0 presetDataEqual: 1 FModule, extract presets done FModule Done w/ priv data init #### Matrix Seq, num voice names: 12 FModule initWithCoder: Matrix, modID: 4 >>> decodeFileMapWithCoder FModule, use existing file map for: 283 Matrix Sequencer FModule, decoded maps equal: 0 presetDataEqual: 1 FModule, extract presets done FModule Done w/ priv data init MX Ctlr : mono mode on CTLR INIT: 0 FModule initWithCoder: Note Output, modID: 10 >>> decodeFileMapWithCoder FModule, use existing file map for: 111 MIDI Note Output FModule, decoded maps equal: 0 presetDataEqual: 1 FModule, extract presets done FModule Done w/ priv data init FGenericAudioModule, decoded ModuleClassWithCoder, cdo nil: 0 mod class nil: 0 FModule initWithCoder: Reaktor, modID: 11 --Gen loadingMapKey: aumuNiRe-NI- >>> decodeFileMapWithCoder FModule, decode fileMap of size: 3 filePresetSize: 20 .. setLoadingFileMap w/ Key: 900 Audio Unit:aumuNiRe-NI- FModule, decoded maps equal: 1 presetDataEqual: 1 ##FModule, copying preset data directly FModule, copy presets done FModule Done w/ priv data init .. aux send: 0 level: 0.000000 .. aux send: 1 level: 0.000000 .. aux send: 2 level: 0.000000 .. aux send: 3 level: 0.000000 ***NumerGroup: read AudioOutPort from array, busNum: 3 FMGroupModule: init private data DONE FModule initWithCoder: (null), modID: 517 >>> decodeFileMapWithCoder FModule, use existing file map for: 100 Group Module FModule, decoded maps equal: 0 presetDataEqual: 1 FModule, extract presets done FModule Done w/ priv data init FMTwoDrum, loaded size: 4 FModule initWithCoder: Drum Seq, modID: 12 >>> decodeFileMapWithCoder FModule, decode fileMap of size: 35 filePresetSize: 944 .. setLoadingFileMap w/ Key: 142 Drum Sequencer FModule, decoded maps equal: 1 presetDataEqual: 1 ##FModule, copying preset data directly FModule, copy presets done FModule Done w/ priv data init FModule initWithCoder: Note Output, modID: 13 >>> decodeFileMapWithCoder FModule, use existing file map for: 111 MIDI Note Output FModule, decoded maps equal: 0 presetDataEqual: 1 FModule, extract presets done FModule Done w/ priv data init FGenericAudioModule, decoded ModuleClassWithCoder, cdo nil: 0 mod class nil: 0 FModule initWithCoder: pHATmatik PRO, modID: 14 --Gen loadingMapKey: aumupPRO0xBA >>> decodeFileMapWithCoder FModule, decode fileMap of size: 3 filePresetSize: 20 .. setLoadingFileMap w/ Key: 900 Audio Unit:aumupPRO0xBA FModule, decoded maps equal: 1 presetDataEqual: 1 ##FModule, copying preset data directly FModule, copy presets done FModule Done w/ priv data init .. aux send: 0 level: 0.000000 .. aux send: 1 level: 0.000000 .. aux send: 2 level: 0.000000 .. aux send: 3 level: 0.000000 ***NumerGroup: read AudioOutPort from array, busNum: 2 FMGroupModule: init private data DONE FModule initWithCoder: (null), modID: 518 >>> decodeFileMapWithCoder FModule, use existing file map for: 100 Group Module FModule, decoded maps equal: 0 presetDataEqual: 