Elektron Musical Instruments
Index last updated: 2026-04-28 23:22 UTC
i need some basic help
2007-10-09 by ernesto east
normally i record my patterns straight to protools but now im trying to archive the info so if i
need it i can access to my kits and patterns and everything so i was trying to save the pattern
and the kit dumping it via sysex and everything runs perfect, my problem starts when i want
to get that back to the monomachine,for an example  the data is on E5 i dump the K+P  and i
try to load it to E7 from the file in the sysex app (os x)  and i get nothing but the kit .
i appreciate any help
thanks
www.beastbrothers.net
Re: [elektron] i need some basic help
2007-10-10 by Patrik Rydberg
Are you on the latest OS? There was a bug in the previous version, when
you dumped a pattern back to the monomachine, verify would say OK, but
a real receive would fail.
/Patrik
> starts when i want
> dump the K+P and i
> thanks
Re: i need some basic help
2007-10-10 by ernesto east
i have the 1.08b os installed, so the bug is stll alive :(
> /Patrik
> > starts when i want
> > dump the K+P and i
> > thanks
Re: [elektron] Re: i need some basic help
2007-10-11 by Patrik Rydberg
Well, not the same bug. I contacted elektron about the bug I mentioned
and also tested after the upgrade. In 1.08 it didn't work, in 1.08b it
worked, same pattern and kit, so, well, a new bug, but might be related.
What happens if you load it to the same position as it was in
originally? (might be a good idea to copy the original pattern to
another position first, just in case, and then clear the original
pattern position before dumping back.) I suggest you contact elektron
support directly, they are usually very nice to deal with.
/Patrik
> <mailto:elektron-users%40yahoogroups.com>, Patrik Rydberg <rydan@...> wrote:
>  > /Patrik
> trying to
> problem
>  > > starts when i want
>  > > dump the K+P and i
>  > > thanks