1 FModule, extract presets done FModule Done w/ priv data init #### Matrix Seq, num voice names: 12 FModule initWithCoder: Matrix, modID: 15 >>> decodeFileMapWithCoder FModule, use existing file map for: 283 Matrix Sequencer FModule, decoded maps equal: 0 presetDataEqual: 1 FModule, extract presets done FModule Done w/ priv data init MX Ctlr : mono mode on CTLR INIT: 0 FModule initWithCoder: Note Output, modID: 16 >>> decodeFileMapWithCoder FModule, use existing file map for: 111 MIDI Note Output FModule, decoded maps equal: 0 presetDataEqual: 1 FModule, extract presets done FModule Done w/ priv data init FGenericAudioModule, decoded ModuleClassWithCoder, cdo nil: 0 mod class nil: 0 FModule initWithCoder: Reaktor, modID: 17 --Gen loadingMapKey: aumuNiRe-NI- >>> decodeFileMapWithCoder FModule, use existing file map for: 900 Audio Unit:aumuNiRe-NI- FModule, decoded maps equal: 0 presetDataEqual: 1 FModule, extract presets done FModule Done w/ priv data init --session, decoded groups NumerSession addGroup NumerSession addGroup: 0 newNumGroups: 1 NumerSession addGroup NumerSession addGroup: 1 newNumGroups: 2 NumerSession addGroup NumerSession addGroup: 2 newNumGroups: 3 NumerSession addGroup NumerSession addGroup: 3 newNumGroups: 4 NumerSession addGroup NumerSession addGroup: 4 newNumGroups: 5 NumerSession addGroup NumerSession addGroup: 5 newNumGroups: 6 NumerSession addGroup NumerSession addGroup: 6 newNumGroups: 7 --session, added: fileGroups: 7, groups: 7 NumerTrackSeq -- clockTrack NOT Inserted --session, add modules from group: 0 numMods: 1 --session, add modules from group: 1 numMods: 3 --session, add modules from group: 2 numMods: 2 --session, add modules from group: 3 numMods: 3 --session, add modules from group: 4 numMods: 3 --session, add modules from group: 5 numMods: 3 --session, add modules from group: 6 numMods: 3 --session, added modules to engine NumerSession: Updating all port connections GateSeqCtl -- need full update GateSeqCtlr: updateClockDivType ^^^^^FMUpdateMidiOutDest, force to 0, paramid: 44, orig: 8, numOuts: 6 ^^^^^FMUpdateMidiOutDest, force to 0, paramid: 49, orig: 8, numOuts: 6 .. upate mono/poly btn .. upate mono/poly btn .. upate mono/poly btn ^^^^^FMUpdateMidiOutDest, force to 0, paramid: 44, orig: 8, numOuts: 6 ^^^^^FMUpdateMidiOutDest, force to 0, paramid: 49, orig: 8, numOuts: 6 **MIDI IN CONTROLLER: updateMidiMenus: 0 --session, updated port & MIDI menus, all done ***NMainCtlr: setSession*** NMainCtlr session path name 0: /Users/ple/Desktop/schulung.ns NMainCtlr: setSessionOpen: 1 NMainCtlr session path name 1: /Users/ple/Desktop/schulung.ns ENGINE: queue new sessionData b3ff000 ENGINE: write session action: 1 GC : set is master clock NMainCtlr: layout modules for each group ENGINE: read session action: 1 ENGINE: free old gSession: a7d5000 ENGINE: set new gSession: b3ff000, numModules: 519 ENGINE: set ext sync: 2 ENGINE: New clock port Id 3 ************************ENGINE: set master clock module, Id: 0 GateSeqCtlr: updateClockDivType ^^^^^FMUpdateMidiOutDest, force to 0, paramid: 44, orig: 8, numOuts: 6 ^^^^^FMUpdateMidiOutDest, force to 0, paramid: 49, orig: 8, numOuts: 6 .. upate mono/poly btn .. upate mono/poly btn .. upate mono/poly btn NMainCtlr: layout modules DONE NMainCtlr, groupChOwner setCurrGroup done NMixCh Controller dealloc NMixCh Controller dealloc ***NAudioMgr: groupAudioInputMenu: 1d7fb30 ***NAudioMgr: groupAudioInputMenu: 1d7fb30 ***NAudioMgr: groupAudioInputMenu: 1d7fb30 ***NAudioMgr: groupAudioInputMenu: 1d7fb30 ***NAudioMgr: groupAudioInputMenu: 1d7fb30 ***NAudioMgr: groupAudioInputMenu: 1d7fb30 ***NAudioMgr: groupAudioInputMenu: 1d7fb30 tracksViewHeight: 514.000000 NTracksBgView: setHZoom: 0.062500 NTracksBgView: setHZoom: 0.062500 NTrCtlr, initial groupYCursor: 474.000000 prev scroll point x: 0.000000 y: 0.000000 scroll to point: 2.000000 NMainCtlr, setSession for Browser done GateSeqCtlr: updateClockDivType ^^^^^FMUpdateMidiOutDest, force to 0, paramid: 44, orig: 8, numOuts: 6 ^^^^^FMUpdateMidiOutDest, force to 0, paramid: 49, orig: 8, numOuts: 6 .. upate mono/poly btn .. upate mono/poly btn .. upate mono/poly btn **NMainCtlr, setup audio for new session NAudioMgr: assignMixerChannels ..group: 2 setAudioMixer NEW index: 0 ..group: 3 setAudioMixer NEW index: 1 ..group: 4 setAudioMixer NEW index: 2 ..group: 5 setAudioMixer NEW index: 3 ..group: 6 setAudioMixer NEW index: 4 NAudioMgr: assignMixerChannels DONE **NAudioMgr, conn group 2 to AU graph, 2 modules, mixerIndex: 0 .. audioSourcePort type: 0 FMAuSynth, setAudioUnit >>> NAudioMgr : pre-init new AU node! .. NAudioMgr: connect group to matrix mixer: 0, and enable **NAudioMgr: ConnGroupToAuxMixer at: 0 NAudioMgr: setupMainMixerAtIndex: 0 ..status check: 0 : NAudioMgr : enable metering ..status check: 0 : NAudioMgr : conn aux send mixer to aux FUNNEL mixer ..status check: 0 : NAudioMgr : conn aux send mixer to aux FUNNEL mixer ..status check: 0 : NAudioMgr : conn aux send mixer to aux FUNNEL mixer ..status check: 0 : NAudioMgr : conn aux send mixer to aux FUNNEL mixer ..status check: 0 : NAudioMgr : conn aux send mixer to output mixer NAudioMgr : conn aux send mixer 4 to output mixer 1 .. last node for group: 72 .. connecting group to aux mixer, group's lastNodeElement: 0 ..status check: 0 : NAudioMgr : conn node to aux mixer ..status check: 0 : NAudioMgr : update graph ..status check: 0 : NAudioMgr : update graph AU GRAPH: conn: 0 node: 1 out: 0 to node: 2 in: 0 conn: 1 node: 4 out: 1 to node: 68 in: 0 conn: 2 node: 4 out: 2 to node: 69 in: 0 conn: 3 node: 4 out: 3 to node: 70 in: 0 conn: 4 node: 4 out: 4 to node: 71 in: 0 conn: 5 node: 4 out: 0 to node: 1 in: 0 conn: 6 node: 72 out: 0 to node: 4 in: 0 **NAudioMgr.connGroupToMixer DONE ..status check: 0 : NAudioMgr : update graph ******** NumerGroup: setAudioIsRouted: 1 AU GRAPH: conn: 0 node: 1 out: 0 to node: 2 in: 0 conn: 1 node: 4 out: 1 to node: 68 in: 0 conn: 2 node: 4 out: 2 to node: 69 in: 0 conn: 3 node: 4 out: 3 to node: 70 in: 0 conn: 4 node: 4 out: 4 to node: 71 in: 0 conn: 5 node: 4 out: 0 to node: 1 in: 0 conn: 6 node: 72 out: 0 to node: 4 in: 0 **NAudioMgr, conn group to AU graph DONE FGenericAudioModuleClass buildAuOnlyParmInfoList ..RAW Num AU Params: 281 ***NAudioMgr, getAuPresetMenu for mod: Zebra NAudioManager : getPresetDir NAudioManager : getPresetDir NAudioMgr, load 33 user presets NAudioMgr, load 6 user presets NAudioMgr, load 32 user presets NAudioMgr, load 19 user presets NAudioMgr, load 1 user presets NAudioMgr, load 18 user presets NAudioMgr, load 129 user presets NAudioMgr, load 36 user presets NAudioMgr, load 7 user presets NAudioMgr, load 5 user presets NAudioMgr, load 57 user presets NAudioMgr, load 32 user presets NAudioMgr, load 5 user presets NAudioMgr, load 29 user presets NAudioMgr, load 14 user presets NAudioMgr, load 16 user presets NAudioMgr, load 21 user presets NAudioMgr, load 22 user presets NAudioMgr, load 3 user presets NAudioMgr, load 7 user presets NAudioMgr, load 19 user presets NAudioMgr, load 7 user presets NAudioMgr, load 19 user presets NAudioMgr, load 36 user presets NAudioMgr, load 7 user presets NAudioMgr, load 6 user presets NAudioMgr, load 5 user presets NAudioMgr, load 14 user presets NAudioMgr, load 4 user presets NAudioMgr, load 13 user presets NAudioMgr, load 16 user presets NAudioMgr, load 21 user presets NAudioMgr, load 3 user presets NAudioMgr, load 6 user presets NAudioMgr, load 29 user presets NAudioMgr, load 12 user presets NAudioMgr, load 7 user presets NAudioMgr, load 8 user presets NAudioMgr, load 9 user presets NAudioMgr, load 6 user presets NAudioMgr, load 28 user presets NAudioMgr, load 55 user presets NAudioMgr, load 47 user presets NAudioMgr, load 29 user presets NAudioMgr, load 12 user presets NAudioMgr, load 8 user presets NAudioMgr, load 9 user presets NAudioMgr, load 20 user presets NAudioMgr, load 9 user presets NAudioMgr, load 3 user presets NAudioMgr, load 1 user presets NAudioMgr, load 0 user presets .. got 862 user presets NGlobals, return auPresetMenuView, 862 items FGenAudioMod, updateAuPresetData DONE NPopupView, selectItemWithText: |Default| **NAudioMgr, conn group 3 to AU graph, 3 modules, mixerIndex: 1 .. audioSourcePort type: 0 FMAuSynth, setAudioUnit >>> NAudioMgr : pre-init new AU node! .. NAudioMgr: connect group to matrix mixer: 1, and enable **NAudioMgr: ConnGroupToAuxMixer at: 1 NAudioMgr: setupMainMixerAtIndex: 1 ..status check: 0 : NAudioMgr : enable metering ..status check: 0 : NAudioMgr : conn aux send mixer to aux FUNNEL mixer ..status check: 0 : NAudioMgr : conn aux send mixer to aux FUNNEL mixer ..status check: 0 : NAudioMgr : conn aux send mixer to aux FUNNEL mixer ..status check: 0 : NAudioMgr : conn aux send mixer to aux FUNNEL mixer ..status check: 0 : NAudioMgr : conn aux send mixer to output mixer NAudioMgr : conn aux send mixer 5 to output mixer 1 .. last node for group: 73 .. connecting group to aux mixer, group's lastNodeElement: 0 ..status check: 0 : NAudioMgr : conn node to aux mixer ..status check: 0 : NAudioMgr : update graph ..status check: 0 : NAudioMgr : update graph AU GRAPH: conn: 0 node: 1 out: 0 to node: 2 in: 0 conn: 1 node: 4 out: 1 to node: 68 in: 0 conn: 2 node: 4 out: 2 to node: 69 in: 0 conn: 3 node: 4 out: 3 to node: 70 in: 0 conn: 4 node: 4 out: 4 to node: 71 in: 0 conn: 5 node: 4 out: 0 to node: 1 in: 0 conn: 6 node: 72 out: 0 to node: 4 in: 0 conn: 7 node: 5 out: 1 to node: 68 in: 1 conn: 8 node: 5 out: 2 to node: 69 in: 1 conn: 9 node: 5 out: 3 to node: 70 in: 1 conn: 10 node: 5 out: 4 to node: 71 in: 1 conn: 11 node: 5 out: 0 to node: 1 in: 1 conn: 12 node: 73 out: 0 to node: 5 in: 0 **NAudioMgr.connGroupToMixer DONE ..status check: 0 : NAudioMgr : update graph ******** NumerGroup: setAudioIsRouted: 1 AU GRAPH: conn: 0 node: 1 out: 0 to node: 2 in: 0 conn: 1 node: 4 out: 1 to node: 68 in: 0 conn: 2 node: 4 out: 2 to node: 69 in: 0 conn: 3 node: 4 out: 3 to node: 70 in: 0 conn: 4 node: 4 out: 4 to node: 71 in: 0 conn: 5 node: 4 out: 0 to node: 1 in: 0 conn: 6 node: 72 out: 0 to node: 4 in: 0 conn: 7 node: 5 out: 1 to node: 68 in: 1 conn: 8 node: 5 out: 2 to node: 69 in: 1 conn: 9 node: 5 out: 3 to node: 70 in: 1 conn: 10 node: 5 out: 4 to node: 71 in: 1 conn: 11 node: 5 out: 0 to node: 1 in: 1 conn: 12 node: 73 out: 0 to node: 5 in: 0 **NAudioMgr, conn group to AU graph DONE FGenericAudioModuleClass buildAuOnlyParmInfoList ..RAW Num AU Params: 281 ***NAudioMgr, getAuPresetMenu for mod: Zebra NGlobals, return auPresetMenuView, 862 items FGenAudioMod, updateAuPresetData DONE NPopupView, selectItemWithText: |Default| **NAudioMgr, conn group 4 to AU graph, 3 modules, mixerIndex: 2 .. audioSourcePort type: 0 FMAuSynth, setAudioUnit >>> NAudioMgr : pre-init new AU node! Initialization request for 2 inputs and 2 outputs Succeeded: symmetric effect configuration .. NAudioMgr: connect group to matrix mixer: 2, and enable **NAudioMgr: ConnGroupToAuxMixer at: 2 NAudioMgr: setupMainMixerAtIndex: 2 ..status check: 0 : NAudioMgr : enable metering ..status check: 0 : NAudioMgr : conn aux send mixer to aux FUNNEL mixer ..status check: 0 : NAudioMgr : conn aux send mixer to aux FUNNEL mixer ..status check: 0 : NAudioMgr : conn aux send mixer to aux FUNNEL mixer ..status check: 0 : NAudioMgr : conn aux send mixer to aux FUNNEL mixer ..status check: 0 : NAudioMgr : conn aux send mixer to output mixer NAudioMgr : conn aux send mixer 6 to output mixer 1 .. last node for group: 74 .. connecting group to aux mixer, group's lastNodeElement: 0 ..status check: 0 : NAudioMgr : conn node to aux mixer ..status check: 0 : NAudioMgr : update graph ..status check: 0 : NAudioMgr : update graph AU GRAPH: conn: 0 node: 1 out: 0 to node: 2 in: 0 conn: 1 node: 4 out: 1 to node: 68 in: 0 conn: 2 node: 4 out: 2 to node: 69 in: 0 conn: 3 node: 4 out: 3 to node: 70 in: 0 conn: 4 node: 4 out: 4 to node: 71 in: 0 conn: 5 node: 4 out: 0 to node: 1 in: 0 conn: 6 node: 72 out: 0 to node: 4 in: 0 conn: 7 node: 5 out: 1 to node: 68 in: 1 conn: 8 node: 5 out: 2 to node: 69 in: 1 conn: 9 node: 5 out: 3 to node: 70 in: 1 conn: 10 node: 5 out: 4 to node: 71 in: 1 conn: 11 node: 5 out: 0 to node: 1 in: 1 conn: 12 node: 73 out: 0 to node: 5 in: 0 conn: 13 node: 6 out: 1 to node: 68 in: 2 conn: 14 node: 6 out: 2 to node: 69 in: 2 conn: 15 node: 6 out: 3 to node: 70 in: 2 conn: 16 node: 6 out: 4 to node: 71 in: 2 conn: 17 node: 6 out: 0 to node: 1 in: 2 conn: 18 node: 74 out: 0 to node: 6 in: 0 **NAudioMgr.connGroupToMixer DONE ..status check: 0 : NAudioMgr : update graph ******** NumerGroup: setAudioIsRouted: 1 AU GRAPH: conn: 0 node: 1 out: 0 to node: 2 in: 0 conn: 1 node: 4 out: 1 to node: 68 in: 0 conn: 2 node: 4 out: 2 to node: 69 in: 0 conn: 3 node: 4 out: 3 to node: 70 in: 0 conn: 4 node: 4 out: 4 to node: 71 in: 0 conn: 5 node: 4 out: 0 to node: 1 in: 0 conn: 6 node: 72 out: 0 to node: 4 in: 0 conn: 7 node: 5 out: 1 to node: 68 in: 1 conn: 8 node: 5 out: 2 to node: 69 in: 1 conn: 9 node: 5 out: 3 to node: 70 in: 1 conn: 10 node: 5 out: 4 to node: 71 in: 1 conn: 11 node: 5 out: 0 to node: 1 in: 1 conn: 12 node: 73 out: 0 to node: 5 in: 0 conn: 13 node: 6 out: 1 to node: 68 in: 2 conn: 14 node: 6 out: 2 to node: 69 in: 2 conn: 15 node: 6 out: 3 to node: 70 in: 2 conn: 16 node: 6 out: 4 to node: 71 in: 2 conn: 17 node: 6 out: 0 to node: 1 in: 2 conn: 18 node: 74 out: 0 to node: 6 in: 0 **NAudioMgr, conn group to AU graph DONE FGenericAudioModuleClass buildAuOnlyParmInfoList ..RAW Num AU Params: 1000 ***NAudioMgr, getAuPresetMenu for mod: Reaktor NAudioManager : getPresetDir NAudioManager : getPresetDir NAudioMgr, load 0 user presets NAudioMgr, load 0 user presets .. got 1 user presets NGlobals, return auPresetMenuView, 1 items FGenAudioMod, updateAuPresetData DONE **NAudioMgr, conn group 5 to AU graph, 3 modules, mixerIndex: 3 .. audioSourcePort type: 0 FMAuSynth, setAudioUnit >>> NAudioMgr : pre-init new AU node! .. NAudioMgr: connect group to matrix mixer: 3, and enable **NAudioMgr: ConnGroupToAuxMixer at: 3 NAudioMgr: setupMainMixerAtIndex: 3 ..status check: 0 : NAudioMgr : enable metering ..status check: 0 : NAudioMgr : conn aux send mixer to aux FUNNEL mixer ..status check: 0 : NAudioMgr : conn aux send mixer to aux FUNNEL mixer ..status check: 0 : NAudioMgr : conn aux send mixer to aux FUNNEL mixer ..status check: 0 : NAudioMgr : conn aux send mixer to aux FUNNEL mixer ..status check: 0 : NAudioMgr : conn aux send mixer to output mixer NAudioMgr : conn aux send mixer 7 to output mixer 1 .. last node for group: 75 .. connecting group to aux mixer, group's lastNodeElement: 0 ..status check: 0 : NAudioMgr : conn node to aux mixer ..status check: 0 : NAudioMgr : update graph ..status check: 0 : NAudioMgr : update graph AU GRAPH: conn: 0 node: 1 out: 0 to node: 2 in: 0 conn: 1 node: 4 out: 1 to node: 68 in: 0 conn: 2 node: 4 out: 2 to node: 69 in: 0 conn: 3 node: 4 out: 3 to node: 70 in: 0 conn: 4 node: 4 out: 4 to node: 71 in: 0 conn: 5 node: 4 out: 0 to node: 1 in: 0 conn: 6 node: 72 out: 0 to node: 4 in: 0 conn: 7 node: 5 out: 1 to node: 68 in: 1 conn: 8 node: 5 out: 2 to node: 69 in: 1 conn: 9 node: 5 out: 3 to node: 70 in: 1 conn: 10 node: 5 out: 4 to node: 71 in: 1 conn: 11 node: 5 out: 0 to node: 1 in: 1 conn: 12 node: 73 out: 0 to node: 5 in: 0 conn: 13 node: 6 out: 1 to node: 68 in: 2 conn: 14 node: 6 out: 2 to node: 69 in: 2 conn: 15 node: 6 out: 3 to node: 70 in: 2 conn: 16 node: 6 out: 4 to node: 71 in: 2 conn: 17 node: 6 out: 0 to node: 1 in: 2 conn: 18 node: 74 out: 0 to node: 6 in: 0 conn: 19 node: 7 out: 1 to node: 68 in: 3 conn: 20 node: 7 out: 2 to node: 69 in: 3 conn: 21 node: 7 out: 3 to node: 70 in: 3 conn: 22 node: 7 out: 4 to node: 71 in: 3 conn: 23 node: 7 out: 0 to node: 1 in: 3 conn: 24 node: 75 out: 0 to node: 7 in: 0 **NAudioMgr.connGroupToMixer DONE ..status check: 0 : NAudioMgr : update graph ******** NumerGroup: setAudioIsRouted: 1 AU GRAPH: conn: 0 node: 1 out: 0 to node: 2 in: 0 conn: 1 node: 4 out: 1 to node: 68 in: 0 conn: 2 node: 4 out: 2 to node: 69 in: 0 conn: 3 node: 4 out: 3 to node: 70 in: 0 conn: 4 node: 4 out: 4 to node: 71 in: 0 conn: 5 node: 4 out: 0 to node: 1 in: 0 conn: 6 node: 72 out: 0 to node: 4 in: 0 conn: 7 node: 5 out: 1 to node: 68 in: 1 conn: 8 node: 5 out: 2 to node: 69 in: 1 conn: 9 node: 5 out: 3 to node: 70 in: 1 conn: 10 node: 5 out: 4 to node: 71 in: 1 conn: 11 node: 5 out: 0 to node: 1 in: 1 conn: 12 node: 73 out: 0 to node: 5 in: 0 conn: 13 node: 6 out: 1 to node: 68 in: 2 conn: 14 node: 6 out: 2 to node: 69 in: 2 conn: 15 node: 6 out: 3 to node: 70 in: 2 conn: 16 node: 6 out: 4 to node: 71 in: 2 conn: 17 node: 6 out: 0 to node: 1 in: 2 conn: 18 node: 74 out: 0 to node: 6 in: 0 conn: 19 node: 7 out: 1 to node: 68 in: 3 conn: 20 node: 7 out: 2 to node: 69 in: 3 conn: 21 node: 7 out: 3 to node: 70 in: 3 conn: 22 node: 7 out: 4 to node: 71 in: 3 conn: 23 node: 7 out: 0 to node: 1 in: 3 conn: 24 node: 75 out: 0 to node: 7 in: 0 **NAudioMgr, conn group to AU graph DONE FGenericAudioModuleClass buildAuOnlyParmInfoList ..RAW Num AU Params: 48 ***NAudioMgr, getAuPresetMenu for mod: pHATmatik PRO NAudioManager : getPresetDir NAudioManager : getPresetDir NAudioMgr, load 0 user presets NAudioMgr, load 0 user presets .. got 1 user presets NGlobals, return auPresetMenuView, 1 items FGenAudioMod, updateAuPresetData DONE *** malloc_zone_malloc[376]: argument too large: 4294966984 cheers re : p e t e => => => => => => => => => => => => => => => maetrixsolution - musically platformed pete leuenberger http://www.maetrixsolution.com <= <= <= <= <= <= <= <= <= <= <= <= <= <= <= [Non-text portions of this message have been removed]
